Relativity, speed of light and stuff
180 replies · 27K views
atyy said:
If the electric field fills all space, that is coming very close to the aether isn't it? I kinda of do away with the aether in classical field theory by thinking that light can move into a region where it previously wasn't.
JesseM said:
Not really, because it doesn't have a rest frame of its own--I would say that's the defining difference between aether theories and field theories.
Ah, I finally understood what you meant about "no rest frame of its own" from your reply on another thread! I didn't reply there, because I thought we should confine pointless discussions to one thread:smile:.
Yes, I agree with you, that's why I said "very close". So the aether doesn't come about when an electromagnetic wave permeates all space (in which case, space itself is the aether), but rather when a partially static electromagnetic field permeates all space. The non-zero rest state of an electromagnetic field only really begins to make sense within quantum field theory. But within classical SR, we can think of some parts of space having a static electric field - which is an electromagnetic field at rest - and other parts having a traveling electromagnetic wave.
Actually what I was talking about on the other thread was a different issue, namely the fact that light waves don't have their own rest frame. In aether theory the rest frame of the aether is not the same as the rest frame of light waves, in fact the aether was thought to be a material substance that would be at rest with respect to some sublight observers (as an analogy, the rest frame of the air is not the same as the rest frame of a sound wave).
What is a "partially static electromagnetic field"? Just one where the electromagnetic field vectors at each point in space are unchanging in some frame? This is not the same as the field having a rest frame, though.
Huh? There is no rest frame of the electromagnetic field in classical electromagnetism either.
There's no reason to think that because the field is static in that frame, that's an "electromagnetic field at rest". After all, if you believe in aether, the frame where the field vectors are static could be completely different from the rest frame of the aether! (for example, look at the electromagnetic field around a charge moving inertially relative to the aether, in the charge's own rest frame)
I meant the opposite of what you understood. I agree that in classical SR, it is more helpful to identify the aether with spacetime itself. So the aether is not really useful as a concept distinct from spacetime in classical SR. However, it is useful in quantum field theory - as the vacuum state of the electromagnetic field - it is an entity distinct from spacetime because it is obligatorily non zero. I understand this is quite uncontroversial. Apart from Xiao-Gang Wen's analogy that the vacuum is like an ocean (quoted in an earlier post), there is also Wilczek's analogy (http://query.nytimes.com/gst/fullpa...1A35751C0A96F958260&sec=&spon=&pagewanted=all). There's an amusing claim by deWitt that Einstein made an appeal in 1920 that the aether should not be abandoned (Google books: p178 of "Conceptual Foundations of Quantum Field Theory" edited by Tian Yu Cao, CUP 1999).
Again, my point is that one of the defining features of the aether is that it has a rest frame of its own. Spacetime does not have a rest frame, so most authors do not identify the aether with it, they simply consider relativity to have discarded the aether (there are some exceptions, as the Einstein quote below shows, but in this case the authors make clear that they are defining 'aether' in a new way which differs from the classical notion)
The ground state of the vacuum doesn't have a rest frame either, so it would normally not be identified with the aether either.
Wilczek says the quantum vacuum should be seen as "descended from" the aether, but that's not the same as saying the quantum vacuum is a type of aether, since again it lacks a particular rest frame.
DeWitt is presumably referring to this, but Einstein does emphasize that relativity altered aether theory by getting rid of the idea of aether as a motionless substance, and was instead using a new definition of "aether" which only was meant to denote the idea that empty space has properties of its own, like spacetime curvature and electromagnetic fields:
It may be added that the whole change in the conception of the ether which the special theory of relativity brought about, consisted in taking away from the ether its last mechanical quality, namely, its immobility.
...More careful reflection teaches us, however, that the special theory of relativity does not compel us to deny ether. We may assume the existence of an ether; only we must give up ascribing a definite state of motion to it, i.e. we must by abstraction take from it the last mechanical characteristic which Lorentz had still left it.
