I Recursive square root inside square root problem
Gionata
I have been debating this issue for days:
I can't find a recursive function of this equation:
##\large{\sqrt{2+\pi \sqrt{3+\pi\sqrt{4+\pi\sqrt{5+\dotsb}}}}}##
Starting value 2 always added with pi
has been trying to find a solution this for days now, is what I have achieved so far:
This sucession result not correct:
##f\left(n\right)=\sqrt{n+1+\pi f\left(n+1\right)}##
http://www.wolframalpha.com/input/?i=f\left(n\right)=\sqrt{n+1+\pi+f\left(n+1\right)}
Unfortunately, I do not know how to move forward, thanks a lot!
Mathematics news on Phys.org
I don't know the "correct way" to do this kind of recursive equation, but this was my strategy:
If you start from a large n and work backwards, whatever error you started with is going to get less and less as you move towards n=1. This is because you're doing those square roots over and over again.
So I solved for the f(100) given the recursion formula and given the approximation f(100)=f(101).
That got me f(100) = 11.74269.
Then I worked it backwards to f(1) using an Excel spreadsheet.
If you work out an estimate using this method or some other method, I let you know if it's consistent with what I have.
If it is consistent, I'll give you a Wolfram Alpha link that shows the series.
Thank you very much for the very comprehensive response.
I need the recursive formula because I have to demonstrate with another program (mathlab) that at high sequnze of n (very high) the value tends to a value x.
To do this I cannot be satisfied with an approximation but rather with a recursive formula that calculates exactly the value of x on the basis of (n)
It sounds as though you are saying that you are looking for a version of f(n) that is not recursive.
Or are you saying that you are looking for a recursive formula in the form of ##f(n)=g(f(n-1),n)##? In that form, you would be able to compute a series of f(n) given f(0).
Also, "tends to a value x": I presume x is a different function of n. In rough terms, as n gets very large, f(n) will be approximately ##\sqrt{n} + \pi/2##.
But I was able to get that with the existing f(n) definition - just by presuming that f(n) is approximately equal to f(n+1) for very large n.
I am a looking for a recursive formula in the form of:
in alternative
##f\left(n+1\right)=\frac{1}{\pi}\left(f\left(n\right)^2-n-1\right)##
These examples mentioned above are very close to the solution but unfortunately wrong.
What I want is to be able to get a recursive formula in order to calculate at will, repeating n times the root the exact result
Meanwhile, thank you for your interest:)
in alternative
OK.
I have that sequence. But I'm not suppose to just give it to you. On this board, I am only suppose to help you calculate it.
So I will give the general form of the answer, but not the exact answer:
http://www.wolframalpha.com/input/?i=f(n)=sqrt(n+1+(pi+f(n+1)));+f(0)=3.5
Warning: The sequence generate by that link is also not what you want.
To get it right, you need to replace that 3.5 value with the correct value.
I told you how to calculate that value earlier in this thread. But if you want more assistance, I will assist.
One more thing: When you are using wolframalpha to work this problem, f(0) to f(19) will be accurate. f(20) to f(24) may be accurate. But they plot values for f(25) to f(30) which are not valid. That's because of limitations on the precision of the floating point values they are using - and the fact that tiny errors in f(0) or f(1) quickly build up after f(19).
That is why you can get much greater precision for f(n) by starting with a good estimate of f(n+20) and working backwards to f(n). This is true no matter what tool you are using: Matlab, Excel, wolfram.
well now I've understood the situation,
I have to find the key value of f0), but I'm currently struggling a lot, if you're patient and want to I'd like if together you help me to calculate the value of f(0). I would be very grateful.
I used Excel.
I reserved column "F" for n. And "G" for f(n).
At cell F4, I put the number 100.
At cell F5, I put =f4-1. (which will be 99).
At cell G3, I put in an estimate for f(101). Almost any value will work, but I put in my estimate of 11.75. Less accurate values (0 or 20) will also work.
At cell G4, I put in your formula: =SQRT(F4+1+PI()*G3)
Then I copied G4 to G5. That gives us a good estimate of f(99).
for f(99)= 11.70016315
for f(0)= 3.609993083
Correct?
Correct?
Yes. BTW: I look for the PF alert. So if you quote something of mine, I will see it a lot quicker.
Now if you use that in Wolfram, you will see the values in the n vs. n+1 look good up to about 20.
You can't see it in the plot because the scale is messed up with f(30).
So that demonstrates:
1) that you formula was basically OK;
2) the value for f(0) to f(20) can be deduced from Wolfram.
3) Values for f(21) and on need another method - but you should have the first 80 of so in your Excel spreadsheet.
So, if you need f(9,000) in MatLab, do you know how to generate it?
For example: f(10000) = 101.5882103
f(1000000) = 1001.572531
Notice how close that is to ##\sqrt{n} + \pi/2##
I am really happy that it works, after days of work.
Thanks for the explanations, you have a great talent.
