How Can Static Electricity Be Controlled in Textile Spinning Machines?
The discussion focuses on controlling static electricity in textile spinning machines, particularly where a rubber roller spins at 10,000 RPM, causing cotton fibers to stick to a stationary rubber surface. The primary solutions proposed include increasing humidity to enhance conductivity, adding fabric softener to the cotton, and utilizing earthed conductive components such as braid curtains and shorting rollers. The interaction between antistatic polyurethane and NBR rubber is identified as a significant factor in static charge generation, necessitating further exploration of conductive rubber options from suppliers like Simco-Ion.
  • Understanding of static electricity principles in textile applications
  • Familiarity with triboelectric series and material interactions
  • Knowledge of humidity's effect on static charge control
  • Experience with textile spinning machinery and its components
  • Research methods to increase humidity in textile environments
  • Explore the use of fabric softeners in cotton processing
  • Investigate conductive rubber options for spinning machine components
  • Learn about static control technologies from Simco-Ion
Textile engineers, production managers, and maintenance personnel involved in textile spinning operations seeking to mitigate static electricity issues.
Manikandan
My application is for textile spinning machine where
Rubber roller is running at a speed of 10000 rpm.
Another rubber (stationary)is rubbing on the rubber roller surface.
In this case cotton fibers are sticking on the surface of stationary rubber due to static electricity and over the period it starts accumulate on its surfaces which is the problem for us.
I would like to know how to eliminate this problem. And also is there any calculation available for determine the static electricity deposition.
Can you increase the humidity?
Triboelectric charges are created when dissimilar materials come into contact with each other. So the static charge would not be created from a rubber-to-rubber contact (assuming they are the same rubber material).
So the static charge is from another source. Perhaps the cotton coming into contact with the spinning rubber.
The most common way of eliminating this kind of problem is to keep the air more humid (thus more conductive) or to add a little fabric softener to the cotton.
Earthed non contact comb collectors .
Earthed conductive braid curtains .
Earthed lightweight metal shorting rollers .
You are essentially trying to prevent what is basically a crude Van der Graf generator from working .
+1
Although comb contacts may also scrape off some cotton causing issues?
Perhaps speak to the company that supplies the rubber rollers and ask about conductive rubber or see if they have another solution.
This company specializes in static control: https://www.simco-ion.com. They are experienced in applications similar to yours.
Rolling rubber is a antistatic polyurethane and stationary rubber is a NBR rubber ( insulator). Will there a static electricity?
Increasing humidity may increase the fibre stickiness
As triboelectric materials, all rubbers are mildly negatively charged. The polyurethane is at the very top of the list for positively charged. So that difference would be more than enough to create a static charge.
  • · Replies 19 ·
  • · Replies 24 ·
94K
  • · Replies 19 ·
12K
