Relational quantum mechanics and its approach to interactions
127 replies · 21K views
AndreiB said:
As long as there is some motion (like a beating heart) you have a change of the mass distribution. Such a change is measurable by its gravitational effects.
"Measurable" in principle is not the same as "measured" in the actual experiment. As long as there is nothing in the experiment that couples to whatever effects the motion has, the motion is isolated, which is all that is required.
AndreiB said:
The object cannot be isolated for any time, no matter how small.
This claim is not correct; at least, not according to standard QM. Standard QM does not forbid even macroscopic objects from being isolated for some finite amount of time. Perhaps you have some different speculative theory in mind that includes such a limitation?
AndreiB said:
Such a cage cannot shield static electric or magnetic fields
You didn't say static electric or magnetic fields, you said electric currents flowing in the cat's brain. Overall the cat is electrically neutral, so putting it inside a Faraday cage will work just fine; the internal currents will not affect the (zero) external field outside the cage.
AndreiB said:
The electrons can be in superpositions because of the uncertainty principle
Wrong. They are in superpositions if you prepare their states appropriately. It has nothing to do with the uncertainty principle.
AndreiB said:
The uncertainty principle is not relevant for macroscopic objects
This is not what standard QM says; standard QM says the uncertainty principle is relevant for all measurements, although the exact limitations it places on particular measurements will vary with the size of the system and the specific measurement. Again, perhaps you have some different speculative theory in mind?
And what is wrong? Yes, you prepare them "appropriately", by a measurement of a non-commuting property. You prepare a UP/DOWN spin superposition on X by passing the electrons through a Z-oriented Stern-Gerlach device. You prepare a momentum superposition by passing the electron through a narrow slit, so that its position is accurately known and so on.
Sure, uncertainty applies to everything. However, for a macroscopic object such an instrument pointer or a cat the uncertainty is simply irrelevant because of the high mass of the object. I do not make any speculation here.
The relevant point is that the uncertainty cannot be increased by placing the system in a box. Box or no box, it's the same.
No, not measurement. Just passing a beam of electrons through a Stern-Gerlach magnet is not a measurement. The measurement comes when the beam hits a detector screen and you record the intensity on different parts of the screen. But if you're going to use the prepared beam for something else (such as passing through a second Stern-Gerlach magnet), you don't do that.
It applies to measurements. That's not the same as "everything".
The uncertainty for some measurements, such as position vs. momentum, yes. But not all measurements.
An experiment like Schrödinger's Cat that prepares a superposition of macroscopically distinct states has nothing to do with "increasing the uncertainty". If any basic principle of QM is involved in such a thought experiment, it's unitarity: if we have a microscopic system in a superposition, and we couple it in the right way to a macroscopic system, the macroscopic system gets included in the superposition, by unitarity.
OK, I stand corrected.
By "everything" I meant every object, regardless of its size or nature.
If a measurement is performed inside Schrödinger's magic box you need to make sure that an external observer is uncertain in regards to the position of that pointer. If the pointer has a mass of, say 1g there is no way you can use a preparation like in the case of an electron, so we can ignore the uncertainty principle here.
It does. According to proper QM when a measurement is performed, and the detection of a particle by a Geiger counter is such a measurement, the superposition is gone and the presence of the particle is certain. As far as I can tell there is no version of QM that has a special postulate about magical boxes that transform a measurement in a non-measurement.
As far as I can tell the unitary evolution ends when a measurement (such as a detection by a Geiger counter) occurs. The collapse is supposed to take place. You simply postulate that by using a box you can avoid that. I have provided strong arguments why this does not work. It's because, regardless of the material of the box, an outside observer can in principle observe the position of the pointer inside the box by a measurement of its gravitational field, or by a measurement of electric/magnetic fields produced by the instrument. So, the pointer cannot ever be be in a left/right superposition.
A slightly different way to think about this is to reflect on the well known question "Is the Moon There When Nobody Looks?". The answer is obviously yes, since the Moon has observable consequences everywhere, that are incompatible with a non-existence of the Moon. Without the Moon there should be no tides, Earth's orbital parameters would be different and so on. In other words it is not possible not to observe the Moon. So, if want to place the Moon in a superposition of position states by "coupling it in the right way" with a microscopic system you need to make sure that the tides are not going to "measure" the position of the Moon inside the box. How are you going to do that? What type of box are you going to use?
It isn't. That's the whole point of the thought experiment. The only measurement is performed when the box is opened and the cat is observed.
That depends on which interpretation of QM you adopt. In some interpretations, like the MWI, unitary evolution is all that ever occurs; a "measurement" is just another kind of unitary evolution.
These sorts of ideas were actually the kinds of things that Schrödinger had in mind when he proposed his cat thought experiment; as I understand it, he actually intended it to illustrate the kinds of things you are saying here--that, even though standard QM, taken literally, says it should be possible to put a cat in a superposition of being dead and alive, and Schrödinger's thought experiment describes how that could be done based on standard QM, that implication doesn't really make sense.
Schrödinger couldn't really articulate in 1935 why it doesn't really make sense, but decoherence theory, over the past few decades, has developed a viewpoint much like the one you describe. Basically, for an object with as many degrees of freedom as a cat, some of those degrees of freedom are always interacting with the environment, and those interactions are "observations". In fact, we don't even need the external environment: the degrees of freedom in the cat are always interacting with each other, and those interactions count as "observations" too.
The remaining issue, though, is that standard QM does not tell us, from first principles, how to figure out what counts as an "observation" (or a "measurement"). Those terms are simply undefined terms, and in practice physicists doing QM say that an observation or measurement occurs wherever it has to in order to make the predictions of the theory match what they see in experiments. That works in a practical sense, but it's not really satisfactory as a theory.
Different QM interpretations take different approaches to trying to fix this problem: interpretations like the MWI say that unitary evolution is all that ever happens, so a "measurement" is just more unitary evolution and doesn't require any separate theoretical machinery--but then you have to accept that the picture of "reality" that this interpretation gives you looks nothing like what we actually observe, and it's not clear how to reconcile that discrepancy. Other interpretations treat "measurement" as a distinct physical process, which is not unitary, but then you have the problem of reconciling such a process with relativity, since such a process appears to require that information about measurement results can propagate faster than light.
I think we all agree that a detection of a particle by a Geiger counter is a proper measurement. True, it's not defined from "first principles" but we know from experience that it works, the predictions of QM under the assumption that such a detection is a measurement work.
No. If you agree that a detection of a particle by a Geiger counter is a measurement, the cat cannot be put in a live/dead superposition. QM says that the state collapses when the particle is detected.
No, decoherence is a different story.
This misses the point that even single electrons interact continuously with the environment. In a 2-slit experiment the electrons are still subject to gravitational and EM interactions. The crucial point is that those interactions cannot give you enough information about the electron so that you can determine the slit the electron passed through. This is why the electron is in superposition. In the case of the cat, the interactions DO give you enough information, so the cat is not in a superposition.
The assumption you need to make in order to speak about live-dead superpositions is that you can create a box that stops the cat from interacting with the environment, so that the information you can extract from there are again insufficient to determine the cat's state. This assumption is wrong IMHO for the reasons explained earlier.
Again, an electron does interact gravitationally. The electron would make a torsion balance move, but the uncertainty principle tells us that the accuracy in electron's position is not enough to get which-slit information. A cat interacts gravitationally exactly like the electron does, but in this case the measurement accuracy is enough to tell you if it's heart beats or not. The uncertainty principle still applies, but the measurement accuracy is good enough to distinguish between a heart that beats and one that does not. This is all.
MWI fails to predict the correct probabilities, so it's not a valid interpretation.
Standard QM is fine enough here. Everybody agrees that a detection of a particle by a Geiger counter is a measurement. The question "what if the counter is placed in a box?" is irrelevant, since QM does not present us with a different set of postulates that apply only in the presence of a box.
What I think happens here is that a hidden assumption is made, that a measurement is only a measurement if some observer looks at the instrument. Such an assumption is not part of the standard QM, has no evidence in its favor, so it should be dismissed.
If by "a proper measurement" you mean "something that collapses the wave function, in a real sense instead of just as a mathematical convenience", then no, we don't all agree on this, because not all intepretations agree on it.
"QM" (meaning basic QM without adopting any particular interpretation) only says this as a mathematical convenience, not as a claim about what "really happens". Whether or not a collapse "really happens" is interpretation dependent.
Not from what you were talking about in your previous post that I quoted from. Your description of interaction with the environment and how that counts as "observation" is decoherence.
Wrong. MWI makes the same predictions as all other interpretations of QM, since all interpretations use the same or equivalent mathematical machinery to make predictions.
No, what is happening here is that you are confusing "basic" QM--the math that makes predictions about probabilities but makes no claims about what "really happens"--with interpretation-dependent claims.
Regarding Schrödinger’s Cat problem:
“… that at heart the problem does not lie with the (dis)appearance of interference terms (which is a red herring) but with the inability of quantum mechanics to predict single outcomes.” (Klaas Landsman in
"Foundations of Quantum Theory From Classical Concepts to Operator Algebras)
While I agree that the disappearance of interference terms (which is a lot of what decoherence theory deals with) is not the same as the problem of single outcomes, I think Schrödinger's Cat has elements of both.
If you are referring to the assumption in the original Schrödinger's Cat experiment that no "observation" takes place until a human observer opens the box and looks at the cat, I agree that that assumption is not part of standard QM. However, it took decades for the development of decoherence theory to explain why that assumption is not part of standard QM; prior to the development of decoherence theory, it was by no means clear that a macroscopic object like a cat, with so many degrees of freedom, will have interactions between its degrees of freedom that count as "observations" even without the box being opened.
You can eliminate any effects of gravitation by doing the experiment in free fall. You can eliminate EM interactions by isolating the experiment. No such isolation will last forever, but for electrons (as opposed to cats), it is perfectly possible to isolate them for long enough to do a reasonable experiment.
In short, you are trying to make claims about microscopic systems with very small numbers of degrees of freedom, that are only valid for macroscopic systems with very large numbers of degrees of freedom.
Not the interactions that take place while the cat is inside the box, no. Those interactions decohere the "alive" and "dead" states so there is no interference between them; but they do not, by themselves, create enough information to create a single outcome that is either "alive" or "dead". Even the interaction with the human observer, when they open the box and look at the cat, doesn't do that. The single outcome has to be put in by hand as an extra assumption in the theory, and its only real content (if we look just at basic QM and not what various interpretations claim) is that the physicist should use a collapsed wave function whenever it is necessary to make the predictions come out right. That works in a practical sense, but it does not make for a satisfactory theory, which is why there is so much literature on interpretations of QM.
The collapse predicts correctly the post-measurement state. The pre-collapse state does not make correct predictions. So, from this point of view the collapse is "real".
MWI does not make the same predictions since it doesn't have a collapse. If you prepare a spin superposition of 99% UP and 1% DOWN, MWI predicts that the measurement results in two worlds, one UP and one DOWN. Since both worlds are similar (except for the spin value) they should look to the two observers' copies just as real. The probability for the pre-measurement observer to find himself in the UP and DOWN worlds should be the same, 50%.
The MWI camp know this problem and are trying for decades to solve it. As far as I can tell, they did not succeed. The decision-theoretic approach is circular (you need to assume the existence of rational agents, but how are they supposed to exist without a notion of probability is not explained). They also try to postulate a "measure of existence" to make some worlds less likely than others, but I couldn't find what is the meaning of that measure of existence. In the end they simply postulate (not deduce) that the predictions are correct, which is fallacious.
Let's get over this by replacing the cat with a 1Kg elementary particle (or a black hole if you want). When the atom decays the black hole is moved 1m in some direction. There are no internal degrees of freedom to speak about.
Earth is in free fall, yet it surely interacts with the Sun. Free fall does not eliminate gravity, it simply means that there are no other forces/fields except gravity. If the black hole is in free fall it does not mean that it will not make my torsion balance move.
You cannot. Let's say the 1kg black hole also has charge. Tell me how you isolate that charge so that it has no influence on charges outside the box.
