Reciprocating weight in an engine
  • Thread starter Thread starter negativegeforce
    Engine Weight
The discussion centers on accurately calculating the weight of the rod/piston assembly in an engine at various RPMs, with skepticism about the figures provided by ARP. The original poster highlights a calculation yielding 254N at 2000 RPM, noting the complexities of acceleration in simple harmonic motion and suggesting a potential adjustment factor. Participants emphasize the significant increase in perceived weight at higher RPMs, with the piston "weighing" 50 times more at 1000 RPM than at rest. The conversation also touches on the differences between linear and radial acceleration, which affect the calculations. Overall, the thread seeks clarity on the mathematical approach to these calculations and the validity of the initial figures.
negativegeforce
I have been working on a small problem for a little while, and I so happen to find this forum. I was wondering if anyone can point me to the right direction with this.
I am trying to calculate very accurately how much the rod/piston assembly in an engine will weigh at a given RPM. I have been studying ARP's (Automotive Racing Products) equations from their website, but the numbers do not sound correct at all ( 228,742 kilo's @ 1000RPM? ). So I am kind of skeptical about their math or the way I am doing it.
this is the equation and graph
http://www.arp-bolts.com/Tech/T0_FastenerEng/T0_Images/FOSTERP1A-c.jpg
http://www.arp-bolts.com/Tech/T0_FastenerEng/T0_Images/P1-CHARTS.jpg
My thoughts about this is that the piston and rod are not changing direction instantly, but the rod slowly changes direction in about a 180 degree rotation of the crankshaft, but the change peaks at the bottom and top of the strokes. So I believe there has to be a much more detailed math to describe this.
I have an excel sheet i made that has all the work already there. So if anyone could take a look at it and steer me in the right direction with this, that would be cool.
There are 3600 seconds in a minute (acceleration is expressed in terms of m/s) and the answer is in Newtons, not kg. Via f=ma, 1kg=9.8N. So I calculate an answer of about 254N (1/3600th of 915,000) at 2000 rpm. I did calculate that from scratch and then compare/cross-check with your calculation, btw, so I'm pretty sure of the answer.
There is an additional issue of the acceleration not being constant in simple harmonic motion. I can't quite get my head around it, but I think that makes the answer off by a factor of pi/2, meaning the maximum force would be about 400 N. I'm not certain of that, though.
If the position is A cos omega t, the acceleration is -omega^2 A cos omega t.
for your piston A = 0.0455 m.
A speed of 1000 rpm = 2 pi * 1000 / 60 radians/sec = 105 radians/sec
So the max acceleration of the piston at 1000 RPM is 500 m/sec or about 50 g.
So your piston will "weigh" 50 times more at 1000 RPM that at 0 RPM. The weight goes up as speed squared, so at 10000 RPM it "weighs" 5000 times as much as at 0 RPM.
An acceleration of 5000G in a rotating machine is quite a believable number - for example jet engine rotors go well beyond that G level.
Oops ... that might explain why you got a rather small force.
Piston acceleration is a linear acceleration along the axis of motion as opposed to the radial acceleration seen on the crankshaft.
Attached is what I've used in the past for this. Hope that helps.
Sure, but the accelerations at TDC and BDC are the sum and difference of two radial acclerations (the crank and the conrod - each with a different angular velocity because of the different radii) so the accelerations are the same order of magnitude as simple harmonic motion.
I thought the OP was questioning the big numbers, rather than the details of the calcs. THe formula in the first URL doesn't mean much, taken out of context.
Had my central air system checked when it sortta wasn't working. I guess I hadn't replaced the filter. Guy suggested I might want to get a UV filter accessory. He said it would "kill bugs and particulates". I know UV can kill the former, not sure how he thinks it's gonna murder the latter. Now I'm finding out there's more than one type of UV filter: one for the air flow and one for the coil. He was suggesting we might get one for the air flow, but now we'll have to change the bulb...
