Replacing a failed RAID5 HDD with a single SSD in a DVR system
  • Thread starter Vanadium 50
    Ssd
30 replies · 8K views · last reply
Staff Emeritus
Education Advisor
Dearly Missed
TL;DR
I'm interested in experiences people may have using SSD for RAID when speed is not a factor.
Here's the history. I have a homebrew DVR using three Seagate 1 TB 2.5" drives in a RAID5 configuration. On Friday the DVR sent me an email (sweet, huh?) telling me a drive had failed. I cleared the fault and in a second it faulted again. I rebooted - it never came back up and the drive was making a woodpecker sound. I power cycled, it booted, no woodpeckers but it cannot find the drive.
Conclusion: the drive is toast.
It;s still in the system, which is not so nice. I switched to a mirror, so went from 2 TB usable to 1 TB but as I am only using 300-400 GB it;s no immediate problem.
The obvious solution is to pop in a replacement drive, reconfigure back to RAID5 and pretend none of this ever happened.
However...
Seagate no longer makes this drive. There are still a few in inventory, but their price has soared to $145. And what happens next time? I have seen these drives fail every couple of years.
The next idea is to replace it with the newer version of the drive. This uses SMR - shingled magnetic recording - which has issues with RAID in general and my RAID in particular. A rebuild takes under an hour, and I estimate over 2 days with the new drive. That's a long time to be vulnerable to a second fault.
There are some other options I considered, and won't go into unless they come up, but I am considering replacing all three drives with SSDs. No-name 1 TB SATA SSDs cost less than new 1 TB HDDs, and for a few bucks more, one can get a WD Blue. My thoughts:
  • One good reason to go HDD over SDD is cost. But the cost differential is small and may actually be slightly negative.
  • Another is reliability. WD says they stand by their SSDs to 400x capacity, i.r. 400 TB. My cache drive, which has slightly heavier use, sees about 5 or 6 TB/year. So I don't see this as substantially worse than the HDDs which last ~5-7 years before failing.
  • I get more speed than I need, but so what? It's not hurting anything.
  • Related, I can probably drop the cache drive. )A small SSD I have in the system now)
Am I missing anything?
Now...here is where it gets crazy. Suppose I just got one 1 TB SSD and replaced the failed drive. I could go back to RAID5 and my 2 TB capacity. This should work, right? I'm just not sure that anyone has ever tried it. And while speed is not a concern, it should be fast. Not as fast as a pure SSD system, but faster than a pure HDD system. And I could leave the cache drive attached if I wanted.
Is this absurd?
It's not absurd and will likely work well but a SSD and HDD raid will only be as fast as the slowest drive so I'd pick one or the other.
With a HDD there usually is some chance of data recovery. It might be expensive but there are lots of places that can do the job unless there's been a head crash that turned the platters into shavings. I like to build and use systems that have at least two drive fail RAID (Redundant Array of Inexpensive Disks) redundancy (for home use it's 900GB SAS enterprise drives I buy surplus and surface format for errors) and have real backup to a separate backup system with redundant raid drives. I've only used SSD drives in a mirror configuration as a multi drive fail RAID of them gets expensive.
My case might not be typical as:
Rack-mounted NETGEAR ProSafe XS508M 10G switch with several patch cables plugged into its front ports, sitting above a server with six hard drive bays, all within a metal equipment rack.
I run surplus enterprise servers (that have enterprise level raid error reporting and prediction) at home on a 10G house backbone that uses 24/7 off-grid solar power (battery bank)
for the computer rack and cooling.
Photo of a battery bank and power equipment: a black battery with 'Time' printed on its side, a 4000W inverter labelled 'DC' and '4000W', an OutBack Power charge controller mounted on the wall, green-jacketed cables, and a yellow multimeter with red and black probes.
24V 200Ah LiFePO4 Battery with 4000W inverter.
Photo of eight solar panels laid out on grass in two rows of four, with four panels on wooden frames and four flat on the ground.
Power system build pics.
