Why don't acids react with neutral salts in solution?
Acids do not react with neutral salts in solution due to the complete dissociation of both compounds, resulting in a mixture of ions without a double displacement reaction. For example, mixing hydrochloric acid (HCl) with sodium sulfate (Na2SO4) yields no reaction, as both remain dissociated in solution. The only scenario where a reaction occurs is when concentrated sulfuric acid (H2SO4) reacts with solid sodium chloride (NaCl), producing gaseous hydrochloric acid (HCl) and sodium sulfate (Na2SO4). Most salts of strong acids and strong bases behave similarly when mixed with strong acids, while weak acids and bases introduce more complexity due to acid-base equilibrium.
  • Understanding of acid-base reactions
  • Knowledge of ionic dissociation in aqueous solutions
  • Familiarity with chemical equilibrium concepts
  • Basic principles of oxidation-reduction reactions
  • Study the principles of acid-base equilibrium in detail
  • Learn about oxidation-reduction reactions involving acids and salts
  • Explore the behavior of weak acids and bases in solution
  • Investigate the conditions under which gas evolution occurs in acid-salt reactions
Chemistry students, educators, and anyone interested in understanding the interactions between acids and neutral salts in solution.
Vatsal Goyal
Hi
I am new to the concept of neutralization.
My teacher told me that acids do not react with neutral salts.
I want to know why not. If both are dissolved in water and both completely dissociate, why can't the ions of acid and salt exchange and perform a double displacement reaction. Moreover I have seen a reaction in one of my books - NaCl + H2SO4 produces HCl and Na2SO4
Chemistry news on Phys.org
Do you know what the net ionic reaction is? What are spectator ions? Have you learned what the chemical equilibrium is? It is much easier to understand what is going on in these terms.
In short: when you mix solutions of HCl and Na2SO4 all you get is a mixture of ions, everything is still dissociated and no reaction takes place. Such a solution doesn't differ from the solution prepared by mixing NaCl and H2SO4.
Reaction you have seen in your book requires concentrated sulfuric acid and solid NaCl - that's quite a different situation. Besides, the most important reason why it happens is that the HCl is gaseous and volatile and can leave the reaction mixture. When you add concentrated HCl to Na2SO4 basically nothing happens.
Thank you for clearing my doubt.
Just one more thing.
What is happening in the solution when an acid reacts with a basic salt?
Can we say that MOST acid and neutral salt reactions would have a similar situation?
To be precise: most salts of strong acids and strong bases will behave this way when mixed with strong acids.
When there are weak acids/bases involved things become more complicated, that's where the acid base equilibrium comes into play.
Okay got it. Thank you so much!
Some acids can react with some neutral salts, but then the reaction is not about exchange of ##H^+## ions. For example, mix nitric acid with potassium iodide (a neutral salt), and you get elemental iodine (##I_2##) and nitrogen oxides or ##NO_{2}^{-}## ions or something like that. In that case it's an oxidation-reduction reaction taking place.
Which is why I wrote
I didn't want to muddy the watter with unnecessary details.
Just to make sure that we don't talk at cross-purposes: Did he speak about salts or solutions of salts? Most of the posts are about solutions.
yes, i meant solution only. Sorry for not mentioning. :)
