Real Roots of Exponential Equation (Involves Quadratic)
The discussion revolves around determining the real roots of a quadratic equation derived from an exponential equation. The original poster expresses confusion regarding the relevance of both roots in the context of the problem, particularly focusing on the conditions under which these roots are valid.
  • Participants explore the conditions for real roots of the quadratic equation, specifically questioning the implications of the discriminant and the validity of negative roots in the context of the original exponential equation.
Participants are actively engaging in clarifying the conditions under which the roots are valid. There is an exploration of the implications of the values of k on the roots, with some guidance provided on the necessity of considering both roots in certain scenarios.
There is an ongoing discussion about the constraints on k and how they affect the validity of the roots, particularly in relation to the requirement for real solutions and the interpretation of the problem statement regarding the number of solutions needed.
seniorhs9
Hi. I actually understand most of this question, but not the parts in red.
Question.
[PLAIN]http://img703.imageshack.us/img703/7237/2008testhphysf.jpg
If above doesn't load, please go to http://img703.imageshack.us/img703/7237/2008testhphysf.jpg
The roots of a quadratic equation are real when [tex]b^2 - 4ac \geq 0[/tex]
Because we want real solutions, we have...
[tex]b^2 - 4ac \geq 0[/tex] so [tex]9 + 4k \geq 0 => \sqrt{9 + 4k} \geq 0[/tex] .
But [tex]y^2 - 3y + k = 0[/tex] has two solutions...
[tex]y_1 = \frac{1}{2}(3 - \sqrt{9 + 4k}[/tex]
[tex]y_2 = \frac{1}{2}(3 + \sqrt{9 + 4k}[/tex]
I get that [tex]9 + 4k \geq 0[/tex] means [tex]y_2 is true[/tex], but what about [tex]y_1[/tex]?
The solution cares about "the larger root". Ie y_2. But why doesn't it care about y_1? I mean, both y_1, y_2 are solutions?
Thank you.
Your attachment isn't coming through.
Context? Sometimes, when you're dealing with time problems, you'll get a positive and negative root, but since a negative time isn't valid, you'll just take the positive root.
However, if you're just given the equation:
[tex]y^2 -3y + k = 0[/tex]
You are correct in saying that y1 and y2 are distinct real roots (assuming that 9+4k > 0).
Hi. I think I fixed my original post. The picture loads now.
gb7nash. Thanks for your answer. But this question and the test don't give any context for [tex]x[/tex] so I still don't see why the solution doesn't care about the negative root?
Ok, I can see the image now.
Originally, we substitute y = 3x and we want to solve for y. Think about it for a second. Is there any way y can be negative? Is 3 raised to any power of x a negative number?
Knowing this now...
Hi gb7nash. Thanks for your answer.
Actually, I understand why [tex]3^x > 0[/tex] for all x.
But my question is on how [tex]y_1 = \frac{1}{2}(3 - \sqrt{9 + 4k})[/tex] goes with the above.
We don't know [tex]3 - \sqrt{9 + 4k} > 0[/tex]
We only know [tex]\sqrt{9 + 4k} \geq 0[/tex]?
You're exactly right. Depending on what value you choose for k, y1 may be positive or negative. For instance, for k = 10 you'll obtain a negative value for y1 (which is nonsense, since y cannot equal a negative number). For k = 0, you'll obtain a positive value for y1.
Since this is the case, we can't always rely on y1 to give a valid root, since there is the possibility of it being negative. However, y2 will always give a positive number (for k >= -9/4) and a valid root.
So are you saying the only final answer to this question is just y2, GIVEN [tex]\sqrt{9 + 4k} \geq 0[/tex]?
I should toss out y1, since [tex]9 + 4k \geq 0[/tex] for this problem, because like we just talked about, y1 isn't always > 0 if [tex]9 + 4k \geq 0[/tex]?
So just to make sure, y2 = 3x, GIVEN [tex]\sqrt{9 + 4k} \geq 0[/tex]. AND it is WRONG to write y = 3x as final answer, if [tex]9 + 4k \geq 0[/tex].
seniorhs9 said:
So are you saying the only final answer to this question is just y2?
No. A certain range of k makes y1 valid. What must k be to make y1 positive?
I edited my second last post because I actually didn't specify requirement [tex]9 + 4k \geq 0[/tex] for this problem. Now did I get everything right?
But to answer your question, y1 > 0 if [tex]3 - \sqrt{9 + 4k} > 0 <=> \sqrt{9 + 4k} < 3 <=> k < 0[/tex]. But this isn't what we want for this question. Because if k < -9/4, original equation won't have real roots.
No, y1 > 0 if:
[tex]\sqrt{9+4k} < 3[/tex]
Solving for k, what do you get?
Also, you want 9+4k > 0 in order to obtain a real root. Solve for k again.
Combining these, what must k be between to have two roots?
I actually meant to write [tex]3 - \sqrt{9 + 4k} > 0[/tex] so I've fixed this.
Because 3x = y > 0, the asked exponential question has AT LEAST two roots if
k < 0 and k > -9/4 <=> -9/4 < k < 0.
But I just want to make sure. The question asks "one or more real solutions", so isn't [tex]k \geq -9/4[/tex] enough?
This'd mean that it's enough to have y2 as the solution? y1 isn't necessary? Because "one" real solution's enough? Or is the answer wrong?
Yes. If k >= -9/4, we can guarantee that we'll have one or two real roots (depending on if k is between -9/4 and 0, or greater than 0). I interpret one or more to mean that they want both cases covered, so k >= -9/4 gives you what you need.
Hi gb7nash. Thank you so much for your answers.
So again, just to make sure, for only one real root, then
only y2 [tex]= \frac{1}{2}(3 + \sqrt{9 + 4k}[/tex] is a solution
so only y2 = 3x.
y1 [tex]= \frac{1}{2}(3 - \sqrt{9 + 4k}[/tex] is NOT a solution. I just want to make sure because I was confused about this.
It depends on the value of k. As stated before, y1 and y2 are solutions for -9/4 <= k < 0, and only y2 is a solution for k >= 0. Since this is the case, a) is what you're looking for.
  • · Replies 22 ·
10K
