What is the De Broglie Wavelength of 1.0-TeV Protons Accelerated at Fermilab?
The De Broglie wavelength of 1.0-TeV protons accelerated at the Fermilab Tevatron can be calculated using the formula λ = h / p, where p is the relativistic momentum. The momentum can be expressed as p = mvγ, incorporating the Lorentz factor γ for relativistic speeds. The discussion emphasizes the use of the equation E² = (pc)² + (mc²)² to relate energy, momentum, and mass, ultimately simplifying the calculation of the wavelength for high-energy protons.
  • Understanding of De Broglie wavelength and its significance in quantum mechanics
  • Familiarity with relativistic physics and the Lorentz factor
  • Knowledge of the relationship between energy, momentum, and mass in particle physics
  • Basic proficiency in algebra and manipulation of equations
  • Study the derivation of the De Broglie wavelength formula in quantum mechanics
  • Learn about the Lorentz factor and its application in relativistic momentum calculations
  • Explore the relationship between kinetic energy and momentum in high-energy physics
  • Investigate the role of particle accelerators like Fermilab in probing elementary particles
Physics students, particle physicists, and anyone interested in understanding the behavior of high-energy particles and their wave-particle duality.
mramsey
What is the De Broglie wavelength of the 1.0-TeV (1TeV=1012eV)
protons (mpc2=938.3MeV) accelerated at the Fermilab Tevatron
accelerator? These high-energy protons are needed to probe
elementary particles [Hint: You need to use relativistic formula, but
consider potential simplification].
λ = h / p
p=mv
λ = h /(mv*gamma)
hc = 1240 eV
Using the relativistic form i then squared both sides to get λ2 = (h2 /(mv)2)(1-v2/c2)From there i multiplied the two and multiplied by c2/c2 to get λ2 = (hc)2 /((mv2)(mc2)) - (hc)2 /((mc2)2)
I got stuck after that and not sure if i am doing it right i was thinking the mv2 could be the kinetic energy after multiplying by 1/2. λ2 = (hc)2 /2(((1/2)mv2)(mc2)) - (hc)2 /((mc2)2)and that the 1TeV is Kinetic Energy but that gives a negative number
The easy equations to use here are
p = h / lambda
and E^2 = ( p * c )^2 + ( m c^2 )^2
you're pretty much done at that point
13K
