Rational function hole at (0, 0)?
5 replies · 3K views
Esoremada
The function is f(x) = 2x / x3 - 6x2 + 3x + 10
I was taught that any rational function with a numerator of smaller degree than the denominator has a horizontal asymptote at y = 0, which would apply in this case.
This makes sense for the end behaviors because as x approaches +/- ∞, y approaches 0. However, when x = 0, there seems to be no problem solving the equation and ending up with y = 0, which should be impossible since there's an asymptote there. Should my domain include x ≠ 0? Why is this? The equation resolves normally when x = 0, I thought you only needed restrictions to prevent dividing by 0.
Yes. f(x)=0, there is no problem there. But your denominator is zero at some other values of x. Can you find them?
Well, you're not dividing by zero at x=0, so there is no vertical asymptote at that point. As Dick mentioned, there are vertical asymptotes elsewhere however.
So the horizontal asymptote at y = 0 doesn't restrict that point, where y indeed equals 0? I found the 3 vertical asymptotes, those aren't what are confusing me. I thought an asymptote at y = n meant no points can exist with a y value of n.
No. An asymptote at y=n just means that the limit as x->infinity (or -infinity) of y(x) is n, as you said. y(x) can equal n for finite values of x.
In fact, a function can cut its horizontal asymptotes infinitely many times, such as y = sin(x)/x. Vertical asymptotes can't be cut though.
