What is the Related Rate of a Growing Stalk's Shadow?
  • Thread starter Thread starter Linday12
    Related rates
The discussion centers on calculating the rate of increase of a shadow length 's' from a growing stalk positioned 10 meters away from a 4-meter lamppost. As the stalk grows at a rate of 1 meter per hour, the participants derive that when the stalk reaches a height of 3 meters, the shadow length increases at a rate of 40 meters per hour. The solution involves using similar triangles and applying the chain rule in calculus to relate the variables of height, shadow length, and time.
  • Understanding of similar triangles and their properties
  • Basic knowledge of calculus, specifically differentiation and the chain rule
  • Familiarity with related rates problems in calculus
  • Ability to interpret and manipulate algebraic equations
  • Study the concept of related rates in calculus
  • Practice problems involving similar triangles and their applications
  • Learn how to apply the chain rule in differentiation
  • Explore real-world applications of related rates in physics and engineering
Students studying calculus, particularly those focusing on related rates problems, as well as educators looking for examples to illustrate the application of similar triangles and differentiation in real-world scenarios.
Linday12
A magic stalk starts growing at a spot 10 metres from a 4 metre lamppost. The stalk grows 1 metre per hour. Find the rate at which the length 's' of the stalk's shadow is increasing at the instant when the height h of the stalk is 3 metres.
First, I drew a diagram, 4m lamppost as left edge of a triangle, 3 metre height in the middle of the triangle, and 10+s base (10 meters from the beanstalk to the lamppost, and length 's' shadow. I know this part is right.
After this, I'm lost as to what I should do. I think it might be something with c^2=a^2+b^2, but the two equations seem to get very complex, so I must be doing something wrong, and I have no idea how I would combine them. (after which I assume I need the f'(x), because f'(x)=v'(t)=1, but really have no idea?
So any help in the right direction would be highly appreciated. Thanks.
Hi Linday12! :smile:
(try using the X2 tag just above the Reply box :wink:)
… I think it might be something with c^2=a^2+b^2 …
No, it's much simpler …
Hint: draw the horizontal line from the top of the magic stalk to the lamppost (so your big triangle is divided into two triangles and a rectangle). :wink:
Thanks, I'm studying for a final, and on the finals from prior years there seems to be questions like this one asked.
So, after drawing the other line, I can see two triangles in the diagram. I know the details of the one triangle, so if I remember correctly, I can find the details of the other one by using similar triangles. So, \dfrac{1}{10} = \dfrac{3}{s}, and solving for that, I get s=30. Now, I must find the rate at which the length of s is increasing at the instant when the height h of the beanstalk is 3 metres. I assume this is the part where the calculus comes into play, and I don't simply say its growing at 10 metres an hour. So, I'm not exactly sure how to make the equation that I'm supposed to take the derivative of.
Yes, using similar triangles is correct, but keep the height of the stalk as a variable
or you won't have anything to differentiate with respect to! :wink:
So what is the length of the shadow when the height is h? :smile:
Ok, so taking that into account, I have \frac{1}{10} = \frac{h}{s}, which then can be solved to become s=10h. s'=10, so the rate at which the length s is increasing is 10 metres per hour. I'm still not sure where the stalk growth of 1 metre per hour comes in at then.
Linday12 said:
Ok, so taking that into account, I have \frac{1}{10} = \frac{h}{s} …
erm :redface: … it's not 1 any more, is it? :wink:
Hint: you have three variables … h s and t :smile:
I think I understand what you mean (for a single variable course). And if I have 3 variables, that is one too many. So, since h is variable, then 1 must be variable t, and I can state it as 4-h. So, \frac{4-h}{10} = \frac{h}{s}, so s=\frac{10h}{4-h}, and s'(h)=\frac{10}{4-h} + \frac{10h}{(4-h)^2}. From here, subbing in the height of 3, I get 40. I think I am way off course.
Looks ok to me (but you should write ds/dh rather than s'(h), just to make it clear what you're differentiating with respect to, since ultimately you need ds/dt :wink:).
What's wrong with 40 (except you haven't given the units)? Calculate the length when the height is 2 3 and 3.5. :smile:
(of course, in the next hour, the shadow will go an infinite distance! :biggrin:)
Interesting. So,
\frac{ds}{dh} = \frac{10}{4-h} + \frac{10h}{(4-h)^2}
where h is 3, the shadows rate is increasing at 40... metres every 3 hours? That has to be wrong, since it doesn't really make any sense to me. I'm unsure of what the units would be.
And, when it approaches 4, the shadow does go to infinity. So, that part checks out. :smile:
And thank you for your help in finding the answer. It's very much appreciated, especially the day before a test.
Linday12 said:
… every 3 hours? That has to be wrong, since it doesn't really make any sense to me. I'm unsure of what the units would be.
Why do you have this aversion to using t (the time)? :confused:
(and where did that 3 come from?)
If you'd used t, you'd know what the units are!
Sorry, I'm not quite sure what I'm doing. I got the 3 for the height from the question, asking the shadows rate of increase at 3. It's a one variable calculus course, so I was avoiding t to keep it down to one variable, I'm not sure at all how to do differentiation with two variables. I could change the similar triangles to be: \frac{4-t}{10} = \frac{h}{s}
Which then comes out to \frac{10h}{4-t}. I'm not sure how to do this part. I can sub the rate of 1 metre per hour in, and get s=10/3 for h=1 and t=1. Then I can do the same for h=3, and t=3, and get s=30, but if I have no idea how to differentiate the equation. I guess I could let h be t as well, since it will be the same as t, becomes:
\frac{ds}{dt}=\frac{10}{4-t} + \frac{10t}{(4-t)^2}.
oooh, don't do that! :redface:
Put in the extra variable, and use the chain rule …
in this case, you want ds/dt, so that's ds/dh dh/dt (and you know dh/dt = 1 m/hr) :wink:
("one variable" means one at a time, but you can have chains of one-variable-at-a-time, in sequence :smile:)
Hmm, I am stumped. I'm not seeing how to do it at all.
But you've got it …
you had ds/dh, so you just multiply that by dh/dt (which is 1), and that gives you ds/dt in m/hr
what's worrying you about that? :confused:
Ok, so
\frac{ds}{dh} = \frac{10}{4-h} + \frac{10h}{(4-h)^2}, when the height, h, is 3, is equal to 40. So, then \frac{dh}{dt} * 40, and solving the dh/dt for 1m/hr, makes the shadow have an increase of 40 m/hr at h=3. Hopefully I'm starting to get it.
12K
