Finding Remainders for Large Numbers Modulo 5
The discussion centers on finding the remainder of the expression 1^99 + 2^99 + 3^99 + 4^99 + 5^99 when divided by 5. The final conclusion is that the remainder is 0. Participants emphasized the use of modular arithmetic, particularly the properties of congruences, to derive the results. A key insight shared was that summing n integers, where n is prime, results in a remainder of 0 when divided by n.
  • Understanding of modular arithmetic
  • Familiarity with congruences and their properties
  • Basic knowledge of exponentiation
  • Ability to apply the division algorithm
  • Learn about the properties of modular exponentiation
  • Explore the concept of congruences in number theory
  • Study the division algorithm and its applications in modular arithmetic
  • Investigate the behavior of sums of powers modulo n for prime n
Mathematicians, students studying number theory, and anyone interested in modular arithmetic and its applications in solving problems involving remainders.
cheiney
(a) Find the remainder when 1^99 + 2^99 + 3^99 + 4^99 + 5^99 is divided by 5.
(b) Generalize this result
Congruence Modulo
a\equivb mod n
also
a=n*q+b where q is some integer.
The remainder for 1^99 would be 1.
The remainder for 5^99 would be 0.
I'm having difficulty finding the remainder for 2,3,4.
I'm assuming I have to use modular arithmetic to find the remainder for these, but I'm not sure where to start. Anyone care to point me in the right direction?
For ##2^{99}##, note that ##2^4 = 16## which leaves remainder ##1##. So start by using the division algorithm to write ##99 = 4a + b## where ##b < 4##.
cheiney said:
The remainder for 1^99 would be 5.
really ?
jbunill has offered you an idea, which is a good one. However if you are still not sure how to proceed, try this: compute each of ##2^n## mod 5 where n = 0,1,2, .. 7. Observe what happens. From that point you should be able to compute ##2^{99}## mod 5.
Likes 1 person
Thanks everyone for your posts. I figured out the answer to both parts.
Part a) , the remainder is 0.
Part b) , If you sum n integers, where n is prime, and divide the sum by n, you will always get a remainder of 0.
P.S. Phinds and Mark44, I wrote it incorrectly. The remainder should be 1, not 5.
I especially appreciate brmath's post as this one made the most sense to me.
This is way too general... according to this claim, if I take 4 and 5, which is two integers, and I sum them, then divide by 2 I get a remainder of zero.
Ah, I didn't think of that. What if I specify n consecutive integers starting from 1?
Part (a) is not an example of that though... if it was
"Find 1+2+3+4+5 mod 5" then it would be, but as written it's not a sum of n consecutive integers.
Okay I understand what you are saying. What if I said:
If you sum 1^a+2^a+3^a+...+n^a (where n is a prime number) and divide this sum by n, you end up with a remainder of 0?
You can write 4 as -1 mod 5 and 3 as -2 mod 5.
( 1 mod5)^99 = (1 mod5)^98 *(1 mod5)
( -1 mod5)^99 = (-1 mod5)^98 *(-1 mod5),
the same with 2 mod5 and -2 mod5.
How are (k mod5)^98 and (-k mod5)^98 related?
ehild
Is it true if a even? For example, 12+22+32 divided by 3?
ehild
cheiney What is the connection between amod5 + bmod5 and (a+b)mod5? Figure that out by taking some examples.
Then figure out ##2^{99}, 3^{99}, 4^{99}## by the method I suggested earlier and use what you just learned about sums and mods.
It's best not to reach for general answers until you have worked out a number of specific cases.
  • · Replies 27 ·
  • · Replies 24 ·
  • · Replies 16 ·
