Racemic mixtures versus achiral compounds
  • Thread starter Thread starter emitted_echo
    Highschool
emitted_echo
TL;DR
How did we first discover that a racemic mixture had two different chiral compounds when it behaves the same as an achiral compound.
Lately, I've been doing a lot of research on chirality in biochemical and medical contexts; especially from a developmental standpoint. I am aware of how each enantiomer behaves differently from its corresponding mirror-image molecule, but i'm confused by racemic mixtures. I understand on a conceptual level that it's just a mixture between 'right-handed' and 'left-handed' chiralities, but how was this discovered? Everything I have read says that racemic mixtures behave identically to achiral ones since the two essentially cancel out the other's optical properties, so does this mean that there is a chance other compounds we believed to be achiral could simply be racemic mixtures we haven't separated, or is there something I am missing? Additionally, I am aware that it is incredibly complicated to separate them at times- especially depending on what specifically you're working with,- so how were these processes chosen?
Thank you in advance for any responses. I am very new to research on this subject, so any and all help is appreciated.
Chemistry news on Phys.org
Whenever you know the molecular structure (ie, the 3D positions of the atoms within the molecule), then you can immediately determine whether it is chiral or achiral - it's just a quick geometry exercise.
Once you determine that it is chiral, and it is either transparent or can be dissolved in a water solution that is transparent, then you can check a sample to see whether it will turn the polarization.
If it does not turn the polarization, then it's either a racemic mixture or its chiral affect on light is minimal.
So, for example, even without a non-racemic fructose sample, you know that the molecules are chiral by their structure. If you test a fructose sample's chiral affect on polarization and find none, you know that either the fructose sample is racemic or the chiral affect on polarization it too subtle to be noticed by your experiment.
In fact, because of its molecular structure, fructose will have a very noticeable affect.
[AI reference removed by the Mentors, since they are not allowed in the technical forums.]
Louis Pasteur (of the vaccination fame) separated racemic mixture of tartaric acid by drying it out and patiently sorting crystals under microscope. That's where it started.
Before it was known that tartaric acid is optically active if extracted from the plant material, but is not when synthesized. Pasteur explained why.
Achiral compounds aren't identical as racemic mixture. For example, achiral mezo-tartaric acid is different than mixture of +/- tartaric acid. They differ by solubility in water, acidity and melting point. What matters in a molecule's biological interactions is the configuration of individual carbons, not how they interact with polarized light. Meso-type molecules possess chiral fragments, but with opposite directions of rotation. Although the entire molecule is not chiral, one end with one configuration can interact with a receptor, and the manner of this interaction can be modified by the configuration of the other end. The net effect may therefore be different from the effects of the D,D, and L,L species. This difference is exploited in racemic resolution techniques—interactions of one chiral molecule with another chiral molecule make it possible to separate the isomers, for example, by fractional crystallization. Using the good type of technique separates (+)-tartaric acid from (-)-tartaric acid in the racemic mixture, but does not separate mesotartaric acid.
