Regex to match text between bold markup tags
  • Thread starter Thread starter Greg Bernhardt
    Strings Tags
14 replies · 3K views
Say I have a dozen of strings like this, with different content between the bold markup tags ("Re:" is also a constant). I need a regular expression that will match this. Basic and I think I am close, but just need a little help.
Here is what I have, but it's not matching
(?<=[b])Re:.*?(?=[/b]]) or this \[b]Re:(.+)[\/b]
Is this Python?
Don't you just need to escape the square brackets? Otherwise the regex interprets it as a character range (i.e., [abcd] matches a, b, c or d, so a b in square brackets matches b). So \[b\]Re:.*\[\/b\] should work (although that would be case sensitive).
Edit: And whether you need to escape the slash in the close bold tag may depend on your language.
Try this:
Code:
\[b\]Re:(.+)\[/b\]
This assumes that what's after the "Re:" can be anything; if you want to restrict it to alphanumerics and punctuation you could do something like:
Code:
\[b\]Re:(([A-Za-z \!\?\.\,\;]+))\[/b\]
So PF comment from the admin side is SQL-queryable?
Python's regexp parser (which is what I used for my testing) doesn't seem to require it, but yes, others might.
PeterDonis said:
Try this:
Code:
\[b\]Re:(.+)\[/b\]
Code:
This works when testing in https://regexr.com/ but when I do a SELECT query using it, it's not at all working and returns results that don't match at all. hmmm
Of course, it's all stored in a DB
What database engine? And what exactly is the SELECT query statement?
MariaDB which is a drop in replacement for mySQL.
SELECT * FROM `xf_post` WHERE `message` REGEXP '\[b\]Re:(.+)\[\/b\]'
This actually returns only 6 results when I know there are 127k when doing a LIKE query for "[B]Re:"
One of the results matches this
[b]Please check out the COBE and WMAP results[/b]
In case you're interested, Sql Server dev allows for Python and has its own ML Server.
I tested by piping a string through sed, which does require it because it uses / to delimit the regex. Some other engines follow suit - apparently not this one, though.
