Reshape 3x3 array in Fortran causing segmentation fault
4 replies · 3K views · last reply
davidfur
Hi guys,
On with my Fortran adventures...I'm trying to accomplish a simple task: assign a 2D array with some reals. Here's an excerpt from the code:
Fortran:
subroutine get_energy_and_grad(natoms_,coords,ereal,gradmat)
    include 'cbka.blk'
    include 'opt.blk'
    integer, intent(in)    :: natoms_
    double precision, intent(in)    :: coords(3*natoms_)
    real*8, intent(out)    :: ereal    ! total energy
    real*8, dimension(3,3), intent(out)    :: gradmat
    call vlist
    call srtbon1
    call encalc
    ereal = estrc ! total energy
!    write (*,*) 'natoms_ is: ', natoms_
    write (*,*) 'size of gradmat is:', size(gradmat)
    write (*,*) 'size of d is:', size(d)
    write (*,*) 'shape of gradmat is:', shape(gradmat)
    write (*,*) 'shape of d is:', shape(d)
    gradmat = reshape((/ 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0 /),(/3, 3/))
    write(*,*) 'gradmat is: ', gradmat(2,3)
end subroutine get_energy_and_grad
This just won't assign the 1.0-9.0 reals into gradmat and throws out the following:
Code:
 size of gradmat is:           9
 size of d is:        7500
 shape of gradmat is:           3           3
 shape of d is:           3        2500
Program received signal SIGSEGV: Segmentation fault - invalid memory reference.
Backtrace for this error:
#0  0x7F3B8F78EE08
#1  0x7F3B8F78DF90
#2  0x7F3B8F0D54AF
#3  0x40151C in __reaxff_interface_MOD_get_energy_and_grad
#4  0x402C5E in MAIN__ at main.f90:?
Segmentation fault (core dumped)
I'm obviously doing something really stupid, but I just can't figure out what's wrong... need help!
Dave
Here's a tutorial on the reshape function:
https://www.tutorialspoint.com/fortran/reshape.htm
I don't see what wrong but a memory error often indicates referencing an element outside the array bounds.
Perhaps, you could try being more explicit and breaking the statement up a bit:
Fortran:
 real*8, dimension (1:9) :: b = (/ 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0 /)
 gradmat = reshape( b , (/3, 3/) )
Thanks jedishrfu, but it doesn't work either. I suspect there's something wrong with my declarations...
I post here the full code if this helps
Main program
Fortran:
program main
use reaxff_interface
implicit none
integer natoms_
real*8 ereal
real*8, allocatable :: coords(:,:)
real*8, allocatable :: gradvec(:,:)
call get_energy_and_grad(gradvec)
write (*,*) "This is main. grad(3,3) is : ", gradvec(3,3)
end program main
Module
Fortran:
    module reaxff_interface
    implicit none
subroutine get_energy_and_grad(grad)
    include 'cbka.blk'
    include 'opt.blk'
    grad = reshape( b , (/3, 3/) )
end module reaxff_interface
output:
Code:
Program received signal SIGBUS: Access to an undefined portion of a memory object.
#0  0x7F4FB566DE08
#1  0x7F4FB566CF90
#2  0x7F4FB4FB44AF
#3  0x7F4FB574563F
#4  0x7F4FB5748154
#5  0x7F4FB5748D3E
#6  0x402DBF in MAIN__ at main.f90:?
Bus error (core dumped)
Fortran:
    include 'cbka.blk'
    include 'opt.blk'
    call vlist
    call srtbon1
    call encalc
I see two or maybe three problems:
1. In your three call statements, none of the subroutine calls is written correctly. The syntax for a call statement is
call SubName(argument1, argument2, ...). If a subroutine has no parameters, the parentheses still must be used. See http://pages.mtu.edu/~shene/COURSES/cs201/NOTES/F90-Subprograms.pdf, on page titled "Subroutines: 2/2".
You don't show the definitions for the three subroutines, so I can't tell if any of them takes any arguments.
2. What is d? There is no declaration for d in either the parameter list or in the declarations for local variables, so d apparently is a global variable. It's very bad practice for a function of subroutine to access global variables. At the very least, doing this makes debugging much more difficult.
3. I'm not sure that reshape will take a list of constants as its first argument. Per the GNU Fortran Compiler man page for reshape (https://gcc.gnu.org/onlinedocs/gfortran/RESHAPE.html), it appears to me that the first argument has to be a variable, but I'm not certain of this.
Thanks Mark44 for your help!
I managed to solve the problem by properly declaring and allocating coords and gradvec variables outside the get_energy_and_grad subroutine.
Cheers!
