Ratio simplification using ratio series.
  • Thread starter Thread starter rcmango
    Ratio Series
7 replies · 8K views
rcmango
here is the problem: http://img155.imageshack.us/img155/5175/15399391yy7.png
how do i simplify the fraction?
i got the correct answer but I'm not sure how to simplify the fraction correctly, especially with the n+1 with a exponent 4.
please help.
Have you learned L'Hospital's rule yet? If you have then all you need to do is to evaluate [tex]\lim_{n\to \infty} \frac{n^4+16}{(n+1)^4 +16}[/tex] separately, then put that result back into the expression then you'll get the answer.
Okay, you after applying l'hospital's rule, i get 1. also, i believe i could change this (n+1)^4 to this n^4 + 1^4 i believe?
thanks.
I don't think that's allowed. What rule are you following there?
thanks.
No, it's not correct at all.
Here's a simple counter example. If n = -1, then your LHS will be 0, whereas your RHS is 2, they are not equal.
To expand the terms that have the form: (a + b)n (where n is a natural number), one should use Binomial Theorem.
Or, you can just divide both numerator, and denominator by n4 (the greatest power), like this:
[tex]\lim_{n \rightarrow \infty} \left| (2x - 1) \frac{n ^ 4 + 16}{(n + 1) ^ 4 + 16} \right|[/tex]
[tex]= |2x - 1| \lim_{n \rightarrow \infty} \left| \frac{\frac{n ^ 4 + 16}{n ^ 4}}{\frac{(n + 1) ^ 4 + 16}{n ^ 4}} \right|[/tex] (since 2x - 1 is a constant, independent of n, we can "pull" it out)
[tex]= |2x - 1| \lim_{n \rightarrow \infty} \left| \frac{1 + \frac{16}{n ^ 4}}{\frac{(n + 1) ^ 4}{n ^ 4} + \frac{16}{n ^ 4}} \right|[/tex]
[tex]= |2x - 1| \lim_{n \rightarrow \infty} \left| \frac{1 + \frac{16}{n ^ 4}}{\left( \frac{n + 1}{n} \right) ^ 4 + \frac{16}{n ^ 4}} \right|[/tex]
[tex]= |2x - 1| \lim_{n \rightarrow \infty} \left| \frac{1 + \frac{16}{n ^ 4}}{\left( \frac{n + 1}{n} \right) ^ 4 + \frac{16}{n ^ 4}} \right| = ...[/tex]
Can you go from here? :)
Viet Dao, thankyou for that thorough explanation! That was exactly my question, and it helped me a great deal!
just skipping to the end, i get the interval of convergence to be [0, 1] where i plug these into the original equation and they both converge, correct? just need a confirmation.
also the radius of convergence came to 1/2
thanks.
thanks.
What is the series you are working on? You haven't shown us any series at all. :bugeye:
