Relationship between Pileup and inelastic collision events
The discussion clarifies the relationship between pileup and inelastic collision events in particle detectors. Pileup refers to the number of overlapping events detected, primarily caused by inelastic collisions, which are observable by detectors. The average number of additional collisions in an event correlates with the inelastic cross section and integrated luminosity per bunch crossing. The conversation highlights the complexities of interpreting pileup, particularly in low energy nuclear physics, where accidental overlaps can lead to misinterpretations of event significance.
  • Understanding of inelastic collision events in particle physics
  • Familiarity with the concept of pileup in detector signals
  • Knowledge of Poisson distribution as it relates to event rates
  • Basic principles of integrated luminosity in high-energy physics
  • Research the calculation of inelastic cross sections in particle physics
  • Explore methods for reducing pileup in particle detectors
  • Learn about the implications of integrated luminosity on collision events
  • Investigate the Friendship paradox and its relevance to event selection in experiments
Particle physicists, experimental researchers, and anyone involved in the analysis of collision events and detector performance in high-energy physics.
Ruihu Zhu
TL;DR
why number of inelastic event approximately equals pileup event in detector?
I've read some stuff on pileup.In one paper, it says the number of inelastic event approximately equals pileup event in detector.I don't quitely understand it.Can someone explain?Thanks
Pileup is the number of events seen in the detector. Inelastic collisions are usually seen by the detectors, elastic collisions are often not (depends on the detector, however).
Sir,I'd like to ask a few more questions.Does it mean inelastic collisions cause pileup?In one paper,it directly uses inelastic cross section to calculate number of pileup.I'd like to know the reason to do so.Thanks.
All collisions that lead to tracks in the detector contribute to pileup. That typically means inelastic collisions, yes, but it depends on the detector.
There's another question confusing me.In the lessons I've learned,pileup refers to muti-collision happening at the same time which causes pileup of detector signals.Pileups are not the events we are interested in.One should reduce number of pileup.But as what you reply before, detector can only see pileup event.This seems like pileups include events we are interested in. It seems that there's a conflict.
In low energy nuclear physics the meaning of pileup is accidental overlap of events within the resolution (pulse) width of the detector. Pulses 'pile up' when they accidentally overlap in time. The pileup rate is computed by assuming events are Poisson distributed in time with the rate estimated by the observed count rate.
Two interesting collisions in the same event is essentially non-existing, so you only have events with zero interesting collisions and events with one interesting collision. Here is a non-intuitive result: The average number of extra "boring" collisions is the average number of collisions. If you have 0.05 collisions per bunch crossing on average, then your interesting collisions will have an average of 0.05 other collisions in the same event. To a good approximation in most experiments this average is the inelastic cross section times the integrated luminosity per bunch crossing. Mathematically this is related to the Friendship paradox. By choosing an interesting event you are more likely to choose an event with more collisions, simply because they have a higher chance to have an interesting event.
  • · Replies 20 ·
  • · Replies 67 ·
