Radicals Within Radicals: Simplifying and Solving Equations
  • Thread starter Thread starter ExamFever
    Radicals
6 replies · 3K views
ExamFever
sqrt(7 + 2sqrt(6)) - sqrt(7 - 2sqrt(6))
In order to work out the radicals, I define the answer as "x". Now I can square both sides to get rid of some of the first radicals:
sqrt(7 + 2sqrt(6)) - sqrt(7 - 2sqrt(6)) = x
(sqrt(7 + 2sqrt(6)) - sqrt(7 - 2sqrt(6)))2 = (x)2
Now, I hope this is the right way of starting on this problem, continuing we get:
(7 + 2sqrt(6)) - 2 * sqrt(7+ 2 sqrt(6)) * sqrt(7 - 2 sqrt(6)) + (7 - 2 sqrt(6))
this implies:
14 - 2 * sqrt(7+ 2 sqrt(6)) * sqrt(7 - 2 sqrt(6)) = x2
on moving the 14 to the RHS and squaring once more to get rid of more radicals:
(-2 * sqrt(7+ 2 sqrt(6)) * sqrt(7 - 2 sqrt(6)) )2 = (x2-14)2
this implies
4 * (7 + 2 sqrt(6)) * (7 - 2 sqrt(6)) = (x2-14)2
because the two factors with sqrts are conjugate pairs, the LHS will look like this:
4 * (72 - (4*6) = 4 * 25 = 100
thus
100 = (x2-14)2
by taking the square root of both sides:
±10 = ± (x2-14)
±10±14 = ± x2
Now, this does not look like a proper solution. Working further I can get a couple of answers for x, but no way to check them or anything:
sqrt(24) = 2 sqrt(6) = ± x
sqrt(4) = 2 = ± x
Where do I go wrong?
You can check the answer by using a calculator on the original problem line. In fact, you can use a calculator to check each line of your solution...
Yes, however, the problem states I should be able to calculate without the use of a calculator...
Sure, I'm just saying that you can use a calculator to see if what you are doing algebraically is working...
this implies:
Why do you make it so complicated? Simplify the left side, using that
[tex]\sqrt{7+ 2 \sqrt6} \sqrt{7 - 2 \sqrt6} =\sqrt{(7+ 2 \sqrt6) (7 - 2 \sqrt6)}=?[/tex]
As for the sign of x, 7+2sqrt(6)>7-2sqrt(6), and so are the square roots. The difference is positive.
ehild
sqrt(4) = 2 = ± x
Why do you think there is no way to check? Isn't it obvious the original number is positive? And it's pretty easy to show that it's less than 4 too.
Sometimes separating the solutions via inequalities requires a lot of precision, but this one only requires very coarse estimates.
P.S. it's probably better to split into cases, rather than using ±; it's easier to avoid making mistakes that way.
Thanks to all of you. When I read your answers everything becomes clear to me. The only thing I do not understand sometimes is how I could be so stupid not to see it...I paid special attention to seeing the rules for radicals in here but missed the simple fact at one point that sqrt(a) * sqrt(b) = sqrt(ab)
I would practice more on my own not to ask so many seemingly stupid questions. Unfortunately I have very little time left and I need to evolve my basic understandings into a (somewhat) more advanced understanding of the basic rules.
Just want to say I really appreciate the input and patience. Feels like I found a great place to get help with math...sometime the internet is too big to find something like that, not this time luckily :)
Cheers,
