userunknown
- 11
- 0
According to relativity, If magnetic field is just an electric field viewed from a different frame of reference, why is the magnetic field around the wire is circular?
userunknown said:If magnetic field is just an electric field viewed from a different frame of reference
jartsa said:The reason that magnetic field around a wire is circular is that we like it that way, for similar reasons as in the case of angular momentum: https://www.physicsforums.com/threads/direction-of-angular-momentum.771452/
An alternative convention might be magnetic field pointing to the direction of the Lorentz-force.
The reason that there is a cross product operation in magnetic field and force calculation is that we have chosen the first alternative not the second one.
userunknown said:Magnetic field could be defined as pointing to the direction of Lorentz force as well. But scientist wanted it to be like it that way. So there is no deeper meaning, no deeper scientific, relativistic reason. Right?
stevendaryl said:Umm, I wouldn't say that, exactly. What's important about the magnetic field, as I said, is not the direction it points in, but the direction the magnetic force points in. To say: "The magnetic field points in the x-direction" is just a convention for summarizing the information:
These facts are neatly summarized by saying:
- A positive charge moving in the positive y-direction experiences a magnetic force in the negative-z direction.
- A positive charge moving in the positive z-direction experiences a magnetic force in the positive-y direction.
- A positive charge moving in the negative-y direction experiences a magnetic force in the positive-z direction.
- A positive charge moving in the negative-z direction experiences a magnetic force in the negative-y direction.
- (And the opposite for a negative charge)
[itex]\vec{F} = q \vec{v} \times (B \hat{x})[/itex]
It's just a convention to say which "direction" the B field points in. It's also just a convention to define what the cross product [itex]\times[/itex] does. But the two conventions have to work together so that [itex]\vec{v} \times \vec{B}[/itex] is in the correct direction.
I don't understand what you are saying, sir. The magnetic field does depend on the velocity of the particle. It looks like you are talking against biot-savart law.Orodruin said:No, this is wrong. The field would then depend on the velocity of the particle it is acting on and you would lose the independence of the field from whatever is moving in the field.
userunknown said:I don't understand what you are saying, sir. The magnetic field does depend on the velocity of the particle. It looks like you are talking against biot-savart law.
stevendaryl said:The more modern way of doing electrodynamics is to treat [itex]B[/itex] as a tensor, rather than a vector.
The magnetic field does not depend on the velocity of the particle that it is acting on (aka the test charge). The velocity of the test charge is not even in the Biot Savart law. You are thinking of the source of the field, not the test charge.userunknown said:The magnetic field does depend on the velocity of the particle. It looks like you are talking against biot-savart law.
Then it looks like there is a source for magnetism. Right? We need another way so, there is only one way left to define it. This is what you mean with "then the direction of the force could not be velocity dependent". Right?Orodruin said:If the field was pointing in the same way as the force, then the direction of the force could not be velocity dependent,
Not right. The magnetic field is every bit as physical as the electric or gravitational field.userunknown said:Magnetic field is not a physical thing. Right?
userunknown said:Then it looks like there is a source for magnetism. Right? We need another way so, there is only one way left to define it. This is what you mean with "then the direction of the force could not be velocity dependent". Right?
Thank you all...
pervect said:I do not believe the magnetic field in isolation is a tensor - I'm not sure why steve appears to be saying otherwise :(.
pervect said:I'm not sure what you mean by "a physical thing". If by "a physical thing" you mean a tensor (a common but not universal interpretation), I do not believe the magnetic field in isolation is a tensor - I'm not sure why steve appears to be saying otherwise :(.
Orodruin said:Any pseudovector in three dimensional space has a 1-to-1 correspondance to a rank two anitsymmetric tensor. It is also the space-space part of the electromagnetic field tensor in relativity, which means it is a tensor (rank 2 antisymmetric) under coordinate changes on space. In some sense,
pervect said:I assume you are referring to the same tensor I linked to in my original post, the Faraday tensor, which is indeed antisymmetric. To quote the wiki reference, the Faraday tensor can be written as:
F^{\mu\nu} = \left | \begin{matrix}
0 & -E_x/c & -E_y/c & -E_z/c \\
E_x/c & 0 & -B_z & B_y \\
E_y/c & B_z & 0 & -B_x \\
E_z/c & -B_y & B_x & 0
\end{matrix} \right |
However, if you are claiming there is a one-one correspondence between ##\vec{B}## and this tensor, I have to disagree.
I am claiming nothing of the sort. I am claiming there is a 1-to-1 correspondence of the space-space part of this tensor and the magnetic field. The space-space part of any rank 2 tensor in Minkowski space is a rank 2 3-tensor.pervect said:However, if you are claiming there is a one-one correspondence between B⃗ \vec{B} and this tensor, I have to disagree.
stevendaryl said:What I was saying was that the DIRECTION of the magnetic field is not particularly meaningful. It's just a convention to say that the magnetic field "points" in this direction or that direction.
You are still seeing tensors as something that appear in 4-dimensional Minkowski space, this is not the only situation in which you can deal with tensors. The B field is most definitely an anti-symmetric rank 2 tensor with respect to spatial transformations (as I stated earlier, any space-space part of a rank 2 4-tensor is a rank 2 3-tensor wrt spatial transformations). Note that ##\vec B## does not follow the vector transformation laws under parity transformations - it is a pseudo vector, which in three dimensions have a one-to-one correspondance with ... you guessed it, antisymmetric rank 2 tensors, via the Levi-Civita symbol.pervect said:I would agree that ##\vec{B}## is part of the Faraday tensor, more exactly that there is a 1:1 correspondence between it and the purely spatial part of the Faraday tensor. Because ##\vec{B}## doesn't follow the tensor transformation laws, though, I still believe that it is not itself a tensor, but rather a piece or part of one.
OK. Thanks for help.stevendaryl said:Why do you think that? You can measure the magnetic field, so it's definitely physical. What I was saying was that the DIRECTION of the magnetic field is not particularly meaningful. It's just a convention to say that the magnetic field "points" in this direction or that direction.
It's a coincidence of 3-dmensional space that the magnetic field can be thought of as a vector.
