Resonance and understanding what a resonant is?
  • Thread starter Thread starter Spookie71
    Resonance Resonant
This discussion centers on the concept of resonant waves, specifically the second and third resonances in wave physics. Users clarify that resonant waves occur when two waves superimpose, resulting in different patterns based on frequency. An applet is recommended for visualizing these resonances, showing how varying frequencies produce distinct nodes and antinodes. The equation for calculating wavelength in relation to resonant frequencies is also discussed, highlighting the confusion around manipulating the formula.
  • Understanding of wave superposition
  • Familiarity with nodes and antinodes in wave physics
  • Basic knowledge of resonance in sound waves
  • Ability to manipulate algebraic equations related to wave properties
  • Explore the applet at http://www.ngsir.netfirms.com/englishhtm/StatWave.htm for visualizing wave interactions
  • Study the principles of resonance in open and closed air columns
  • Learn about the mathematical derivation of wave equations, focusing on the relationship between wavelength and frequency
  • Investigate the physical applications of resonant frequencies in musical instruments and acoustics
Students of physics, educators explaining wave phenomena, and anyone interested in the principles of sound resonance and wave behavior.
Spookie71
Here is a page out of my textbook but I'm having trouble understanding what a Resonant is
They try to explain it clearly but I get confused when they start talking about a 2nd and 3 resonant. The pictures seem clear that they exist with their nodes and antinodes but where do the 2nd and 3rd come from. Confusing to me. maybe someone can explain better how this works.
I have uploaded the page to here at photobucket
http://i215.photobucket.com/albums/cc10/Spookie71/image0-11.jpg
Again I can make sense of the first drawing, I just don't understand where the other two come in. Maybe it just needs to be explained different.
Thanks
Scott
Okay, you understand what it means for two waves to be superimposed (added together) right? Resonant waves are just one possible result when you add two waves together. Here's an applet that can let you see what happens with different frequencies:
If you max out the amplitude on the applet and set it to a frequency of 75 you can see a resonating wave with 4 nodes. At 99 you can see one with 5 nodes.
Even though there are is one particular string, you can have different resonances (one with just two nodes, one with three nodes, 4 nodes... and so on.
So those pictures that i posted for you are based on using different frequencies, that makes more sense to me. the applet makes a lot more sense. The page didn't really say it was using different frequencies, just that there was a 2nd and 3rd Resonant.
Still confused but the overall picture is becoming clearer.
Thank you
Can I help you with whatever you're still confused about?
Anadyne I appreciate your help. to be honest I'm just a little overwhelmed. It's a lot of new concepts all at once. Just a matter of processing them. I guess it would help a little if I knew where we are going and where I will apply this later in Physics. It's a lot to remember how sound resonates in an air column that is open ended or closed on one end. Must sound silly to you but I'm having difficulty. Wish I could be more specific.
Scott
Ok here is a question for you, How can a column of air be closed at both ends? as their describing in this textbook?
Actually forget my last question:
I have a question regarding an equation again.
Required is \lambda
l = \frac{(2n - 1)\lambda}{4}
becomes
\lambda\frac{4l}{(2n - 1)}
I understand that you multiply the 4 by both sides and then bring the 4l over as the numerator. Where it becomes confusing is the (2n -1) and bringing it down to the denomenator. Doesn't bringing it down from the numerator cancel it out?
12K
12K
  • · Replies 31 ·
15K
