Radial Net Force/Circular Motion Valley Question
8 replies · 12K views · last reply
whit13j
A car is traveling through a valley at a constant speed, though not a constant velocity and (I believe) it is at the bottom. If the car's speed is 25 m/s, its mass is 1200 kg and the radius of the valley (r) is 25 meters, Use your force diagram to create a Fnet=ma equation for the Y-Direction. Then determine the magnitude of the force of the road acting on the car. (i.e. the Force Normal)
m = mass; v = velocity; r = radius
Fnet=(mv2)/r
So I know the force body diagram. Fn (Normal Force) is greater than Fg (gravity).
Then when I continue to work with the equation I can come up with
Fg - Fn = (mv2)/r which then becomes
Fn = Fg - (mv2)/r
However after this step I don't know what to plug in or even how to solve for the numbers that need to be plugged in. Well gravity will be 11760 N but after that I am lost.
Thanks!
Fn = Fg - (mv2)/r
You have your signs a bit mixed up:
ƩF = ma
Fn - Fg = mv2/r
The normal force and the acceleration are both upward.
You are given the mass, speed, and radius. Just plug them in.
Wow that was really simple...sorry sometimes even the simplest stuff in physics just goes over my head. Thank you, especially for my equation corrections!
So Fn = 41,760 N
Ah wait. There is a second question that is really similar. Instead of being in a valley the car is on top of a hill.
m = 1200 kg
r = 25 meters
speed = 43 km/hr = 11.94 m/s
Does that original formula change? The first question was Fn - Fg = (mv2)/r
However, when I used this equation my Fn was 18608.148. I thought that the Fn was less than the Fg because the car is at the top of a hill
Think it through. What's the direction of the acceleration when going over a hilltop?
Well the acceleration is straight down since the car is at the top of the hill. So that would then add to Fg and make it larger (not the actual force of gravity, it would just be Fg + a).
I feel like I should simply make Fg negative but I don't understand why.
Oh a = v2/r
I think I get it now.
So there is no upward force at all? Can you explain how that works? My teacher was talking about it in class but since it's new I don't understand it all yet
whit13j said:
Oh a = v2/r
The normal force Fn acts upward. (The road always pushes up, right?) And gravity always acts downward.
The difference between the two situations--the valley versus the hill--is the direction of the acceleration (and thus the direction of the net force).
For the valley:
ƩF = ma
Fn - Fg = mv2/r
Fn = Fg + mv2/r
The acceleration is up and thus positive in the equation. (I choose up as positive as my sign convention.)
For the hill:
ƩF = ma
Fn - Fg = -mv2/r (the acceleration is now down, thus negative)
Fn = Fg - mv2/r
This should make some intuitive sense. Think of a roller coaster. When going over the top of a hill, you feel light--a smaller than usual normal force acts. But when going through a valley, you are pressed firmly against the seat: the normal force is greater than usual.
Make sense?
