How many litres of air do I need for a raft in a Daft Raft Race?
  • Context: High School
  • Thread starter Thread starter rob.oc95
    Race
To support a weight of 600 kilograms in a raft for a "Daft Raft Race," approximately 601 liters of air are required. This is based on the principle that one liter of water has a mass of one kilogram. Using 50-gallon barrels, which can hold about 227 kilograms of water each, three barrels would provide sufficient buoyancy, totaling 681 kilograms. It is crucial to account for additional buoyancy to ensure the raft remains above water.
  • Understanding of Archimedes' principle
  • Basic knowledge of buoyancy calculations
  • Familiarity with metric and imperial volume conversions
  • Knowledge of the weight of water (1 liter = 1 kilogram)
  • Research Archimedes' principle in detail
  • Learn about buoyancy and stability in watercraft design
  • Explore calculations for converting gallons to liters
  • Investigate materials and designs for effective raft construction
Individuals participating in raft races, hobbyists interested in watercraft design, and educators teaching principles of physics related to buoyancy and fluid mechanics.
rob.oc95
raft for a "Daft Raft Race"
Hi all,
Now I know this has probably been asked already, and it's probably a very simple question, but I'm building a raft for a "Daft Raft Race" and I was just wondering how many litres of air in cylindrical, metal barrels would i need to support around 600 kgs?
Thanks a mil.
Rob
P.S. Even just let me know how it's calculated/a formula and I would be able to work it out myself.
rob.oc95 said:
Hi all,
Thanks a mil.
Rob
Welcome to the PF.
In general, whatever weight of water the barrel would hold, is the weight that the empty barrel will support:
http://en.wikipedia.org/wiki/Archimedes'_principle#Archimedes.27_principle
Not to say you're wrong or anything but this doesn't seem correct.
To support 600 kgs or so I would only need 3, 50 gallon containers (plus a little extra) ?
This just seems a lot less than what i was expecting.
Thanks for the quick reply anyways...
One liter of water has a mass of one kilogram, so you need at least 601 liters of air to float your 600 kilograms. (600 liters of air has a mass of 0.7 kilogram!)
Check out the wikipedia article that I linked to. It should help out.
a gallon of water weighs about 8.3 lb, and there are 2.2KG per lb, so a gal is about 3.8kg
and 150 of them would weigh about 150 x 3.8 or 570 kg. so you really need closer to 600/3.8kg or 158 gallons of container to support 600 kg...
While what has been said in this thread is true, you are likely going to want a much larger volume than what you are calculating, otherwise your flotation device will be 99% under the surface.
Ok. I think I see it now. Very Sorry. Thanks everyone else too. Great help. Couldn't find out any other answers on the internet...
That's the exact thinking that caused the 767 to run out of fuel over Canada!
It's 2.2lb per KG.A litre of water = 1kg.
There are approximately 4.54l in a UK Gallon.
That gives 4.54kg per gallon.
That means each 50 gallon container holds 227kg of water.
So for your boat you would need 3 of them to give you 681kg of buoyancy.
It's 2.2lb per KG.
:smile: Good catch!
  • · Replies 23 ·
  • · Replies 22 ·