A typical work related RAID 10 storage system
https://www.acronis.com/en-us/blog/posts/whats-raid10-and-why-should-i-use-it/
Rack-mounted server with a row of black drive bays, several with green activity lights, sitting under a monitor and keyboard on a workbench with a Craftsman tool chest behind it.
I don't think it's an issue for a DVR. If I lose an episode of The Muppet Show ("Nothing like good entertainment." "Yeah, and that was nothing like it!") I just wait for it to come around again. Anything I really, really want to keep gets transferred to my regular RAID anyway.
It's kind of academic, but I don't think it's the case. Consider the simplest RAID, a mirror. The system can get data off either drive, so if one is 3x faster than the other, it will serve 3x as much data as the other. The whole system should have reads 4x faster than the slow drive. Writes, I agree - it will be the slowest drive that throttles things.
In RAID5 things are more complicated, but the same principle applies. The system gets some data off one HDD and needs to get it's partner. It can get it from either the HDD or the SSD, so it more often than not gets it from the SSD. While the HDD is happily seeking away, the SDD is ready to go.
Now in my case, since there is a cache SSD in front of the RAID, I expect to run out of cache most of the time, and that can saturate a GbE link. So the RAID doesn't really need to go faster. The real rationale for this odd hybrid system isn't speed - it's cost, or availability of drives, which is much the same thing.
I confess I hadn't considered SAS drives. A mixed SAS/SATA system seems to me to have the same pros and cons as a mixed SSD/HDD system, plus I'd need to buy a controller, plus the drives look to be about the same price as new SSDs. And for a DVR quiet is a bonus. (I can't hear the Seagates except when they are dying)
jedishrfu said:
One thing to consider with SSD technology is filling it to capacity.
HDDs don't like it much either. :wink:
I think the DVR use case is probably the best for this. To first order, a show comes on, is recorded, is watched, and then erased. Yes, some programs are kept for a while, so this isn't exactly the case, but it's close.
It also means that the data is dominated by a few large files. Not sure of the impact of this, but it's certainly a feature.
I don't see speed as an issue. Typically, HD is about 1.6 GB/hour. I have four tuners, so my max write speed is 6.4 GB/hour or 15 Mb/s. (Note the switch to bits) That's tiny. As I said, read speed saturates the network, so I won't see any boost there.
Because of the caching structure, unless I have recorded a lot of shows without watching them, I am likely getting the data from memory, or at least my cache SSD. So the speed of the RAID array doesn't enter into it except for programs I recorded a long time ago and haven't watched and erased.
Remember, people used to "tape" shows - so the speed of magnetic tape was adequate.
I have a DVR type recording system using MYTHTV, Zoneminder and a DLNA server that what writes/reads large program sized files via SAS HDD raid. Speed is not a problem with good hardware and a fast network. Linux XFS to XFS file system transfers on a 10G Ethernet backbone.
Bulk file transfer numbers.
Screenshot of a network monitoring graph showing RX Bytes/second in green and TX Bytes/second in red over 60 seconds for interface enp1s0f0, with values in MiB and KiB.
Terminal output of ethtool eth0 showing 10000Mb/s full duplex link speed, auto-negotiation on, twisted pair port, and link detected: yes.
