Radiation and differential equations
The discussion revolves around a problem involving radiation levels in a room, modeled using differential equations. The scenario includes a rate of radiation seeping into the room from the basement, the volume of air in the room, and the concentration of radiation in both the indoor and outdoor air. Participants are tasked with setting up a differential equation to describe the radiation dynamics over time.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants explore the formulation of a differential equation to represent the change in radiation levels, questioning the definitions of variables and the rates of radiation entering and leaving the room. There is discussion about the meaning of parameters in the equation and how to express them correctly.
The discussion is active, with participants sharing their interpretations and calculations. Some have proposed equations and attempted to derive values for parameters, while others are clarifying concepts and questioning the assumptions made. There is no explicit consensus on the final approach, but guidance is being provided regarding the setup of the problem.
Participants are working under the constraints of a homework assignment, which may limit the information available and the methods they can use. There are also discussions about equilibrium conditions and the implications of different rates of air exchange.
Pqpolalk357
Sam is seeping into a room from the basement at a rate of
$$\frac{1}{6} \times 10^6 \frac{\mathrm{pCi}}{\mathrm{hr}}$$
(pCi=picocuries). The room contains $$10^6$$ liters of air. (The rate was chosen so that the room reaches the EPA action level of $$4 \frac{pCi}{liter}$$ after $$24$$ hours.) Air in the room is being exchanged with the outside air at a rate of $$R$$ liters/hr. The outside air has a concentration of $$0.5$$ pCi/liter.
Set up an equation for the total radiation $x$ in the room in picocuries, assuming instantaneous uniform mixing, that is, the indoor concentration of radioactivity is $$\frac{x}{10^{6}}$$ pCi/liter.
Explain your equation using the notations $$\Delta x$$ pCi, $$\Delta t$$ hr, and display the units of every variable explicitly to show that they match (e. g., (pCi/liter)(liter/hr) = pCi/hr).
I wanted to try to express the differential equation under the form $$\frac{dx}{dt}=a-bx$$ such that x is the value of the radiation, but I am not sure how to use the remaining information.
The form of your target equation says radiation is entering at rate a and leaving at a rate proportional to the amount in the room. So far so good.
What are the sources of radiation entering the room. What is the rate for each source?
If the concentration in the room is x, at what rate is it leaving the room?
So we have a=1/6*10^6. I still don't understand what is b ..
I think I found. Is it: $$\frac{\Delta x}{\Delta t}=\frac{1}{6}\times 10^6+0.5R-R\frac{x}{10^6}$$
I am having a problem now with the final question:
Find the rate R at which the equilibrium is 1.5 pCi/liter (well below the EPA action level). At this value for R, how many times per day is the total volume of air of the room exchanged?
I tried to solve the above differential equation and obtained: $$x(t)=\frac{1}{6} \times \frac{10^{12}}{R}+5 \times 10^5+ \lambda \exp(\frac{-R}{10^6}t)$$
Perhaps it is the wrong procedure, but I don't really know how to proceed with this question.
I don't think you need to solve for x(t) at all. Equilibrium occurs when dx/dt = 0. So just plug that in and solve for R given that you want x/(10^6) = 1.5
The rest should be pretty trivial once you have R.
We find R=$$\frac{1}{6} \times 10^6$$ but I don't understand the rest of the question.
Well, in the simplest terms, that means that one-sixth of the air is exchanged every hour. So... how many times is the entire volume exchanged over 24 hours?
4 times
Yup.
Ok Thank you very much for all your help. Have a nice day.
No problem, and the same to you.
Turned out you didn't need it, but that is not a solution of the differential equation.
  • · Replies 27 ·
10K
  • · Replies 18 ·
