What is the reason for galaxies fading in the distant future?
Galaxies beyond a distance of c/H metres from Earth exhibit recessional velocities exceeding the speed of light, leading to their eventual fading from view. The fading occurs because the expansion of the universe stretches the wavelength of light emitted from these galaxies, resulting in a decrease in energy flux as described by the inverse square law and redshift factor (1+z). The intensity of light received from these galaxies diminishes continuously as redshift approaches infinity, effectively rendering them invisible to observers on Earth in the distant future.
  • Understanding of cosmological redshift and its implications
  • Familiarity with the inverse square law of light intensity
  • Knowledge of the concept of the Hubble radius and superluminal recession
  • Basic grasp of gravitational time dilation and its effects on photon reception
  • Research "Hubble's Law and its implications for distant galaxies"
  • Study "Cosmological redshift and its effects on light propagation"
  • Explore "Gravitational time dilation in cosmology"
  • Investigate "The concept of cosmic event horizons and their significance"
Astronomers, astrophysicists, and students of cosmology interested in the long-term fate of galaxies and the implications of cosmic expansion on observable phenomena.
Einstein's Cat
Galaxies that are greater than a distance of c/H metres from Earth have recessional velocities exceeding the speed of light and begin to fade. Thus, theoretical astronomers 3 trillion years in the future will see only the Milky Way in the night sky. What is the reason for this fading of galaxies?
Space news on Phys.org
You just said the reason: they retreat faster than the speed of light.
However why would that fact mean a photon emitted from that galaxy would never reach Earth?
As the photon moves towards Earth at ##c##, the distance between Earth and the photon is increasing at greater than ##c##, so (as long as space keeps expanding at its current rate or faster) the photon will simply get further and further away.
If the expansion of space was suddenly or gradually to stop, then that would be a different matter!
Two points. As the universe expands all galaxies that move away from us tend to fade just because of the inverse square rule for intensity (all else being constant). As for the expansion itself have a look at this http://arxiv.org/abs/astro-ph/0310808 and you will see we can still and do observe galaxies who's recession velocity is greater than c.
Regards Andrew
A more accessible description in discussion here:
http://physics.stackexchange.com/qu...ceding-faster-than-light-visible-to-observers
... so amend the above observation: the galaxies are receeding from faster than the speed of light and not all the photons are able to reach a slower expansion part of the Universe. But you get the idea that farther away a galaxy the harder it is for it's light to reach us... at some point it won't be able to. The recession speed being equal to the speed of light is just not the cutoff point.
https://en.wikipedia.org/wiki/Event_horizon#Cosmic_event_horizon
I would emphasis that it is a cut-off, as Simon points out, rather than a fading. Give or take interstellar and inter galactic absorption all photons from a galaxy (treated as a point source) emitted towards us at the same time either all make it or they all don't.
Regards Andrew
There is a fading (and not just at and beyond the Hubble radius). The expansion of the universe has, in two ways, diminished the energy flux that we receive beyond just a distance effect. The energy of light is inversely proportional to its wavelength (energy of a photon is ##E=hc/\lambda)##. As the light travels to us, the expansion of the universe expands the wavelength of the light by a factor of 1+z, where z is redshift. Also, the expansion of the universe decreases the rate at which we receive photons, as compared to the rate at which photons left a source, by another factor of 1+z (gravitational time dilation). Consequently, as redshift goes continuously towards infinity (cosmological horizon, not Hubble radius), intensity continuously decreases towards zero.
Can you point me at an explanation of this effect as I would like to understand it. I have come across gravitational time dilation in association with mass but not the expansion of the universe before.
Also do you agree it fades towards a cut-off or are you saying a cut-off does not exist ?The paper I referenced implies there is one.
Thanks Andrew
George, I have managed to track down some papers on cosmological time dilation that fits your formula and some Sn Ia results that seem to confirm it. (e.g. http://www.ppd.stfc.ac.uk/ppd/resources/pdf/ppd_seminar_100609_talk_1.pdf and my original link!) I assume this is what you intended. Thanks
What exactly is the cosmological horizon? And also could one just apply the typical equation for the Doppler effect to a ray of light emitted from a retreating galaxy to calculate the redshift as well as the calculation you suggested?