Time is not an issue here. I grant you that if something can be in principle isolated, that isolation is perfect. for example I agree that the box can be made perfectly reflective for photons of every wavelength, no photon will leak out.
The black hole example should solve this.
And what will you infer from a "measurement" if no observer looks at an instrument? Von Neumann's "quantum mechanical measurement chain" would here be the keyword.
Once a measurement is performed, an observer has no chance not to "observe" that fact. The Moon is there even if you don't look in its direction because it produces effects at your location. For example your body would feel Moon's gravity.
This is indeed very common-sense but sadly has little to do with QM(which doesn't mention any of the the following terms - "Moon", "tides", "body", "location", "direction", "observer"). The whole framework is only about observables, probabilities and measurements. So the whole point about the alleged persistence in time and space of those macroscopic bodies is largely moot. They are in a grey area.
You can't simply assume their 'classical' all-time existence to help yourself deal with measurements outcomes. Unless you think they are made of classical stuff which nobody has seen so far..
This is interpretation dependent. You keep ignoring interpretations like the MWI, in which the post-measurement state is not the "collapsed" state; in such interpretations "collapse" is just a mathematical convenience, not a reflection of an actual change in the physical state.
Collapse is not a prediction of basic QM; it's just a mathematical convenience. Please read the "7 Basic Rlues of QM" Insight article that is one of the sticky links in the QM forum.
Also, all QM interpretations make the same predictions. Please read the ground rules for this subforum; even if you don't personally agree with the statement I've just made, it is not up for discussion on this forum; by definition in this forum QM interpretations all make the same predictions; if you have some thingie that doesn't make the same predictions, it's not a QM interpretation, it's a different theory.
As far as the MWI itself is concerned, I'm not aware of anything in the literature claiming that the MWI does not make the same predictions as other QM interpretations; it uses the same 7 Basic Rules mathematical machinery as all of the other interpretations. It tells a very different story about what is "really happening", but that story is not a prediction since there is no way to test it. (The same is true for the stories that all the other QM interpretations tell.)
I agree there are problems with the MWI that have not been solved, but I don't think the problem you are describing (to the extent I understand what you are describing) is one of them.
It eliminates gravity as a "force" (according to general relativity, the force is not "gravity" anyway). If you are going to make claims about "gravitons", then you need to say what working theory of gravitons you are using, which will be difficult since there isn't one.
You keep introducing special cases as if they were a basis for general arguments. They're not. Let's say the hole doesn't have charge: then your argument doesn't apply. Which means it's not a general argument.
Only if you can show me a working quantum theory of black holes. Which you can't because there isn't one.
OK, never mind.
I fully agree with those postulates. The problem is that MWI has a significant difficulty to accommodate the 6 postulate, Born's rule. Please take a look at this very recent paper:
Quantum fractionalism: the Born rule as a consequence of the complex Pythagorean theorem
ALG Mandolesi
Phys. Lett. A 384 (28),126725 (2020)
The abstract reads:
"Everettian Quantum Mechanics, or the Many Worlds Interpretation, lacks an explanation for quantum probabilities"
At page 7 the problem is discussed in more detail:
"Not knowing how probabilities can emerge in EQM, we can not assume they satisfy Everett’s or Gleason’s hypotheses. Other attempts [45, 2, 10] have been made to get the right probabilities, without much success."
Sure, the author proposes his new solution, including an infinite number of universes, etc. Maybe this works, I am not sure, since the paper is new and nobody seems to offer a critique of it. But in the end the truth is that the status of the Born rule in MWI is still "work in progress", so, technically, MWI cannot make any prediction at all. But since this forum postulates that MWI makes similar predictions with Copenhagen I'll leave this issue aside.
It doesn't. I hope you agree that a planet is in free fall. A space probe in orbit around that planet is also in free fall. Yet, by a careful monitoring of the probe's orbit one can deduce the mass distribution inside the planet. The same approach can be used to detect the mass distribution of a cat inside the box, by observing the motion of a small object in orbit around the box. If the mass distribution changes (as a result of its heart beating for example) you know the cat is alive.
No gravitons.
OK, forget the charge, let's just go with mass.
