Resources on Gear Cutting Machines
The discussion focuses on the quest for detailed resources about the history and mechanics of original gear-cutting machines, specifically Polhem's and Whitworth's designs. The user expresses difficulty in finding comprehensive descriptions that include the mathematics and components involved in these machines. Suggestions point to various online resources, including books, museum archives, and specialized libraries that house historical documents and drawings. It is noted that much of the valuable information on early machine tools is not readily available online and is primarily found in physical texts and exhibits. The user acknowledges the helpfulness of the shared resources and looks forward to exploring them further.
enJayneering
I'm interested in learning about how original gear cutters were made, such as Polhem's manually operated gear-cutting machine or Whitworth's design. So far, I have only been able to find very brief or vague description on how they worked. Any helpful resources that explain the mathematics and parts utilized to create such machines is much appreciated! I am working on a project that requires the skills to create my own tools. Thanks!
http://www.gracesguide.co.uk/Category:Machine_Tools
https://books.google.co.uk/books?id=mLUclpsfTeQC&pg=PA694&lpg=PA694&dq=whitworth+gear+cutting&source=bl&ots=-jWHW7tgtz&sig=h_TUKO6027pE5C3OSYpjML9RHKo&hl=en&sa=X&ved=0ahUKEwi52ba8mODKAhVH7BQKHWBWBjoQ6AEIMjAD#v=onepage&q=whitworth gear cutting&f=false
https://www.imeche.org/libraries-archive
http://www.sciencemuseum.org.uk/visitmuseum/new_galleries/research_centre
There is a large amount of information on development of early machine tools but not much of this has found it's way to the internet - bulk of information is in books , papers and museum exhibits .
Thanks for sharing! I had already stumbled upon a few of the sources you mentioned, but I didn't realize there was libraries of old articles and drawings of some of these machines. I definitely have a lot to sift through. Thanks again!
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
