Removable discontinuity solution
  • Thread starter Thread starter grace77
    Discontinuity
9 replies · 5K views
grace77
Problem statement
Revelant equations
None
Attempt at a solution
I know it is discontinuous if the right hand limit doesn't equals the left hand limit? Is that correct?
The other criteria are
If f(c) exists, lim f(x) x--> c exists and lim f(x)=f(c)
I don't really understand what the other criteria mean? Also how will I tell from the piecewise function if it is removable?
For the graph question number 24 I know the points of discontinuity are the open holes however how do I know if it's removable?
Any help would be appreciated!
Removable means that there's a hole in the graph, as opposed to a break as you would find in a piecewise graph. Removable discontinuities have a hole at a place, and then they're discontinuous immediately to the left and right. They have the missing value (filled in dot) somewhere above or below the hole.
For a function to be continuous at a point c, three conditions must be met:
1) f(c) is defined.
The left graph in my attachment shows an example of a graph where f(c) is NOT defined.
2) [itex]lim_{x \rightarrow c} f(x)[/itex] exists.
The middle graph shows an example of a graph where f(c) is defined, but the limit at x = c does not exist.
3) [itex]lim_{x \rightarrow c} f(x) = f(c)[/itex]
The right graph shows an example of a graph where f(c) is defined and the limit at x = c exists, but lim f(x) does not equal f(c).
Hope this helps.
1) f(c) is defined.
Hope this helps.
Oh I understand it now. But how can that be used towards how to do those questions? How would I start?
Here's a good criteria to use:
If [itex]lim_{x \rightarrow c}[/itex] exists and [itex]lim_{x \rightarrow c} \neq f(c)[/itex], then there's a hole at [itex]c[/itex].
If [itex]lim_{x \rightarrow c}[/itex] doesn't exist, but [itex]f(c)[/itex] does exist, then there's a break, as in a piece wise graph that breaks between portions of the domain.
I understand that thank you but how can I use that to solve the question?
Just apply those formulas to the graphs where there are holes. For example, in 23, there's a discontinuity at x = 0, and in that case the limit exists (f(x) approaches 0 from both sides), but what the graph approaches doesn't equal what the function equals -- i.e. limit approaching c doesn't equal f(c), so then it's a removable discontinuity.
Ok thank you how do I do that using a piecewise function without a graph though?
Is it that if the 2 sided limits are different then it is not removable?
Yeah, if the left and right limits aren't equal, then it can't be removable.