You asked me if I can generate f(9,000) in MatLab, the answer is no, do you want to explain it to me? That would be the culmination of the project.
You're going to do the same thing in MatLab that you did with Excel.
Start will 9020 and make a guess. I'd use the formula ##\sqrt{n} + \pi()/2## - but even 0 will work.
Then compute f(9019) from f(9020), f(9018) from f(9019), and so on until you get to f(9000).
If you want more precision, start with 9040 instead.
well, understood thank you very much!
Last question just to understand:
f(0)= 3.609993083
http://www.wolframalpha.com/input/?...left(n\right)^2-n-1\right);+f(0)=+3.609993083
##\sqrt{2+\pi }## f(0) should not give 2.26751?
from the second link the first value is 3.60999
##\sqrt{n} + \pi()/2## is an approximation to f(n) for large n.
As we said earlier, ##f(0)=3.609993083##.
##f(1) = \sqrt{2+\pi() f(0)} = 3.829920486##.
I'm not sure where you are getting 2.26751.
Oh.
There is a difference between ## \sqrt{2+\pi/2} ## and ## \sqrt{2} + \pi/2 ##.
.Scott said:
Oh.
oh, my error ignores...
Question, if I want to replace (retaining the formula) only the pi with phi example, and doing all the calculations as we did together should work?
##\large{\sqrt{2+\phi \sqrt{3+\phi\sqrt{4+\phi\sqrt{5+\dotsb}}}}}##
Yup. Given some specific positive value for ##\phi##.
Super
Super! Thanks a lot for your help !
Gionata said:
I calculated that for phi (Golden section)
f(0)=2.267712876
But it is not correct:
http://www.wolframalpha.com/input/?i=f\left(n+1\right)=\frac{1}{1.6180339887}\left(f\left(n\right)^2-n-1\right);+f(0)=+2.267712876
What's wrong?
I'm not sure anything is wrong. But I got f(0)=2.2677128829.
http://www.wolframalpha.com/input/?i=f(n)=sqrt(n+1+(1.6180339887f(n+1)));+f(0)=2.2677128829
Also, I notice that with 1.618.., the results are only good for about the first 15.
http://www.wolframalpha.com/input/?...1+++n]],+f[0]+==+2.267712882},+f,+{n,+0,+20}]
.Scott said:
Strange, I calculated manually with excel the first 10 series:
I got: 3.128171204
D2= 1.6180339887 (phi)
=RADQ(D2+2*RADQ(D2+3*RADQ(D2+4*RADQ(D2+5*RADQ(D2+6*RADQ(D2+7*RADQ(D2+8*RADQ(D2+9*RADQ(D2+10))))))))
You're calculating f(1).
But you have some terms backwards.
I set D10 to phi and used this:
=SQRT(2+D10*SQRT(3+D10*SQRT(4+D10*SQRT(5+D10*SQRT(6+D10*SQRT(7+D10*SQRT(8+D10*SQRT(9+D10*SQRT(10+D10*SQRT(11+D10*SQRT(12+D10*3.7)))))))))))
I got 2.560219. If you want greater precision than that, you need to use more terms.
= RADQ (2 + D10 * RADQ (2 + D10)) = 2.2534
different
= RADQ (D10 + 2 * RADQ (D10 + 3)) = 2,4322
the value of pi I wish before the sequence 2,3,(n)
Good morning, Dear Friend Gionata, even if it is evening.
Let me please to share this example, maybe it could be of help for You.
Best Regards,
one of Yours many friends,
Vitalie.
After working on the problem for a day I have found:
Starting with the more general expression, ## \large{\sqrt{1+\pi \sqrt{2+\pi\sqrt{3+\pi\sqrt{4+\dotsb}}}}} ## , we can get the backward recursive relation: $$ f\left(n\right)=\sqrt{-1+\pi \sqrt{n+1+f\left(n+1\right)^2}} $$
Putting ## f\left(n+1\right) = i ##, we work our way down until we reach ## f\left(1\right) ##.
For example, let ## n=3 ##.
## f\left(4\right) = i##, ## f\left(3\right) = \sqrt{-1+\pi \sqrt{4+i^2}} = \sqrt{-1+\pi \sqrt{3}}##, until we reach finally: $$ f\left(1\right) = \large{\sqrt{-1+\pi \sqrt{1+\pi \sqrt{2+\pi\sqrt{3}}}}}$$.
Squaring, adding one and dividing by ## \pi ##, we are getting ## \sqrt{1+\pi \sqrt{2+\pi\sqrt{3}}} ## as required.
For your particular sequence getting as far down as ## f\left(2\right) ## only, will suffice...
As easy as that!
And here is the Mathematica code for ## \sqrt{2+\pi \sqrt{3+\pi\sqrt{4+\pi\sqrt{5+\dotsb}}}} ##, for n=100:
z = I; For[n = 100, n > 1, n = n - 1,
z = N[Sqrt[-1 + \[Pi] Sqrt[n + 1 + z^2]], 100]]; (z^2 + 1)/\[Pi]
