Restoring force (negative or positive)
  • Thread starter Thread starter pugfug90
    Force Positive
The discussion centers on the concept of restoring force in the context of a pinball machine and pogo stick mechanics. Alesia exerts a force of 10N on the pinball machine's spring, which has a force constant of 200N/m and is compressed by 5cm. The restoring force is defined as the force that acts to return the spring to its equilibrium position, which is equal in magnitude but opposite in direction to the force exerted. The conversation highlights the distinction between the magnitude of force, which is always positive, and its direction, which can be negative.
  • Understanding of Hooke's Law and spring mechanics
  • Basic knowledge of force vectors and their magnitudes
  • Familiarity with equilibrium positions in physics
  • Concept of force constants in springs
  • Study Hooke's Law in detail, focusing on its applications in various mechanical systems
  • Explore the concept of equilibrium in dynamic systems
  • Learn about vector representation of forces in physics
  • Investigate the relationship between force constants and energy stored in springs
Students studying physics, particularly those focusing on mechanics, as well as educators teaching concepts related to forces and springs.
pugfug90
First, I'll give a problem in context..
In anticipation of her first game, Alesia pulls back the handle of a pinball machine a distance of 5cm. The force constant of the spring in the handle is 200N/m. How much force must Alesia exert?
Convert 5cm to 0.05m.
F=kx..
k=200N/m
x=0.05m
200N*0.05m/m=10N
But why is it positive..
I have a definition for restoring force as
"Whenever a spring is stretched from its equilibrium position and released, it will move back and forth on either side of the equilibrium position. The force that pulls it back and attempts to restore the spring to equilibrium is called the restoring force."
"The force that acts to move the spring away from the equilibrium position is equal in magnitude to the restoring force, but opposite in direction."
So.. In Alesia's pinball machine.. the spring is in equilibrium? The force that Alesia exerts makes the spring not equilibrium.. So shouldn't the force be negative? I realized that the force exerted after she releases is going to be the same magnitude..
And that's just the context problem..
Gary Stewart of Reading, Ohio set a pogo stick record in 1990 by jumping 177737 times(irrelevant??). a)If pogo stick he used had a force constant(k) of 6000N/m and compressed 0.12m on each jump, what force must Gary have exerted on the pogo stick upon each jump?
b)What force would be exerted back up on Gary each time he went up?
Note that the magnitude of a force is always positive because it is a vector. The direction of the force is another story. With Hook'e law, if you know where the equilibrium position is, the spring force vector will point to it.
I remember with electrostatics.. Forces of attraction were represented with negatives..
http://phun.physics.virginia.edu/topics/electrostatics.html
In situations like these you have to think about what the they physically represent.
Think of it this way how would you move a book with negative force?
No matter what direction you move the book the book is always moving positively with respect to the force you apply on it.
