Relativity - Lorentz Transformation
1 reply · 2K views
missmaths.
A is at the base station and given in K co-ordinates
B is on a spacecraft and given in K' co-ordinates.
The velocity of the spacecraft is v=0.8c
Question 1
After t = 2y (y = years) A sends a message by radio to B demanding a picture. Which time t' does B have when the signal arrives and what is B's distance x to the base station then?
Question 2
It took B t' = 1y time to take the picture and get the radio transmission on its
way. What time t is it for A and where (x) is the spacecraft when B launches
his message?
Question 3
What time t is it for A when the message from B arrives and where (x) is
B when this happens?
[tex]\gamma = \frac{1}{\sqrt{1-\frac{v^{2}}{c^{2}}}}[/tex]
so in this question [tex]\gamma = \frac{1}{0.6}[/tex]
Lorentz's Transformations
[tex]t' = \gamma(t-\frac{vx}{c^{2}})[/tex],
[tex]x' = \gamma(x-vt)[/tex],
[tex]t = \gamma(t'+\frac{vx'}{c^{2}})[/tex],
[tex]x = \gamma(x'+vt')[/tex].
For 1 I have done the following
[tex]x_{B}=vt[/tex],
[tex]x_{message}=c(t-2y)[/tex]
So I need to find when these to meet i.e.
[tex]vt=c(t-2y)[/tex]
which leads to
[tex]t=\frac{2y}{1-\frac{v}{c}} = \frac{2y}{1-0.8} = 10y[/tex]
therefore
[tex]x_{B}=0.8c * 10y = 8Ly[/tex]
then from the Lorentz t' equation I get 6y (just substituting values above in).
For 2 I have done the following
From 1 I saw that t' = 6y when B got the message therefore when B sends the message it must be 7y as tooks 1y to sort it.
Now I need to find t from this which is where I am stuck.
Obviously I use the t Lorentz equation however it is the entry for x' I am confused about.
As I am calculating t for A must I put in [tex]x'_{A} = -vt'[/tex] or should I put in x' = 0 as the photo is at x' = 0.
I have calculated both ways and for x' = -vt' I got 4.2y and for x' = 0, I got 11.67.
The second seems more correct as it is greater then 10 the t found in part 1, but this is relativity so I am confused.
Once I have sorted this bit I am sure I can do part 3.
Any help on my problem would be much appreciated.
Thank You.
Your instinct and reasoning that x' = 0 is correct. The primed coordinates have nothing to do with observer A; they are the coordinates B uses. You calculate for A by using the Lorentz transformations with the relative velocity of the two frames.
