Radioactivity and radioactive decay
The discussion revolves around calculating the remaining percentage of thorium after 266 days, given its half-life of 1.913 years. The user initially attempted to find the solution using the atomic mass but encountered errors in their calculations. They realized that since 266 days is less than the half-life, more than 50% of thorium should remain. The correct approach involves using the formula N=No*(1/2)^n, where n represents the number of half-lives. Ultimately, the user confirmed their understanding and arrived at the correct solution.
shigg927
[SOLVED] Radioactivity and radioactive decay
Thorium (with half-life T1/2 = 1.913 yr. and atomic mass 228.028715 u) undergoes alpha decay and produces radium (atomic mass 224.020186 u) as a daughter nucleus. (Assume the alpha particle has atomic mass 4.002603 u.)
What percent of thorium is left after 266 days?
X --> Y + He
N=No*(1/2)^n
n= t/T(half)
T(half)= .693/\lambda
I found that lambda=4.14x10^-5 hrs^-1 (the problem asks for it in hours, dumb, I know.)
I then found the number of half-lives to be 266 days, or 6384 hours divided by 16757.88 hours, to be .381 half-lives. I multiplied this by Thorium's atomic mass to get 36% but this keeps turning up incorrect for my online homework.
Why don't you just apply N=No*(1/2)^n ?
since 266 days is shorter than the half life, more than 50% should be left.
Ahhhhh for some reason I thought I needed to now the number of nuclei, did NOT know I could just use the atomic mass. I got it, thank you!
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
