How to simplify a fraction with a square root in the numerator?
  • Thread starter Thread starter elie_girl
The discussion focuses on the method of rationalizing the numerator of a fraction containing a square root. The correct approach involves multiplying both the numerator and the denominator by the conjugate of the numerator, specifically changing the sign of the non-surd part. The example provided illustrates the process with the expression sqrt(5) + 3 over -4sqrt(7), leading to the conclusion that the final answer should eliminate the square root from the numerator. The participants clarify that rationalization requires removing square roots entirely from the numerator.
  • Understanding of rational expressions
  • Knowledge of conjugates in algebra
  • Familiarity with square roots and their properties
  • Basic algebraic manipulation skills
  • Study the process of rationalizing denominators in fractions
  • Learn about conjugate pairs and their applications in algebra
  • Practice simplifying expressions with square roots
  • Explore advanced topics in algebra, such as polynomial division
Students learning algebra, mathematics educators, and anyone seeking to improve their skills in simplifying rational expressions with square roots.
elie_girl
Rationalize the numerator
sqrt(5)+3/-4sqrt(7)
The answer I got for this was -(sqrt(5)+3*sqrt(7)/28) and it marked it as wrong.
I think you rationalised the denominator instead of the numerator...
How do I rationalize the numerator?
Almost the exact same way you normally rationalise the denominator. The difference is that this time you multiply both top and bottom with the conjugate of the numerator.
That should be right, although I do make a lot of mistakes usually :p
1. You multiply the top and the bottom by the same value that you are trying to rationalise, except the non-surd part of the expression needs to be turned from a positive to negative, this way the two square roots create an integer, and the surd disappears.
2. you simplify :)
So then would the answer be (sqrt(5)+3sqrt(7))/14 ?
No, sorry.
Rationalise means get rid of all the square roots. And Numerator means the top of the fraction, and you have not got rid of the square roots on the top of the fraction
You get rid of a square root by squaring it, then it turns into an integer.
If you want to rationalise [sqrt(A) + B] then you multiply it by [sqrt(A) - B]
note the negative 'B'
When you are doing this with a fraction, multiply the top and the bottom by the same value (so you can keep the overall value the same).
I did this step-by-step in the picture I attached with my last post, it ended with the final answer as well.
Do you have any more questions? I'm glad to help.
Oh ok, I think I get it now. Thanks very much!
Please rationalize root (x plus 4) - 2 divided by x
