Rank of Matrices and Eigen Vectors
The discussion focuses on determining the rank of matrices and understanding eigenvalues and eigenvectors. For the matrix A = [2 0 9; 1 4 6; 3 5 7], the rank is confirmed to be 3 since all calculated minors are non-zero. The eigenvalues for the matrix A = [7 2; 0 1] are identified as 7 and 1, indicating that the eigenvectors can be derived from the equation (A - λI)x = 0. The conversation emphasizes that while eigenvalues can be zero, eigenvectors cannot, as they exist in the null space of the transformation.
  • Matrix rank determination using determinants
  • Understanding eigenvalues and eigenvectors
  • Matrix operations involving (A - λI)
  • Concept of eigenspaces and their dimensions
  • Study the process of calculating matrix rank using determinants in MATLAB
  • Learn about the properties of eigenvalues and eigenvectors in linear transformations
  • Explore the concept of eigenspaces and how to determine their dimensions
  • Investigate applications of eigenvalues and eigenvectors in data analysis and machine learning
Students and professionals in mathematics, engineering, and data science who are working with linear algebra concepts, particularly in relation to matrix analysis and transformations.
Erbil
Find the rank off matrices?
i)A=[2 0 9 2; 1 4 6 0; 3 5 7 1 ] 3X4
ii)A=[3 1 4; 0 5 8; -3 4 4; 1 2 4;] 4X3
Find Eigen Vectors and Values of A;
A = [3 2 4; 2 0 2; 4 2 3 ]
-when det(A) is not equal to zero it will the rank of matrices.
- (A-λ)X' = 0
I have calculate all minors ;
det(a) = [ 2 0 9; 1 4 6; 3 5 7] , [2 0 2; 1 4 0; 3 7 1] , [0 9 2; 4 6 0; 5 7 1]
And I found different numbers from zero.Does it mean that rank is 3?
My original question about Eigen Vectors and Values is to understand what is it? And where can we use it?
I would think that if any of the minors is nonzero the rank must be 3.
An Eigenvector, as you can see from the equation, is one which is not rotated at all by the matrix. Instead, the vector is merely expanded/shrunk linearly (but not to zero). These turn out to have many uses in getting to grips with the core features of the transformation.
Ok,thank you.
a is true.Tested with matlab.
For b) all det. is nonzero? so how can I write on 2X2 det form?
An eigenvalue can equal 0 so that Ax=0x. The eigenvector, however, can not be 0.
A = [-1 1 0; 1 -1 0; 0 0 0] what is the eigen vectors of this matrices?
I found eigenvalues as 0 and -2.
Eigen vector of 0?
Erbil said:
Eigen vector of 0?
As vela rightly said, an eigenvalue can be 0 but an eigenvector cannot be.
For an eigenvalue of 0, the eigenvectors will be in the null space of the transformation.
Ok but how we can find eigenvector when eigenvalue is zero?
Also there's another problem..
A=[7 2; 0 1 ] this matrice eigenvalues is not zero.Eigenvalues are 7 and 1.
(A-λI)*X=0
[7 2 ; 0 1] - 7 * [ 1 0; 01 ] = [ 0 2; 0 -6} --> [0;0;0]
If X1 = [ x1;y1]
[0 2; 0 -6] [x1;y1] = [0;0]
2y1 = 0
-6y1 = 0
x1 = 0? or not? If = 0 where to go from here?
The same way as when it is nonzero: you know A and λ, so solve (A-λI)x = 0.
(A-λI)*X=0
If X1 = [ x1;y1]
2y1 = 0
-6y1 = 0
This is telling you x1 can be anything nonzero. Remember that although we speak of eigenvectors they're really eigenspaces. The dimension of the eigenspace is the number of times the eigenvalue repeats in the roots of the polynomial. Here, neither root repeats so each eigenspace has only one dimension. You can pick any nonzero vector in that space as a representative eigenvector, but any nonzero scalar multiple of it would do as well.