A typical raid mirror SATA drive
root@sma2:~# mdadm --detail /dev/md0
/dev/md0:
Version : 1.2
Creation Time : Sun Nov 11 20:35:49 2018
Raid Level : raid1
Array Size : 7813895488 (7.28 TiB 8.00 TB)
Used Dev Size : 7813895488 (7.28 TiB 8.00 TB)
Raid Devices : 2
Total Devices : 2
Persistence : Superblock is persistent
Intent Bitmap : Internal
Update Time : Mon Jul 10 07:13:08 2023
State : clean
Active Devices : 2
Working Devices : 2
Failed Devices : 0
Spare Devices : 0
Consistency Policy : bitmap
Name : sma2:0 (local to host sma2)
UUID : 3c87c6d1:7f6272fa:3cc0c731:55b9eae6
Events : 23685
Number Major Minor RaidDevice State
0 8 0 0 active sync /dev/sda
1 8 32 1 active sync /dev/sdc
root@sma2:~# smartctl -a /dev/sdc
smartctl 7.3 2022-02-28 r5338 [x86_64-linux-6.3.0-2-amd64] (local build)
Copyright (C) 2002-22, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Western Digital Red
Device Model: WDC WD80EFZX-68UW8N0
Serial Number: VK0X0TPY
LU WWN Device Id: 5 000cca 3b7ccbd61
Firmware Version: 83.H0A83
User Capacity: 8,001,563,222,016 bytes [8.00 TB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Rotation Rate: 5400 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5319
ATA Version is: ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon Jul 10 12:21:03 2023 PDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 016 Pre-fail Always - 0
2 Throughput_Performance 0x0005 130 130 054 Pre-fail Offline - 120
3 Spin_Up_Time 0x0007 193 193 024 Pre-fail Always - 323 (Average 358)
4 Start_Stop_Count 0x0012 100 100 000 Old_age Always - 46
5 Reallocated_Sector_Ct 0x0033 100 100 005 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 067 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 128 128 020 Pre-fail Offline - 18
9 Power_On_Hours 0x0012 095 095 000 Old_age Always - 39710
10 Spin_Retry_Count 0x0013 100 100 060 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 46
22 Helium_Level 0x0023 100 100 025 Pre-fail Always - 100
192 Power-Off_Retract_Count 0x0032 098 098 000 Old_age Always - 2843
193 Load_Cycle_Count 0x0012 098 098 000 Old_age Always - 2843
194 Temperature_Celsius 0x0002 171 171 000 Old_age Always - 35 (Min/Max 16/49)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0022 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0008 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x000a 200 200 000 Old_age Always - 0
SMART Error Log Version: 1
No Errors Logged
Your system is very impressive, no doubt about it. But I probably won't put together a solar-powered enterprise cluster to replace a failed drive so I can time shift The Muppet Show. ("Hey maybe we should be on the stage." "Yeah...there's one leaving town in five minutes.")
My experience with mdadm RAID is spotty - some work great, others seem to require some manual intervention every time the host is power cycled. And one terrible day at work when they replaced a failed mirror and the system dutifully copied the new blank drive onto the old working drive. Oops.
Your 8 TB Reds are CMR, so you won't see any of the SMR problems.
I mainly posted that to show what cheap surplus server hardware is capable of today if you have affordable power.
What you can get for under $200 is amazing.
Yes, it's a little much for the X-files or SG-1 recordings but much, much more valuable is knowing it's a rock solid hunk of hardware that's unlikely to fail just because of a reboot.
Screenshot of a DVR recording guide showing several Stargate SG-1 episodes listed with New tags, 16:9 format and file sizes, plus a highlighted entry for the 11:00 AM episode titled 2_3 Comet.
Stargate SG-1 and Colonel Jack O'Neill are forever in your debt.
The G'ould not so much and I think the Ori would concur citing the enemy of my enemy is my friend.
Just a data point here.
I've been using multiple WD Blue drives for many years. Their lifetime has been around 5000 ±500 hours.
Worst case was around 1800hrs. due to bad plating on the connector to the heads and positioner. Best case was 10,000hrs. for a few that spent almost all their life just spinning, (they were on-line backups, rarely read or written).
I typically dedicate one physical drive for all the temporary, paging, and scratch files. That seems to be "hard service" for them, they last roughly 2500 - 3000hrs.
Cheers,
Tom
nsaspook said:
SG-1
With a young Terryl Rothery...she's pretty.:heart:
Tom.G said:
WD Blue
Can you clarify? HDD or SSD? They market both now.
One annoying thing about WD is that their "Blue" drives of a given capacity actually include a half dozen or so models. There was also the merger of the Green and Blue lines which added to the confusion.
Many, many years ago, WD did something not very nice, I caught them at it, and they made it right. So I think of them in a generally positive light, even though I am a bit wary of what they say.
