How Does Relativity Explain Shorter Travel Times at High Speeds?
  • Thread starter SAT2400
  • Tags
    Years
In summary, the 8 light year distance from Earth to Sirius can be reconciled with the 6 year duration of the trip by accounting for length-contraction in special relativity.
SAT2400
69
Relativity(Light years)? PLEASE HELP!
Imagine an astronaut on a trip to Siris, which is 8 light years from Earth. On arrival at Siris,
the astronaut finds that the trip lasted 6 years. If the trip was made at a constant speed of .8c, how can the 8 light year distance be reconciled with the 6 year duration?
E=mc^2
I don't know how to solve this question...8 light years-> 6 years. 3/.8c??
Please help!
Hi SAT2400! :smile:
(try using the X2 tag just above the Reply box :wink:)
(e = mc2 has nothing to do with it … and i think it's Sirius :wink:)
the astronaut's measurement of the time (on his own clock) is 6 years
what is his measurement of the distance?
The relevant equations are:
γ=1/root(1-v2/c2)
t'=γt
x=γx'
The 6 years is measured from his frame of reference, you need to measure the distance in the same frame as well.
hmm, can you explain more easily/??:(
Thanks !
Hi SAT2400! :wink:
Do you know the Lorentz transformation equations?
(you didn't mention them in your "Relevant equations")
If not, look them up in your book. :smile:
root of( 1-v^2/c^2) ...is this right??
hmm...could you please explain more in detail??
Sorry,,but I still don't know how to solve this question...:(
Sort-of …
but how are you going to use it? :smile:
I still have no idea...T_T
If I knew how to do this,,I would have not come to this website...
SO...
Please help!
THank you very much!
Use x and t for the coordinates in the Earth's frame (so Sirius is at x = 8, for all t).
Use x' and t' for the coordinates in the astronaut's frame.
Start the trip at (0,0) in both frames.
What do you get? :smile:
For one such as yourself, who seems to have a very rudimentary understanding of SR, I wouldn't bother with Lorentz transforms. For the question all you need to utilize is Length-contraction.
To the people traveling on the rocket, the length between Earth and Sirius is contracted to: [tex]L=L_0\sqrt{1-\frac{v^2}{c^2}}[/tex] The time that they measure is then simply: [tex]t=L/v[/tex]
Now you will notice that since L is contracted, it is no longer 8 light years but something shorter, and hence t can be shorter than 8 years without the rocket traveling faster than c.
1. What is the concept of relativity in terms of light years?
The concept of relativity in terms of light years is based on Einstein's theory of special relativity, which states that the laws of physics are the same for all observers in uniform motion. This means that the speed of light is constant and is the same for all observers, regardless of their relative motion or position. Light years are used as a unit of measurement to describe distances in space, and they represent the distance that light travels in one year at a constant speed of about 186,282 miles per second.
2. How is the speed of light related to the concept of relativity?
In Einstein's theory of special relativity, the speed of light is a fundamental constant and is denoted by the symbol 'c'. This means that the speed of light is the same for all observers, regardless of their relative motion. The concept of relativity is based on the idea that the laws of physics are the same for all observers, and the constant speed of light plays a crucial role in this theory.
3. What is the significance of using light years to measure distance in space?
Light years provide a convenient unit of measurement to describe the vast distances in space. Since the speed of light is constant, it allows us to accurately measure distances that would otherwise be too large to comprehend. Light years are commonly used in astronomy and astrophysics to describe the distance between celestial objects, such as stars, galaxies, and other objects in the universe.
4. How does the concept of relativity impact our understanding of time?
The theory of special relativity has shown that time is relative and can be affected by an observer's relative motion. This means that time can appear to pass differently for different observers depending on their relative motion. This concept has been confirmed through experiments and has had a significant impact on our understanding of time and how it relates to space.
5. Can you explain the difference between a light year and a regular year?
A light year is a unit of measurement used to describe distance, while a regular year is a unit of time. One light year is equal to the distance that light travels in one year, while a regular year is based on the time it takes for Earth to complete one orbit around the sun. Therefore, a light year and a regular year are two different units of measurement and cannot be directly compared to one another.