Post #5 and #6 contain links you should check out since they address your questions.
Not good enough? You can also google "cosmological horizon" and get a range of articles explaining it at a variety of different levels ... you can, then, pick the one most suited to your understanding. Basically, it is the radius at which the galaxies disappear due to cosmological expansion.
The same articles will likely explain why we don't just interpret the redshift observed as a Doppler effect ... one of the side effects of doing this, for instance, would be that distant galaxies do not retreat faster than light: creating some um geometry problems.
galaxy fading sounds like the discrepancy between intensity-based distance and redshift-based distance in dark energy (as an explanation). is there anybody with hard data on intentsities and redshifts or are the galaxy's general output too fuzzy for redshift lines? There must be a general output from a galaxy that has useable data lines, or Hubble et al (Silpher) couldn't use it for the original work on the expanding universe.
the question being does the fading data coincide with the intensity problems in dimness of Sn1a information?
even further would there be an inflection point that coincides with the Sn1a data inflection point in the divergence of intensity vs redshift distance conundrum? (aka dark energy) does it agree with estimates- perlmutter reiss - z~.7 ? or is the fading of galaxies being noticed observationally but without a good analytic technique to categorize it's qualities?
There is real data discussed in both the links I made above. Regards Andrew
It is an effect due to redshift, independent of the cause of the redshift, i.e., it is present for cosmological redshift, for redshift caused by a massive object, and even for redshift caused by relative motion between source and receiver in special relativity.
Imagine that observers A and B have identical watches. A sends a light signal to B that B sees redshifted, so that each photon B receives has lower energy (by the redshift factor) than each photon that A sends out.This also means that there is an observed frequency shift for all frequencies, including the rotational frequencies of the second hands of the watches for A and B. B uses one eye to watch the A's second hand and one eye to watch his own second hand. B observes the rotational period of A's second hand to be larger (again, by the redshift factor) than the period (1 minute) of his own second hand. Suppose that A's experimental set up sends out one photon for per revolution of his second hand, i.e., at the rate of 1 photon per minute according to A. B sees the A's rotational period to greater than 1 minute, so B receives photons at a rate of less (by a redshift factor) than one a minute. Putting stuff together, the energy flux received by B is reduced by two factors of redshift compared to the energy flux sent out by A.
Yes, this illustrated well by panel 3 in figure 1 of the paper. I hope to get back to this, and to some other points.
This is incorrect. Photons emitted from galaxies with superluminal recession velocities will indeed reach earth. See the section "Superluminal recession and the Hubble sphere" here https://www.physicsforums.com/insights/inflationary-misconceptions-basics-cosmological-horizons/. The OP might find the full article of interest.
If photons emitted from galaxies with super luminal recession velocities reach Earth then why would such galaxies apparently fade away?
See George Jones' response #16 above regarding redshift.
Having read your excellent Insight, I can now see that I was ... correct! :wideeyed:
/QUOTE]
Sorry this is just not correct.
Regards Andrew
Care to elaborate?
bapowell said:
Care to elaborate?
From your insight:
"Consider a galaxy located beyond the Hubble radius at a distance dH that emits a photon towards Earth. Of course, locally this photon is traveling at c in accordance with special relativity. But, on account of the expansion, the photon is initially moving away from Earth with a speed vtot=vrec−c>0 (where positive velocities point away from Earth, in the direction of expansion.) ..."
You then go on to explain that if the expansion is decelerating, then the recession velocity will decrease and the photon will start moving towards the Earth.
Someone then asked the following question:
"So once the rate of expansion of a distant galaxy exceeds c, it will never slow to a recession velocity of less than c. So I am struggling to see how light emitted from a galaxy that is receding from us >c can ever reach us?"
To which you replied:
"When the universe is accelerating, there is an event horizon. In this case, there are indeed events (like the emission of a photon from a distant galaxy) that will never be observable by us. The misconception that snares many people is that this is also true during even decelerated expansion as long as the galaxy is receding at superluminal speeds."
I take it from this that if the rate of expansion continues to accelerate, then the photon will always be in a region of space that is receding superluminally (hence will never reach us); but if the expansion decelerates, then it may reach us, as above, subject to a more complicated calculation.
Given that I separated those two cases in my post (as underlined in post #20), I don't see my error.