I do think that their introduction of SMR was handled poorly. First, it should have been announced, and they should have put it on their data sheets as soon as it happened. And second, I don't believe SMR is suitable for RAID, especially RAID5/6. They took advantage of the Red's reputation to sell lots and lots of drives unsuitable for the purpose for which they were sold.
If I place a spinning Blue drive into a RAID and the performance is terrible, it's on me. If I place a spinning Red drive into a RAID and the performance is terrible by design, WD needs to own it.
SDDs are of course different. In 2,5" SATA, I don't think the Red even exists, and advantages like "low vibration" are a non-issue.
I thought about it some more, and looked in a little.
I expect RAID5 to have the same write speed as one drive: the data has to be written three times, once per drive. I would expect the read speed to be 1.5x as fast. I only need to read from two of the drives to get my data, so with three drives, it should go 3/2 as fast: I read one sector from AB, one from BC and one from AC and I now have three sectors in the time of two.
Here there is data from all sorts of configurations: https://calomel.org/zfs_raid_speed_capacity.html
He sees better peformace than that. An excerpt:
Code:
1x 4TB, single drive,           3.7 TB,  w=108MB/s , rw=50MB/s  , r=204MB/s
 2x 4TB, mirror (raid1),        3.7 TB,  w=106MB/s , rw=50MB/s  ,  r=488MB/s
 3x 4TB, raidz1 (raid5),        7.5 TB,  w=225MB/s , rw=56MB/s  , r=619MB/s
I find this surprising. Both reads and writes go faster than simple scaling predicts.. While I did not run my own benchmarking, in part because every number in every configurration is much better than I need, I can say that scrubes - reading all the data from every disk and checking its integrity ran faster in RAID5.
Good grief, this had completely passed me by - I have always used Seagate IronWolf and I'm not regretting that now!
Yes I find some of those numbers a bit odd too - and I'm particularly surprised the only data for 4 disks is for RAID 6 and RAID 10, surely RAID 5 is the optimal compromise with 4 disks for most situations.
bonnie++ -u root -r 1024 -s 16384 -d / -f -b -n 1 -c 4
For this testing systems set of 600GB SAS drives in all slots.
/ raid 50
/images raid 6
/backups raid 5
Screenshot of HP Option ROM Configuration for Arrays version 8.50.66.00 on a blue BIOS screen, listing three available logical drives: #1 RAID 50 at 5.40 TB OK, #2 RAID 6 at 1.20 TB OK, #3 RAID 5 at 2.40 TB with online spare OK.
Well, I'm grateful that The Benchmark Guy did all that work. I think the overall message is that most configurations work as expected, with two exceptions: one is that writes tend to be faster, and the other is that RAID5 performs better than expected.
In my main RAID, I have some IronWolfs, and some Enterprise Capacities. (Formerly "Constellations") They work fine - they do send a lot of SMART messages saying "nothing's the matter". The only WD drive in there now is an HGST Ultrastar Helium. Seven drives total in a 3x2 array with 1 spare. I have to say the spare works shockingly well - temporarily lost one drive in a thunderstorm, and the spare automatically kicked in and resilvered. One reboot later and the process reversed.
But that's my main raid. The DVR is smaller and simpler. I'm kind of stick with 2.5" because of the enclosure, and I don't see many CMR drives in that size. Basically whatever is still on the shelf.
HDD - the ones with the shiny mirror that goes 'round 'n 'round.
BTW, my wife ordered a replacement drive from the Amazon site! :cry:
It was shipped via the Postal Service (US Post Office), :cry:
in a cardboard box with some bubble wrap on one side of it,
and it rattled in the box upon arrival. :cry: (the bubble wrap was collapsed)
Life is getting in the way, so it wil be several days before I can run a diagnostic on it.
That's some rig. I do wish people wouldn't post stuff like this, it's just made me blow a days billing on a new box for no better reasons than (i) I can; and (ii) I have a good place to donate the old one.