...Recapitulating, we may say that according to the general theory of relativity space is endowed with physical qualities; in this sense, therefore, there exists an ether. According to the general theory of relativity space without ether is unthinkable; for in such space there not only wonld be no propagation of light, but also no possibility of existence for standards of space and time (measuring-rods and clocks), nor therefore any space-time intervals in the physical sense. But this ether may not be thought of as endowed with the quality characteristic of ponderable inedia, as consisting of parts which may be tracked through time. The idea of motion may not be applied to it.
A crude analogy might be this: A horse and a hippopotamus share some features (e.g. both have four legs), but that does not mean you can call a hippopotamus a horse. :rolleyes:
On the basis of your definition - I agree!
This has already been pointed out, but it really is the critical issue here, so...
granpa said:
a wave by definition requires a medium.
Granpa, quite simply, you are not "doing" science correctly. Scientific theories are not logical frameworks for connecting/explaining definitions, they are logical frameworks for connecting/explaining facts. You are getting hung up on a definition and ignoring facts. Given:
-The classical definition of a wave requires a medium.
-Light has not been found to have a medium and indeed has been found to disobey classical understanding of waves.
Only one conclusion is possible to a scientifically minded person: light is not a wave in the classical sense. Whether it is a new type of wave or is just wavelike isn't really important. It doesn't change the facts or how the theory works.
Now, you were given a gentle warning about forum rules. Consider this the final one: we want to help people learn and quite a few people have spent quite a bit of effort in that endevour, but you simply refuse to learn. Dogmatically clinging to this idea of yours -- and claiming it's validity in the face of irrefutable evidence/logic to the contrary -- is crackpottery and we don't allow it here. If you can't abide by these rules, the thread will not be allowed to continue.
DaleSpam said:
DrGreg said:
but the 2nd postulate does contain within it two assumptions that don't automatically follow from the 1st postulate.
1. The speed of light is finite, not infinite.
2. The speed of light is independent of the object that emitted it (which is another way of saying that one photon cannot overtake another following the same spatial path).
Don't both of those follow directly from applying Maxwell's equations in each frame?
Yes, they do. But who said Maxwell's equations were one of the postulates of relativity?
Let me guess you might answer this by saying that Maxwell's equations are one of the "laws of physics" covered by the 1st postulate. To my way of thinking, that doesn't really cover it. The 1st postulate doesn't actually explicitly identify which laws of physics it applies to. Just "all of them", whatever they turn out to be. But the 2nd postulate is explicitly necessary for relativity to work, an intrinsic part of the theory itself, and therefore ought to be explicitly identified, albeit in the watered-down version I suggested.
I've never thought about this much, but I imagine it might be possible to invent some fictitious laws of physics for a hypothetical universe that are incompatible with Maxwell's equations but still fully compatible with the postulates of relativity, and with each other.
By the way, there was a heated exchange on this very subject on the talk page of Wikipedia's article on special relativity. See here[/color].
no, just the valid ones. what relativity does is orthogonal to the other physical law. it just says that the expressions of that other physical law must apply identically to every inertial frame of reference. no qualitative or quantitative difference. since one of these "other physics" is EM, then two different observers observing the identical beam of light, will both observe the very same changing E field causing this other changing B field which itself is causing this other changing E field, etc. both observers of the same phenomena using the same Maxwell's equations to describe it, will both see the same wave advance at the same speed, having identical [itex]\epsilon_0[/itex] and [itex]\mu_0[/itex] in those Maxwell's equations.
it's follows from the first and the other laws of physics. there is nothing about relativity that isn't conformed to the Correspondence principle. Newton's 2nd law works both ways if it's expressed as dp/dt.
it turns out that the magnetic action, expressed as a fundamental law in classical physics, can be expressed as a consequence of the sole electrostatic action, but with the effects of special relativity accounted for. the inverse-square law of gravitation (in fact an entire set of corresponding Maxwell-like GEM equations) can be derived from the GR equation. SR can do away with the necessity of the equations of magnetism (essentially leaving just one action) and GR gets rid of Newton's law of gravitation.
relativity doesn't eliminate all other laws of physics. but it does help us understand that some of the old Laws are approximations to the new Laws for speeds much less that c and for reasonably flat space-time (i don't know how to quantitatively express it).
it doesn't matter. if some other expression of what happens to charged particles ends up obsoleting Maxwell's equations, it would be those laws of physics that would be subject to the postulates of physics.