OK, no black holes either.
No theory defines the instruments used to make measurements. I do not get your point.
We know that the Moon persists because we can observe the consequences of that persistence, like tides. The assumption that the Moon disappears when you don't look is falsified by those tides.
I'm not assuming their existence, I deduce their existence based on observations we can make. The tides point to the existence of a massive body, consistent with the Moon. So, if I see tides I know the Moon is there.
I think that the quantum-classical correspondence is an accepted result, so I don't need to assume any classical stuff. The classical world "emerges" out of the quantum one.
Yes, this is a well known open issue with the MWI. Some think it can be resolved, others do not.
Not by measuring "gravitational force" (since gravity isn't a force in GR), but by careful measurements of spacetime curvature--geodesic deviation. However, making such measurements takes time; it is not something you can just read off a meter instantly; and the smaller the change in mass distribution that you want to detect, the longer it takes. The same would apply to trying to detect whether a live cat is inside a box by measuring small changes in mass distribution. One could easily set up a Schrödinger's Cat scenario in which the time for the experiment to run was much shorter than the time that would be required to detect a live vs. a dead cat from changes in mass distribution.
Also, as I have already pointed out multiple times now, the fact that one can in principle make such measurements does not mean such measurements must be made in every scenario. If there is no "mass distribution measurement" being made in a given experiment, there is no way to detect a live vs. a dead cat by that method in that experiment, no matter how long it takes.
OK.
LIGO makes measurements at 10 KHz and I see no reason to believe that there is some theoretical limit. Still, 10 KHz is more than enough to detect the "wobble" associated with a beating heart.
Practically, yes, but in theory this doesn't need to be the case. A small wobble shouldn't take more time to measure than a large one.
Again, I don't think there is any theoretical limitation of that time.
I disagree here. If you send a stream of photons to the slits in a 2-slit experiment and, by detecting those photons you could, in principle, detect which slit the particle passed, no interference would be observed regardless of the fact that you actually detect those photons or not. You don't actually need to look at the instrument, the presence of the instrument is enough to eliminate the superposition.
In the cat scenario, the "instrument" can be any object with mass outside the box. The fact that you do not look at that object changes nothing, the cat is not in a superposition anymore. So, the only way to keep the cat in a superposition is to eliminate all external objects, but this implies that the experiment cannot be done, since you need to have an outside observer.
You implicitly assume those objects are not quantum in nature but classical(Newtonian and persisting in time and space). You justify this fallacy with an even bigger fallacy - that you naturally observe the effects of their Newtonian existence on other classical-like objects(like measuring instruments). The basic fact is you can't infer anything about the world from just quantum theory. This is why you always have to reach out and grab a 'classical" object or two and use them to justify your philosophy. The hard part is describing the classical world in purely quantum terms.
Can you please define what you mean by a "quantum" object? And where exactly did I assume that the objects are not "quantum"?
The "persistence in time and space" is a consequence of mass/energy conservation that applies also in QM. Anyway, where exactly did I assume that "persistence"? Can you please quote the relevant part?
The fact that one massive object acts on other massive objects in an observable way is not a fallacy, it's an experimental fact. When you see the sea level rising, you "observe the effect of the Newtonian existence" of the Moon. It's a fact.
This is a strange claim. A claim that has been refuted countless times by the many confirmed predictions of QM. QM predicts superconductors. Superconductors exist. Your unjustified assertion has been experimentally refuted.
What philosophy?
What do you mean by "quantum terms"?
The "persistence in time and space" is a consequence of mass/energy conservation that applies also in QM. Anyway, where exactly did I assume that "persistence"? Can you please quote the relevant part?The fact that one massive object acts on other massive objects in an observable way is not a fallacy, it's an experimental fact. When you see the sea level rising, you "observe the effect of the Newtonian existence" of the Moon. It's a fact.This is a strange claim. A claim that has been refuted countless times by the many confirmed predictions of QM. QM predicts superconductors. Superconductors exist. Your unjustified assertion has been experimentally refuted.What philosophy?What do you mean by "quantum terms"?
