Rack and pinion, motor selection method
  • Thread starter Thread starter theyusufmasood
    Method Motor
The discussion revolves around the design and specifications of rack and pinion mechanisms for various applications, including horizontal and vertical movements. Participants seek guidance on calculating gear ratios, motor specifications, and handling different loads and speeds in their projects.
  • One participant inquires about calculating gear ratios, pitch, and motor specifications for a rack and pinion system designed to move a 140 kg mass at a speed of 0.3 m/s.
  • Another participant questions whether acceleration and deceleration phases should be included in average speed calculations and discusses methods to counteract gravitational forces on vertical loads.
  • A participant shares a link to a similar product and asks how to calculate gear ratios based on desired speed and load.
  • One participant provides a detailed calculation of kinetic energy and power requirements for accelerating a 140 kg mass, suggesting gear ratios and motor specifications based on assumptions about gear teeth and rack pitch.
  • Several participants express confusion about specific calculations, such as the origin of a numerical factor in speed conversion.
  • Another participant describes a project involving a 200 kg load and seeks advice on motor selection, prompting questions about the load's movement and rack specifications.
  • Multiple participants discuss a scenario involving a 600 kg load, with inquiries about calculating power and torque requirements, as well as the effects of opposing forces on the pinion.
  • One participant raises a question about moving a 100 kg object up a 45-degree incline and seeks guidance on selecting the appropriate number of teeth for the rack and pinion.
Participants express various viewpoints and calculations regarding the design and specifications of rack and pinion systems. There is no consensus on specific methods or calculations, and multiple competing views remain regarding the best approaches to motor selection and load handling.
Participants mention various assumptions, such as the need for acceleration time and the effects of gravity on vertical loads. Some calculations depend on specific definitions of speed and force, which may not be universally agreed upon.
Individuals involved in mechanical design, robotics, or engineering projects that require the use of rack and pinion systems, particularly those dealing with load calculations and motor specifications.
theyusufmasood
Hi!
I'm stuck on a very basic problem while trying to design a product. Basically, I need to know how to calculate the gear ratios, pitch, motor specs etc for two rack and pinion mechanisms- one horizontal and one vertical. The pinion moves along the rack in both situations.
Mass to be moved- 140 kg
speed- 0.3m/s
Distance: Horizontal- 0.65 m, and vertical- 0.45 m
I realize this is quite a simple problem, but I'm have trouble figuring out the best way to go about calculating the specs. Could anyone tell me a basic route to go down- what steps to take in order to give me an approximate specification for my product? Any links would be helpful.
Many thanks
Do you include the acceleration and deceleration phase of movement in the average speed?
Maybe you could specify the required acceleration or the minimum time to achieve the required maximum velocity.
How will you counter the vertical axis force on the 140 kg due to gravity. Can you counterbalance that mass, apply a brake, or must you always provide a torque using a continuous current through an electric servo motor?
I have a mechanism to counter the vertical axis force, the job of the rack and pinion will solely be to drive the load. The acceleration time is not an issue in this situation, but can be taken as a minimum of 1s for convenience.
First you must accelerate 140 kg to 0.3 m/s. KE = ½ * 140 * 0.3 * 0.3 = 6.3 joule.
That needs to be provided in 1 second, so power input is 6.3 / 1.0 = 6.3 watt.
The mass on the vertical slide is balanced so no work needs to be done to lift that.
Bigger gear teeth and wider racks are stronger, so;
Select a commercially available material and rack pitch, p, that will handle the forces involved.
Select the smallest available pinion for the rack, it will have probably about n = 20 teeth.
Each turn of the pinion will advance ( n * p ) along the rack.
To travel at a speed of 0.3 m/sec pinion will require 0.3 / (n * p) RPSec = 18 / (n * p) RPM.
Assume that a DC electric motor is used that has “no load” speed of say 3000 RPM.
For maximum power output, operate it at half speed = 1500 RPM.
Gear ratio required is then (n * p) * 1500 / 18
If p is 5mm and n is 20, then required gear ratio = .005 * 20 * 1500 / 18 = 18.0 : 1 ratio.
That is probably best done with a commercially available enclosed motor with worm drive like used for car windscreen wiper or window winder units.
I sorry I am doing a very similar thing, could I ask where 18 came from ?
"To travel at a speed of 0.3 m/sec pinion will require 0.3 / (n * p) RPSec = 18 / (n * p) RPM."
It just comes from converting RPSec to RPM. The 18 is 0.3 x 60
Hello,
I am making a project, in which i have used a rack which is in 'J' shape having teets outside and have a pinion of its respective pitch. The whole rack is attached with a 200kg load. Now I'm confused in selecting correct motor for the application.
Help
Welcome to PF.
1. What length is the rack?
2. Does the 200 kg load rise, fall or move horizontally?
3. What is the maximum speed that the pinion must move on the rack?
4. What is the tooth pitch of the rack?
5, How many teeth on the pinion?
i am working on rack and pinion system where rack is fixed and pinion has to move with 0.5 m/s and should carry 600 kgs load. i needed to know how to calculate the power required by a pinion to move from one rack teeth to other and the torque if possible please show how to evaluate
Welcome to PF.
Is the 600 kg load on the vertical axis pressing the gear onto the rack ?
Or is it horizontal axial force needed to move a carriage by the spur gear meshed with rack ?
Baluncore said:
Welcome to PF.
rack is horizontal and load has to be carried along it in horizontal direction and the type of gear is spur gear only
If I understand correctly, you have a carriage that weighs 600 kg.
Energy will only be needed while the carriage is accelerating to the speed of 0.5 m/s.
Once rolling, KE = ½·m·v2 = 0.5 * 600* 0.5* 0.5 = 75 joule.
Power is rate of flow of energy. Watts = joules per second.
A 75 watt motor will accelerate the carriage to 0.5 m/s in 1 second.
Power will be torque times RPM.
Torque depends on the radius of the drive pinion, or the number of teeth on the pinion and the pitch of the rack.
you are correct
a carriage weighing 600 kgs has to be moved by the help of rack and pinion mechanism
i have a doubt that when a pinion try to move then there is a opposing force acting on the pinion by the rack teeth so how much force is the opposing and it acts tangentially or normal to the rack teeth.
If the rack has a 20° contact angle then we can resolve the contact force into two different components.
One component is horizontal, let's call it 100%, the other vertical = 100% * Tan( 20° ) = 36.4%.
The vertical component is resisted by the mass of the carriage and there is no vertical movement, so there is no energy involved. The vertical force component is also acting radially on the spur gear so it generates no torque component on the spur gear drive shaft.
The horizontal force component is in line with the carriage movement, so energy will be involved. The horizontal force is parallel to the rack, (tangent to the spur gear circumference), so the entire torque will be due to the horizontal force on the rack.
Hi,
I am doing a project for which I need to carry 100 kg object at an angle of 45 inclined plane. It needs to go at 0.5 m/s with no acceleration. In this the rack is fixed and pinion will travel up the inclined plane. How should I choose the number of teeth on rack and pinion? Also how do I calculate the best motor for the purpose?
  • · Replies 16 ·