:confused: no one is saying that Maxwell's equations are the specific physics that fall under the postulates of relativity but that Maxwell's equations are in the set of what is covered under the postulates of relativity. i guess some of them become unnecessary. but if they didn't become unnecessary, they're still physical law that is expressed within the context of relativity.
too late to edit the previous post. where i said
i meant to say
if some other expression of what happens to charged particles ends up obsoleting Maxwell's equations, it would be those laws of physics that would be subject to the postulates of relativity.
Well, not anymore--nowadays they are just seen as an approximation to quantum electrodynamics, and quantum electrodynamics may someday be seen as an approximation to a "theory of everything" which unites electromagnetism with the other three forces. In any case, if you want to define relativity via a set of axioms then you shouldn't include major implicit assumptions that aren't spelled out--the whole point of axioms is to spell out precisely what assumptions you want to make!
a worthy holy grail. but even if QED replaces Maxwell's equations, do not the expressions of physical interaction in QED (i don't know what they are) apply identically to any inertial frame of reference?
no, i think it's the other way. you do not want to itemize: "these are the specific laws of physics that the first postulate of SR applies to". if the postulate is fundamental (as i believe it is), then whatever system of physics that you show are valid (to whatever degree of experimental precision) in your inertial reference frame, that system of physics is just as valid in my inertial frame of reference, even if it is moving (at a constant velocity) with respect to yours. the postulate is that fundamental. and i think it's pretty damn reasonable.
Sure, but my point is that you don't want your axioms to depend on implicit assumptions about the correct theory of electromagnetism, you want a broad definition of "relativity" that would allow you to see that a universe where Maxwell's laws are correct in every frame respects relativity, and that a universe where QED is correct in every frame respects relativity, not to mention every other possible universe in which the laws of physics are the same in each frame and that things that move at c in one frame move at c in all frames.
Huh? I didn't say anything about itemizing laws of physics, I'm the one arguing for general axioms that don't depend on any implicit assumptions about the specific form of the laws of electromagnetism, while you're the one arguing that we should implicitly take for granted that "all laws of physics" includes some specific theory like classical electromagnetism or QED where light has a constant speed. You need to do this because you've dropped the axiom that things that move at c in one frame move at c in all frames, and clearly the axiom "the laws of physics are the same in every inertial frame" alone is not enough to specify a relativistic universe without additional implicit assumptions about the exact form of the laws of physics, since this axiom would hold true in a universe obeying Newtonian laws as well.
And again, this axiom would hold true in a Newtonian universe (Galilean relativity), but we all know that a Newtonian universe is nonrelativistic because there is no invariant speed. That's why you need to include the notion of an invariant speed as a separate axiom, unless you want the first axiom to include implicit assumptions about the correct theory of electromagnetism.
I'm surprised that no one has pointed out that EM (light) "waves" are not considered waves in the classical sense. So the classical definition of a wave (progressive disturbance of a medium) would not be relevant to modern theory which no longer uses that definition. It's only semantics, but you can't bait and switch definitions to make a point, it's just faulty logic.
Al
JesseM said:
My question was, 'but when you reach the level of the most fundamental laws, what exactly would it mean to have a "theoretical explanation" of these laws?'
I see what you mean here. But I wouldn't consider length contraction, time dilation, or gravitational force to be fundamental laws. Maybe the inverse square law, but that's not a law of physics or gravity, it's just a property of (Euclidean) geometry, it doesn't explain how gravity works.
Of course it's silly to think of a "theoretical explanation" of the inverse square law, because it's just true by mathematical convention in geometry.
Al
I would agree with that, but DaleSpam's message...