Power issues are much less of a factor in the UK (urban area): never had a surge and an outage is maybe once in 24 months. It makes one complacent.
Yes I figured that. Now SSDs are bigger, cheaper and more reliable I think I'd ditch the RAID entirely for this application unless I couldn't live with losing Statler and Waldorf.
That's not a problem. When you pick up the drive itself and it rattled, now that's a problem!
One of my best Blues is a sketchy one I got from Amazon. It was 2/3 the price as usual, and was advertised as new. I got it, and it had 2000 hours and some poor schmuck's data on it. Amazon refunded my money, told me to keep the drive and the drive disappeared from their website. It's been running without incident for several years now.
It's a funny looking thing. 3.5" form factor, but the shiny part where the disk innards live is only half as tall as usual.
But I am not sure what inferences can be drawn between Blue HDDs and Blue SSDs. There are lots of different models sold as "1 TB Blues", like my oddball. Some may have been HGST or even IBM. The SSDs are SanDisks.
I'm less concerned about the individual drive I put in than whether there is some systemic issue. For example, the RAID may notice rhat the HDDs are substantially slower, and thehn decide they have faulted. I don't think this is a situation where the user base has a whole lot of experience.
pbuk said:
That's some rig.
Thanks. It kind of grew organically. Today, it has enough capacity for me, is fast - as fast as a local disk, with the server being on a 10 GbE connection, and most importantly, I have never lost a byte of data.
There's little point to upgrading this setup. Making it faster won't help, since it will run up against the networking. And, like I said, it has speeds like a local disk. (about 8 Gb/s typical, and 4-5 for long transfers) If I ever need more capacity, I can just swap some disks. These are 6 TB's, so replacing a pair of 6's with a pair of 12's (the sweet spot in price today) is straightforward. It would also be accomplished with the RAID in use, so there's little impact in my work.
The DVR RAID is simpler. Its job really is to make sure that I can lose a disk and still watch The Muppet Shown ("That wasn't half bad." "No, it was all bad!") while it gets fixed. Losing the data here is not like losing my tax forms (which have multiple backups in addition to being RAIDed). But the RAID exists not so much to preserve data as to preserve uptime.
The real issue is thunderstorms. They cause brief power issues - maybe a second, maybe a little less. I don't know if this is my GFI, the power company's or something else. It;s annoying. What can happen is that the computer stays up, but gets into a funny state. Not funny ha-ha, but funny as in "how old is this food anyway? It tastes funny." And because these events are correlated, you can get a double fault - a fault when repairing from the first fault.
So getting 2 TB of capacity with three 1 TB drives rather than one 2 TB drive has its advantages.
Having a RAID just for a DVR seems like overkill. And such small drives are odd - the cheapest drives I see around are 4 tb these days.
Not in the UK: I just paid GBP18.50 per TB for 8TB, 12s are nearly GBP27 per TB. Not worth going 6TB to 8TB, but I was on 4TB drives (and the 8s are 7200 RPM vs the 4s 5400).
Yes, I didn't realise how much those old guys meant to you. I'd worry about sustained write performance on consumer SSDs but the sweet spot on IronWolf is 2GB at GBP 78 per TB, but I bet they are as safe as houses: RAID 1?
The rate shouldn't be so bad. I have numbers upthread, but you can look at it this way - if an ordinary HDD is good enough, surely an SSD is good enough.
pbuk said:
Not in the UK:
I think that's because the drives need to spin in the opposite direction. :olduhh:
So maybe.maybe not. It adds what, $40 to the total cost? And what does it buy you? Really, what it buys you is the ability to keep recording during a drive failure. And we all know that drives fail at inconvenient times, like the middle of the night or when when I am out of town,
Do I need 2 TB? Not really - what I really need is 1 + ε TB. But that means 2 TB. And making a 3x1 TB RAID5 is a lot cheaper than a 2 TB mirror, especially since I already own 2/3 of the drives I need.
