Rate of change of the gravitational force.
The discussion focuses on calculating the rate of change of gravitational force exerted by Earth on the space shuttle Endeavor as it ascends to 20 km. The shuttle's mass decreases due to fuel consumption at a rate of 1340 liters per second, with liquid oxygen density at 1141 kg/m³. Participants emphasize the need to derive the gravitational force formula, considering both mass and distance changes over time. The final answer provided by the teacher is -8.9 x 10^11 N/h, prompting users to verify their calculations and assumptions regarding mass, distance, and gravitational constants.
  • Understanding of gravitational force calculations using Newton's law of universal gravitation.
  • Knowledge of calculus, specifically differentiation and rates of change.
  • Familiarity with unit conversions, particularly between liters and cubic meters.
  • Basic principles of rocket propulsion and fuel consumption rates.
  • Review the derivation of the gravitational force formula, focusing on the variables involved.
  • Learn about the implications of mass loss in rocket dynamics and its effect on gravitational force.
  • Investigate the calculation of rates of change in physics, particularly in relation to motion and forces.
  • Explore unit conversion techniques to ensure accuracy in physical calculations.
Students studying physics, particularly those focusing on gravitational forces and rocket dynamics, as well as educators seeking to clarify complex concepts in gravitational calculations.
juanandresrua
The space shuttle Endeavor is moving at a speed of 27870 Km / h. At takeoff, its mass is 2, 28 * 10 ^ 6 kg, however, its mass decreases as it uses its fuel: the engine burns liquid oxygen which has a density of 1141 kg / m^3, at a rate of 1340 liters per second. Calculate the rate of change of the gravitational force exerted by Earth on the shuttle, at the time the rocket is 20 km in height.
I know I have to derivate the formula but I don't get any relation where I can get the dm/dt that results after derivating.
Thanks for help.
So sorry for my English.
This is definitely a question where the more you know, the less willing you are to simply calculate an answer. This is made worse by the use of something very close to a real spacecraft name that really worked in a different way that would not allow an answer to be calculated from the information given.
However I think the question wishes to assume the following rather unrealistic scenario:
The craft has steadily accelerated (or, more complicated, has experienced constant thrust) from take-off (speed zero) to reach its current speed over a distance of 20km straight up, losing mass at a constant rate to be calculated from the density of liquid oxygen.
Essentially both m and d are changing with time, so getting \frac{dF}{dt } will require considering both of these.
First thing to do is work out how many seconds have elapsed since take-off. Unless I'm making this more complicated than it needs to be.
Let me start a little further back.
Looking at ##F=G\left(\frac{mM}{d^2}\right)##, we see that ##G## and ##M## are constant and ##d## and ##m## are changing. So for our purposes, $$F(t)=GM\left(\frac{m(t)}{d(t)^2}\right)$$
We need
$$\frac{dF}{dt}=GM\frac{d}{dt}\left(\frac{m}{d^2}\right)$$
The problem effectively gives us numerical values for ##\frac{dm}{dt}## and ##\frac{dd}{dt}## at the time of interest.
Joffan thanks for answering.
I made this:
https://fbcdn-sphotos-f-a.akamaihd.net/hphotos-ak-xfp1/t1.0-9/10411975_289303221245796_714101699755499906_n.jpg
and like
https://fbcdn-photos-e-a.akamaihd.net/hphotos-ak-xaf1/t1.0-0/10325761_289303194579132_2412401599182272082_t.jpg
Where "Rho" (ρ) is the density of liquid oxygen and "v" is the volume.
Then
https://fbcdn-photos-g-a.akamaihd.net/hphotos-ak-xfa1/t1.0-0/1907645_289303214579130_8064069686441702048_s.jpg
So
https://fbcdn-photos-a-a.akamaihd.net/hphotos-ak-xpa1/v/t1.0-0/10306629_289303207912464_3219228204748229487_a.jpg?oh=c549988bc645d7b880bfe42d50d3d112&oe=5408E190&__gda__=1408655144_ad792295b29cc2ec46b31c5cf5729048
Furthermore
https://fbcdn-photos-c-a.akamaihd.net/hphotos-ak-xpa1/t1.0-0/10306544_289303197912465_4206053763258306607_a.jpg
And then I replaced all the data and converted units of dF/dt to N/h (Newton/hour) but I do not get the answer that my teacher gave: -8.9*10^11 N/h
What am I doing wrong?
- What is ##\frac{d}{dt}\left(\frac{1}{d^2}\right)##?
- Recheck ##\frac{dm}{dt}##
- What value did you use for ##m##? (And indeed ##d##, ##G## and ##M##?)
- Can you double-check the values given in your opening post, because the accelerations involved here are ridiculous, even for a calculation exercise?
  • · Replies 16 ·