...seemed to imply he couldn't see the difference between "falling under the postulates" and "being in the set of what is covered under the postulates" as you put it.
Bear in mind that all "laws" of physics boil down to being mathematical models that approximate to how our universe really behaves, and as our knowledge improves we may generate new models that are better approximations than our old models. The postulates of relativity reflect our current understanding of the constraints that we believe apply to all models. (And as our understanding evolves we may need to reinterpret the wording of the postulates.) The second postulate (however we word it) does seem to represent an additional constraint beyond the first postulate that we need to apply to all our models (of which Maxwell's equations are just one).
(By the way, I agree entirely with JesseM's posts #131 and #133.)
On a final note, when you get down to the mathematics of it all, the two postulates aren't really used directly; it all boils down to symmetries. Any relativity-compatible model is required to be locally "Lorentz covariant", which means, roughly speaking, its symmetry group must include the group of Lorentz transforms.
OK, I can see the basic idea. First you throw out all physical laws. Then assume that whatever unknown set of physical laws are all frame invariant. Then you have to further specify that one of those unknown physical laws results in light going at c in all frames. I can see the approach, but I don't like it.
If you are going to throw out all physical laws and start from scratch, then just postulate the Minkowski geometry of spacetime (or symmetry groups as you mentioned). That seems better than throwing out all physical laws except one. Especially since if a photon is ever determined to have mass then light will not move at the invariant speed, but the invariant speed will still exist as part of the geometry of the universe.
Also, if I recall correctly the first postulate is often expressed as something along the lines "the same laws of electrodynamics and optics will be valid for all frames of reference for which the equations of mechanics hold good" which seems to include Newton and Maxwell both.
i wonder if "other possible universe" is nonsequitur.
anyway yeah, that's what i mean but the later part still follows from the first.
i don't see at all that it follows. i still think that an invariant c follows, semantically, from the first postulate of SR.
i think that is the more fundamental way to think about it. this essentially obviates the question we see here occasionally: "Why light?" questions, where my immediate answer is that it's not just light or EM, but this geometry of space and time that has this invariant c (which can be any real, positive, and finite value; call it "1", it doesn't matter), it's all fundamental interactions. this is, in my opinion, one level more fundamental than hearing that "information cannot be propagated at faster than c" postulate. i think this also follows from the fact that this geometry of space and time applies to any otherwise "instantaneos" interaction. you can't physically transmit information to anywhere else without the use of some physical interaction, all of which propagate at through space and time with at this unit speed.
that's what i think. and i think that, semantically, that includes c (obviating the need for the 2nd postulate), since Maxwell's equations can be easily rewritten with [itex]\mu_0^{-1} c^{-2}[/itex] replacing [itex]\epsilon_0[/itex]. since [itex]\mu_0[/itex] is defined by the unit current (or, equivalently, the unit charge, if the unit time is independently defined) and c is just this other parameter in Maxwell's equations that remains invariant, simply because of the semantics of the 1st postulate.
i continue to see no compelling need for the 2nd postulate of SR. i think the 1st postulate is necessary, and from what little i understand about GR, i think the equivalence principle is fundamentally a postulate (that seems reasonable, even though it would also seem reasonable, but less pleasing, if there were experimentally determined differences between inertial mass and gravitational mass).
Well, feel free to substitute "any possible new laws of physics we might discover in our own universe". For instance, suppose we find a TOE and find that its laws are actually Galilei-symmetric, not Lorentz-symmetric. If we construct our inertial coordinate systems so that they're related by the Galilei transform (and in a universe with Galilei-symmetric laws it should be possible to build types of rulers which don't shrink and types of clocks which don't slow down), isn't it still going to be true that the laws of physics are the same in every inertial frame? And yet clearly this would be a disproof of Einstein's notion of relativity.
Would not the first postulate still be true if it turned out the most fundamental laws were Galilei-symmetric rather than Lorentz-symmetric? But if you construct your inertial coordinate systems such that they're related by the Galilei transform rather than the Lorentz transform, then clearly an object moving at c in one frame can't be moving at c in all other frames, just by the way velocity addition works under the Galilei transform.
