Recovering lagrangian from equations of motion
This discussion focuses on the reconstruction of a Lagrangian from known equations of motion. It establishes that while it is often necessary to guess the Lagrangian, a systematic method exists for reconstructing it if an action does exist. The process involves using the variation derivative of the action and integrating by parts to derive the Lagrangian. An example is provided, demonstrating the reconstruction of a Lagrangian that leads to the equation of motion ∂aaφ + cos(φ2) = 0.
  • Understanding of Lagrangian mechanics and the Euler-Lagrange equation
  • Familiarity with functional derivatives and the action principle
  • Knowledge of integration techniques in multiple dimensions
  • Basic concepts of homotopy parameters in mathematical physics
  • Study the derivation of the Euler-Lagrange equation in detail
  • Learn about the action principle and its applications in classical mechanics
  • Explore examples of Lagrangian reconstruction for various equations of motion
  • Investigate the conditions under which a Lagrangian exists for a given set of equations of motion
Physicists, particularly those specializing in classical mechanics and theoretical physics, as well as students seeking to deepen their understanding of Lagrangian formulations and their applications in various physical systems.
tulip
Hi guys, I have a question about finding a lagrangian formulation of a theory.
If I have a system for which I know the equations of motion but not the form of the lagrangian, is it possible to find the lagrangian that will give me those equations of motion? Is there a systematic way of doing this?
Thanks to anyone who can help!
I don't think there is. Basically you have to guess your Lagrangian and check that it gives you the correct equations of motion.
It may (some times) be impossible to find a Lagrangian that identically reproduces a given set of equations as its Euler-Lagrange equations. Indeed, action principle is not very useful for describing systems in which viscosity or heat transfer is important. In most such cases no Lagrangian / action is known. However, if an action /Lagrangian does exist, we can indeed reconstructed. Let me show you how;
We know that if an action S[\phi] is given, then the equations of motion are
E(\phi) = \frac{\delta S[\phi]}{\delta \phi(x)}= 0 \ \ \ (1)
where \delta S / \delta \phi is the variation derivative of the action with respect to the dynamical variables \phi(x);
\delta S[\phi] = \int d^{n}x \frac{\delta S}{\delta \phi(x)} \delta \ \phi(x) \ \ \ (2)
Suppose now that eq(1) is given and we want to reconstruct S[\phi]. In order to do this, we introduce a (homotopy) parameter \lambda \in [0,1], and let
\phi(x) \rightarrow \lambda \phi(x)
in eq(1);
E(\lambda \phi) = \frac{\delta S}{\delta \phi}|_{\phi = \lambda \phi}
Next, we use eq(2) to write the derivative of S[\lambda \phi] with respect to \lambda;
<br /> \frac{d}{d\lambda}S[\lambda \phi] = \int d^{n}x \frac{\delta S}{\delta \phi}|_{\phi = \lambda \phi}\ \frac{d}{d\lambda}(\lambda \phi ) = \int d^{n}x \ E(\lambda \phi ) \ \phi (x)<br />
Integrating this equation from \lambda = 0 to \lambda = 1 gives (up to an arbitrary additive constant);
<br /> S[\phi] = \int d^{n}x \int_{0}^{1} d \lambda \ E(\lambda \phi )\ \phi (x) \ \ \ (3)<br />
Finally, we may need to integrate by parts and throw away all surface terms before reading off the Lagrangian from eq(3).
For example let us reconstruct the Lagrangian which leads to the following equation of motion;
\partial_{a}\partial^{a}\phi + \cos (\phi^{2}) = 0
From eq(3) we get , after integrating the 1st term by part,
<br /> S[\phi] = \int d^{n}x \int_{0}^{1} d\lambda \{ - \lambda \partial_{a}\phi \partial^{a}\phi + \phi \cos (\lambda^{2}\phi^{2}) \}<br />
From this we find our Lagrangian;
<br /> \mathcal{L} = - \frac{1}{2}\partial_{a}\phi \partial^{a}\phi + \int_{0}^{1}d\lambda\ \phi \ \cos (\lambda^{2}\phi^{2})<br />
Ok, I leave you to reconstruct an action/ Lagrangian which has
\partial_{a}\partial^{a}\phi - \sin (\phi) = 0
as its Euler-Lagrange equation.
Regards
sam
Let me ask a related question: how can one proof/see if there is or there is NOT an action for a given set of equations of motion? :) Are there references for this?
samalkhaiat -> Have been looking for something like this in the past but all I could find was clever guessing work... thanks for posting!
  • · Replies 0 ·
