Rational Inequalities: Solve & Understand | Math
  • Context: MHB
  • Thread starter Thread starter Achi_kun
    Inequalities Rational
The discussion focuses on solving the rational inequality $\dfrac{1}{x} > 2$. The solution involves two cases based on the sign of x. For x > 0, the inequality simplifies to $0 < x < \frac{1}{2}$. For x < 0, no solutions exist as the inequality cannot be satisfied. The critical point $x = \frac{1}{2}$ is derived from the equation $\frac{1}{x} = 2$, and the analysis confirms that the solution set is limited to the interval (0, 1/2).
  • Understanding of rational inequalities
  • Knowledge of interval notation
  • Familiarity with the properties of inequalities
  • Basic algebraic manipulation skills
  • Study the properties of rational functions and their discontinuities
  • Learn about solving inequalities involving absolute values
  • Explore the concept of critical points in calculus
  • Investigate the behavior of continuous functions across intervals
Students and educators in mathematics, particularly those focusing on algebra and inequalities, as well as anyone preparing for standardized tests involving rational expressions.
Achi_kun
Mathematics news on Phys.org
Uhh ... fill in the blanks? Have you worked on any of these?
Idk how the solution works
for $\dfrac{1}{x} > 2$
step 1. $\dfrac{1}{x} - \dfrac{2}{1} > 0$
combine the two fractions by using a common denominator
Personally, I wouldn't do it that say.
From $\frac{1}{x}> 2%$, multiply on both sides by x.
But you have to be careful with that! Unlike with an equation, multiplying on both sides by negative number reverses the ">" sign. So do two cases:
1) If x> 0 then $1>2x$. Divide on both sides by the positive number 2: $\frac{1}{2}> x$..
Since we are requiring that x be positve, we have $0< x< \frac{1}{2}$
2) If x< 0 then $1< 2x$. Divide on both sides by the positive number 2: $\frac{1}{2}< x$, But since we are requiring that x be negative, that is not possible.
The solution is $0<x \frac{1}{2}$.
It is also true that, for continuous functions, g and f, to change from f(x)<g(x) to f(x)> g(x), we have to go through f(x)= g(x) or a poinr where either f or g is undefined.
So start by solving the equation $\frac{1}{x}= 2$. That is the same as $1= 2x$, or $x=\frac{1}{2}$. I is also true that $\frac{1}{x}$ is undefined for x= 0. That divides the real numbers into three intervals, x< 0, 0< x< 1/2, and x> 1/2. We need only check one value of x in each interval. For x< 0 take x=-1. Then 1/x= -1 which is NOT larger than 2 so no x less than 0 satisfies 1/x> 2. For 0< x< 1/2 we can take x=1/4. Then 1/x= 4 which is greater than 2. Every number between 0 and 1/2 satisfies the inequalty. Finally take x= 1. Then 1/x=1 which is not larger than 2. No x larger than 1/2 satisfies the inequality.
  • · Replies 16 ·