Hi JesseM, another question to make sure I understand this definition correctly:
I enclose air in a rigid box, and declare the box the entire universe. I am an observer in the box who only has low energy tools, so air is a continuum to me, and all excitations of the air are sound waves. Let's assume Galilean relativity. This means I can travel at a speed that makes a sound wave stationary relative to me. But I guess from our earlier conversations that this only means the wave has a rest frame of its own, and isn't equivalent to the medium having no rest frame of its own. My previous understanding of air having a rest frame of its own was that air without sound waves could itself move relative to space. But that doesn't seem to work here, since the box is the entire universe. How is the rest frame of the air determined in this case? (I have a rigid ruler and protractor)
You can use Doppler radar, a pitot tube, or a anemometer. Or if your instrumentation budget is really low you can always use the "finger in the wind" method.
So a rest frame is simply a frame in which we move at zero velocity relative to the wave? Isn't that just the rest frame of the wave?
BTW, what I'm trying to understand is why spacetime is not considered a medium for light. JesseM suggested that that was because spacetime had no rest frame of its own, which I thought I understood a few days ago as there being no sense in which spacetime can move relative to something else.
I thought you were trying to find the rest frame of the air, not the rest frame of the sound wave. The rest frame of the air would be the frame where any of the above airspeed measurement devices read 0.
I agree with JesseM. Air has a velocity, measureable by any of the means I mentioned. To my knowledge there is no such velocity measurement for empty spacetime.
Yes, but then I could just be stationary relative to the sound wave. If the wind blows, and I travel at the same speed as the wind, there is no wind. That doesn't mean the wind isn't blowing.
OK, at least it seems I understood that part correctly. From that example, I also understood from that the vacuum state photon field is also not a medium, because it fills all of space, and cannot be moved relative to space - the only way it can move is to be excited into a wave. That makes sense to me.
So if the air is enclosed in a box, and the box is the universe, then the air in the box cannot be moved relative to the box. All possible motions of the air in the box are some sort of sound wave. In this case, it seems that sound waves can also be thought of as not having a medium (which I'd be happy to accept).
This is basic relativity, there is no absolute means on detecting whether the wind is blowing or the Earth is moving. The only thing we can say is that the air and the Earth are in motion.
If the air is in a box, and the box is the universe, then the air cannot move relative to the box. Any wind that I feel is a long wavelength sound wave. If I don't feel any wind, it could either be that there is no sound wave and the air is at absolute rest, or there is a sound wave and I am traveling at the same speed as the wave. So if a medium is something that has a rest frame of its own (ie. can be moved without waves relative to space), it seems like sound sometimes has no medium.
What I am puzzled by is that there is a quantum description of sound waves that looks very much like the quantum description of light waves. In this sense, light is made of "stuff" (that is not controversial, the only question is what to call the "stuff"). The question then is how this "stuff" is different from the "aether" or a "medium". Given that light does not have a "medium" but is made of "stuff", and given the similarity of sound and light, it seems that I should be able to say (under some circumstances) that sound is made of "stuff" but does not have a "medium".
Just take a car or something and start moving inside the box, then measure the velocity of sound waves in your new rest frame which is different than the rest frame of the box. You will find that they are moving faster in one direction than the other, because they continue to move at the same speed in all directions in the rest frame of the box.
You clearly do not understand the principle of relativity.
I don't see what you are saying here. What does a box and the universe have to do with wind and sound?
Anyway, a sound wave, regardless of the frequency, does not involve bulk displacement of the medium. I.e. it is energy transport without net mass transport. In a box you can certainly have eddies, vortices, and all sorts of other "winds" that are not sounds because they involve bulk displacement of the air and net mass transport through a given region.
You are really not making any sense here. Can you explain your thought process better? I have no idea why you think that putting a big box around a medium makes the medium cease to exist.