As long as what you mean by "as long as space keeps expanding at its current rate or faster" is that \ddot{a}<0, then, yes, we are in agreement.
Sorry I just don't see this In the link I posted it says:
"We have seen that the speed of photons propagating towards us (the slope of our past light cone in the upper panel of Fig. 1) is not constant, but is rather vrec −c. Therefore light that is beyond the Hubble sphere has a total velocity away from us. How is it then that we can ever see this light? Although the photons are in the superluminal region and therefore recede from us (in proper distance), the Hubble sphere also recedes. In decelerating universes H decreases as ˙ a decreases (causing the Hubble sphere to recede). In accelerating universes H also tends to decrease since ˙ a increases more slowly than a. As long as the Hubble sphere recedes faster than the photons immediately outside it, ˙ DH > vrec −c, the photons end up in a subluminal region and approach us. Thus photons near the Hubble sphere that are receding slowly are overtaken by the more rapidly receding Hubble sphere."
At current conditions i.e. space expanding at it current rate and acceleration we can see galaxies beyond the Hubble sphere.
What am I missing here.
Regards Andrew
Surely however, despite the continuous diminishing of light, light will reach us, so is the fading a product of the inability for human technology to detect it or a physical phenomenon?
After the cosmological horizon, there is no known mechanism for light to reach us.
The "fading", as explained above, is the real fact that fewer photons reach us ... no amount of detector sensitivity can change that.
Not quite. I was thinking of the case where ##H## is constant. Near the beginning of your Insight you say:
"... for a given rate of expansion, ##H## ..."
But, as the article progresses it seems to focus on ##q## as the rate of change of expansion: "... for the case accelerated expansion, ##q<0##...".
So, when cosmologists say that the expansion is accelerating, do you mean ##q < 0## rather than ##H' > 0##?
Also, by my calculations ##q < 0## is equivalent to ##\ddot{a} > 0##. Is that correct?
Consider a photon seen now by us that was emitted by a galaxy at the event on our past lightcone withe approximate coordinates ##t=2## and ##D=5##. From the top panel of Figure 3, this was below (earlier) than the maximum bulge (proper distance) of our past lightcone.
According to equation (20) of the paper (and using the terminology and notation of the paper), the velocity of the photon is
$$v_\mathrm{tot} = v_\mathrm{rec} + v_\mathrm{pec} .$$
Here, ##v_\mathrm{rec}## is the recessional velocity of the galaxy at the emission event, and ##v_\mathrm{pec} = -c## (negative, since the photon was emitted in our direction).
At the emission event, our past light cone is "getting bigger", so ##v_\mathrm{tot} > 0##, which means ##v_\mathrm{rec}>c##. As the photon proceeds up our past lightcone, it passes galaxies with differing ##v_\mathrm{rec}##, but the peculiar velocity of the photon remains constant at ##v_\mathrm{pec} = -c##. In order for the photon to start moving towards us, it must have ##v_\mathrm{tot} < 0##, i.e., ##v_\mathrm{tot}## must decrease, so, at some times in the past (but not necessarily now) the photon must have had ##\dot{v}_\mathrm{tot} < 0##. From the constancy of ##v_\mathrm{pec}##, this means that ##\dot{v}_\mathrm{rec} < 0##, and equation (19) gives ##\ddot{R}<0##.
The scale factor ##R## also is often denoted (possibly with different normalization) by ##a##, and, I think, this is what bapowell means by
bapowell said:
As long as what you mean by "as long as space keeps expanding at its current rate or faster" is that \ddot{a}&lt;0, then, yes, we are in agreement.
For a universe that consists entirely of matter (including dark matter) and dark energy, an exact solution
$$R\left(t\right) = A \sinh^{\frac{2}{3}} \left(Bt\right),$$
where ##A## and ##B## are constants. Except at very early times when the early universe is radiation dominated, this corresponds to our universe. This solution has ##\ddot{R}<0## at early time, and ##\ddot{R}>0## (accelerating expansion) at later times.
They mean \ddot{a}&gt;0, which is equivalent to q&lt;0. It turns out that constant H gives \ddot{a}&gt;0. Can you see why?
  • · Replies 29 ·
  • · Replies 46 ·