1.2 TB is a common size in SAS. However, going that route again requires more drives, plus a controller, plus 10K drives are not exactly quiet, plus I don't need the speed. So it' not really that good a choice.
A lot of people would say for any purpose whatever RAID5 is underkill.
RAID5 shouldn't directly cause data loss because you should have a backup but it will affect online data availability when you need to restore a nuked array from that backup after the array died during a parity rebuild with the replaced drive.
Increasingly redundant RAID arrays simply reduces the chances of needing a full backup, it doesn't eliminated the need for backup.
Screenshot of a Bacula bconsole terminal session showing director status, a list of terminated jobs with job IDs, levels, files, bytes, status and finish times, and a status prompt for a client.
I don't consider RAID any kind of substitute for backup. That sounds like a plan that will eventually make me sad.
The issue with RAID5 is surviving a rebuild. Most consumer drives say they have an unrecoverable error every 1014 bits or so. Drives are usually better than this, but that's what the datasheets say. Suppose my 3x2 main raid was configured as a 4 drive RAID5 rather than 3 mirrors. That would save me the price of two drives.
Now, suppose I replace a drive and need to rebuild. I need to read 18 TB of data to rebuild the parity. At 1014 there is about a 70% chance of a second failure, this time during the rebuild, and my pool will be borked.
If I mirror it instead, I am reading only 1/3 as much data, so my failure rate is 3x smaller. Instead of a 70% chance of losing my pool., there is a 70% chance it will survive.
But...
My DVR RAID is small. If you work out the numbers, the only difference in survivability between a mirror and parity is the total volume of data. So the only reason RAID5 is less safe is because there's more data on it. And it's only a little more data. So I would argue it's safe enough - or at least as safe as its ever going to get.
Just for fun, I ran some numbers on what would happen if I used these for my RAID.
I have 6x6TB drives (plus a spare) so I would get the same capacity with 40 (!) 900 GB's. This is my main RAID, not the DVR. This would obviously require more controllers, probably more PCI lanes, and some...er..aggressive cable management.
Arranged in 20 (!) two-way mirrors, I'd by looking at something like 6000 MB/s read speed. That would saturate 10 GbE, and it would saturate 40 Gb/s InfiniBand. (Even more OCI lanes there) It would read an hour long TV show in under a second.
Seven times as many drives means ~7x as many failures (even transient ones) so rebuilds every 2 months or so. But they'd only talk half an hour.
I wouldn't even know what to do with this much speed.
Thunderstorms here last night. During the monthly RAID scan/rebuild, so the worst possible time. Had a drive drop out, and the system did exactly what it should have - stopped what it was doing, attached the spare, rebuilt the array, and continued the scan. After power cycling it, it re-attached the original drive and put the spare back where it found it.
I haven't gotten around to adding the SSD, but my plan is to initially add it as a 3rd mirror drive. If all goes well for a while, then switch from a 3-way mirror to a RAID5. This is technically impossible but also there is a technical trick.
Things are more complicated than I thought.
Open up the case and unplug what I think is the bad drive, plug in the SSD. Linux tells me the RAID has one drive, and doesn't see the SSD. Huh.
OK, so I undo what I did. The RAID now sees both drives, and the BIOS sees three: the two working RAID drives and the broken one. Huh.
SMART tells me there's nothing wrong with the "bad" drive. Huh.
I use two SATA to USN connectors, Windows and Linux, and nobody even sees the SSD. Huh.
So, I am now operating a 2-drive mirror and tests on the bad drive, outside of the mirror. If that looks good, I'll put it in the mirror for a week or so, and if that still looks good, I'll do the Secret Magic Trick to turn it from a 2-way mirror into a RAID5.
Now to figure out what is happening with the SSD.
I see I never got around to reporting the outcome. The SSD went bad. The words "firmware PROM" were spoken, but not by anyone who knew anything. WD slowly replaced the drive, and in the interim I found a 1 TB spinning disk.
So I used the replacement SSD elsewhere, and the DVR happily uses a 3x1 RAID5 configuration.
