Counting Non-Consecutive Digit Rearrangements of 11223344
  • Thread starter Thread starter Punkyc7
The problem involves counting the number of rearrangements of the string 11223344 such that no two equal digits are consecutive. The subject area relates to combinatorics and permutations with constraints.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss calculating total rearrangements and consider subtracting cases where digits are consecutive. There is mention of over-counting arrangements with repeated digits and the need to account for these repetitions.
Participants are exploring various methods to approach the problem, with some providing specific terms in their calculations. There is an ongoing dialogue about the meaning of each term and how they relate to the overall count of arrangements.
There are indications of confusion regarding the assumptions made about digit placements and the implications of selecting certain digits first. The discussion reflects a need for clarity on how to handle repetitions and arrangements effectively.
Punkyc7
Find the number of rearrangements of the string 11223344 that contain no two consecutive equal digits
So for the total rearrangements we have
\stackrel{8!}{2!2!2!2!}
I was thinking I would count the total number of rearrangements that have the same digit next to each other
So I started with the total number of rearrangements and sub tract the number of rearrangements that share the same number with the first number selected
\stackrel{7!}{2!2!2!}(4) I multiplied by four because there are 4 numbers. From here I am confused, do you assume that you have had 2 digits in a row or do you assume you could have any rearrangement of the 6 digits?Im thinking the last term would be 4!, I am not sure of the sign though
So far I have
\stackrel{8!}{2!2!2!2!}-\stackrel{7!}{2!2!2!}(4)+.... 4!
yeah the problem will be accounting for like terms with double and greater repetitions, and over counting of these.
For example if you just counted the number of a single repetition
11223434
would get repeated twice, when it is only one arrangement, so you need to account for this
so there's probably a number of ways to do it and its not always obvious which is best until you get into it, but to get started:
counting the number of arrangements with repetitions:
first consider a single set repeated digits
- choose from 4 numbers
- now choose a position in the string = 7
- now the account for how the other 6 digits can be arranged
But any cases that have 2,3 or 4 sets of repeated digits, will have been over-counted. I would try and calculate these explicitly and subtract...
Ok I think I got it
\stackrel{8!}{2!2!2!2!}-\stackrel{7!}{2!2!2!}(4C1)+ \stackrel{6!}{2!2!}(4C2)-\stackrel{5!}{2!}(4C3)+4!(4C4)
Does that seem right?
can you explain your method (or the meaning of) for each of the terms?
The first term is the number of rearrangements of the string
the second term is once we select the first number we have 7 left over and we can choose for 1 of the 4 numbers
the third term is when we have 6 letters in the string ( i.e. 223344) when we choose two numbers of those next to each other we have and of the four numbers we can choose 2 different ways.
the fourth term the number of string when there are 5 rearrangements when we choose 3 of the four numbers
the last one is the number of ways the string keeps all of the numbers together
