Reconciling alpha particle mass
11 replies · 5K views · last reply
ezfzx
Ugh ... I remember there was a reason ... but forgot what it was.
So here's 3 bits of information gathered from dozens of sources, textbooks, official sites:
  1. Alpha particles are identical to Helium nuclei.
  2. Alpha particle mass = 4.001506 u
  3. helium-4 nuclei mass = 4.0026032 u
OK, so ... why aren't they the same?
You sure about bit 3 ? Isn't that the isotope mass instead of the nucleus mass ? So 2 electrons minus some energy heavier ?
You are referring to the atomic mass, but yes, it is.
To make a more explicit hint: find the difference between the two masses, convert to kg, and divide by 2. Does the resulting number look familiar?
jtbell said:
convert to kg
I will convert to keV/c2 if you don't mind ... :rolleyes:
Considered it a reasonable term, since the atomic mass is normally an average over isotopes.
He has only one stable isotope and 3) is the atomic mass, not nuclear.
Helium 3 is stable and naturally occurring.
OK, so the extra mass is the electrons.
That's fine. But that extra mass gets tacked on when whenever I go searching for the mass of the He-4 "nucleus".
Every source seems to ignore the fact that I'm asking for the "nucleus".
If I'm building nuclear "binding energy" questions, I need reliable numbers.
If the source isn't specific about "atomic" vs. "nuclear" mass ... or worse ... if the source is listed in response to my specific search for "nuclear mass", it can be a little frustrating. I can compare He-4 to an alpha, but what about all the other elements?
I guess the point of the story is to get values from a reliable source.
Readers: What is your favorite reliable source? U.S.Gov? Cern? Stanford? chemicalelements.com?
You also found the mass of the nucleus.
Just make sure you check which value is given in a source. A proper source will tell you that.
My point exactly.
Kids ... don't get your data from the back of a truck in a dark alley!
