Understanding Reflectance and Transmittance Calculations
  • Thread starter Thread starter LCSphysicist
    Reflectance
This discussion focuses on the calculations of reflectance (R) and transmittance (T) for a beam of unpolarized light interacting with an air-plastic interface. The participants clarify that T can be calculated using the formula T = 1 - R, where R is the average of the parallel and perpendicular reflectance components. They emphasize the importance of considering the polarization of light and the angle of incidence, referencing the Fresnel equations to accurately determine these values. The final consensus is that the net transmittance T is calculated as 3/4 based on the given intensities of reflected light.
  • Understanding of Fresnel equations
  • Knowledge of light polarization (p-polarization and s-polarization)
  • Familiarity with intensity calculations in optics
  • Basic principles of energy flux in electromagnetic waves
  • Study the Fresnel equations for different angles of incidence
  • Learn about the effects of polarization on reflectance and transmittance
  • Explore energy flux calculations in electromagnetic theory
  • Investigate practical applications of reflectance and transmittance in optical devices
Students and professionals in optics, physicists, and engineers working with light interactions in materials, particularly those involved in designing optical systems or studying light behavior at interfaces.
LCSphysicist
A beam of unpolarized light carries 2000W/m2 down onto an air–plastic interface. It is found that of the light reflected at the interface 300W/m2 is polarized with its E-field perpendicular to the plane of incidence and 200W/m2 parallel to the plane of incidence. Determine the net transmittance across the interface.
This type of problem always confuse me. Indeed, i am always skeptical with the answer i get, because i know there is some subtle points in the calculations that maybe i am missing... Anyway:
Can we just say that $$T = 1 - R = 1 - \frac{(R_{\parallel}+R_{\bot})}{2} = 1 - \frac{(\frac{200}{2000}+\frac{300}{2000})}{2} = 1 - 5/40 = 35/40$$ ?
I think you need to consider that the incidence may not be normal. The incident beam contains a 50-50 mix of light polarized in the plane of incidence (p-polarization) and perpendicular to it (s-polarization). The ratio of electric field magnitudes before and after reflection depends on the polarization and the angle of incidence because of the boundary conditions. Relevant are the Fresnel equations which should help you find the angle of incidence from the amount of reflected p and s polarization. Don't forget that the electric field magnitude is proportional to the square root of the energy flux.
Disclaimer: I have not solved this problem. I just described what I would try first.
Likes LCSphysicist
Yes but, i didn't assumed that the incidence was normal (did i??)
That ##R = \frac{R_{\parallel}+R_{\bot}}{2}## is jut true to any incidence, as well is ##T+R = 1##, being T defined analogous as R.
Or have i misinterpreted the theory?
(Note: i am not talking about ##r,t## (fraction of amplitudes), but ##R,T## (fraction of intensity))
LCSphysicist said:
Homework Statement:: A beam of unpolarized light carries 2000W/m2 down onto an air–plastic interface. It is found that of the light reflected at the interface 300W/m2 is polarized with its E-field perpendicular to the plane of incidence and 200W/m2 parallel to the plane of incidence. Determine the net transmittance across the interface.
Based on your result for ##T_{\rm net}##, what is the net intensity transmitted in W/m2?
Does the net transmitted intensity plus the net reflected intensity equal the net incoming intensity (2000 W/m2)?
Likes LCSphysicist
We have to be careful with how we calculate ##R_{\parallel}## and ##R_{\bot}##.
In a handwaving way we can say that if we have 2000 W/m2 of incident unpolarized light , then on the average we have 1000 W/m2 incident with || polarization and 1000 W/m2 incident with ⊥ polarization. So, ##R_{\parallel} = \frac{200}{1000}## and similarly for ##R_{\bot}##.
Likes LCSphysicist
Nice. So we got ##T = 1 - (200/1000 + 300/1000)/2 = 3/4##?
Yes, I think that's right.
  • · Replies 16 ·
  • · Replies 21 ·