I specifically said that you can't infer anything about the classical world from just purely quantum terms. This is why you always insist on having observational gravity waves, tides, massive bodies and other classical items to explain the emergence of... other classical behaviour.
Specifically here:
Unless you can prove the world is Newtonian, I suggest you do not use "Newtonian" objects to explain quantum behavior because it's a logical fallacy and also a tautology. Saying the cat is either alive or dead because it's classical and Newtonian makes zero sense from a quantum mechanical point of view. Esp. when tied to a quantum process like atomic decay.
I asked you to define what do you mean by "quantum terms". You didn't, so the above assertion is meaningless.
Can you give me an example of observation that is not "classical"?
Describe me an experiment that does not involve the observation of "Newtonian" objects!
I agree, but this is not what I said. You are fighting a straw man here. I said that the cat is in a well defined state all the time because its state is measured from outside the box. And QM says that the superposition ends when a measurement is done. No "Newtonian" assumption is used here.
LIGO is not the tool we use to measure the mass distribution of the Earth. It is not suitable for that purpose. Measuring gravitational waves is not the same thing.
You can't just wave your hands and say what should be true "in theory". You have to actually show that the theory supports your claim.
Measuring the mass distribution of the Earth is not the same as measuring a single wobble.
See my response about theory above.
You are misdescribing this. If you don't actually detect the photons, you don't know whether or not there is interference: to know whether or not there is interference, you have to detect the photons.
What you don't have to "detect" (in the sense of "a human observes") is the output of the which-way detector: just the fact that the which-way detector is present is enough. So it's the presence of the which-way detector--the fact that there is an extra interaction in the path of the photons--that removes the interference.
In the case you're talking about, if there is a "mass distribution detector" present (and if it is actually capable of distinguishing mass distributions on the appropriate time scale), then you are correct that no human has to actually read its output for the "live cat" and "dead cat" alternatives to decohere (i.e., not interfere with each other). However, the detector still has to be there. If it is not there, then the fact that it could have been there is irrelevant. Just as, if a which-way detector is not there in a double slit experiment, there is interference, even though there wouldn't have been if the detector were there. And I was saying that, since it is perfectly possible to run the experiment with such a detector not there, you cannot make fully general claims based on what would have happened if it were there.
[/QUOTE]Explain to me what you mean by massive bodies, gravitational tides, etc in terms of wavefunctions. without resorting to acts of measurements by other unexplained "classical" objects. The framework wasn't devised to explain how the world works but to make predictions. You are using it wrongly to push your circular philosophy. There is no deep knowledge why, how and what exists prior to measurements. This is entirely philosophy, unless you adopted a minimalist interpretation which you obviously did not.
AndreiB said:
Can you give me an example of observation that is not "classical"?Describe me an experiment that does not involve the observation of "Newtonian" objects!
That all observations appear "classical" is not an excuse to use them as an explanation for the appearance of other classical-like behavior. This is a short-coming of the theory. Not its foundation.
Your reasoning and explanations are amount to : there are massive classical bodies... because this is what we observe.
Yes, my formulation was not clear. The particles that are subjected to interference are some atoms or molecules that can interact with photons of some frequency. The photons are used to get which-path information. Of course, the atoms/molecules need to be detected in order to observe the pattern.
OK, right. In the case of the cat in the box, the "which-way detector" is any object with mass that exists outside the box. The only difference is that this object interacts with the cat gravitationaly, while in the 2-slit experiment the interaction is electromagnetic. Since you agree that the presence of the detector is enough to suppress interference, it follows that the presence of at least one object with mass outside the box is enough to eliminate the superposed cats.
Right, and any object with mass is a "mass distribution detector" since its trajectory is correlated with the mass distribution. Since any finite segment of its trajectory contains an infinite number of points and you need a finite number of points to determine the mass distribution it follows that there is no minimal time required. Any time will do, assuming that the camera you use to determine the trajectory is fast and accurate enough. Sure, there are limits to the speed and accuracy of any camera but this can be compensated by using more cameras.
Yes, but since any object with mass outside the box is a "detector", and the experiment requires that something/someone outside exists so that he/it can open the box and look inside, it follows that the "detector" is guaranteed to be there.
