Reverse-tracing Einstein's field equation
  • Level: Graduate
  • Thread starter Thread starter TheMan112
    Field
11 replies · 9K views
TheMan112
How do I rewrite Einsteins famous field equation
[tex]R_{ab} - \frac{1}{2} g_{ab} R = \frac{8 \pi G}{c^4} T_{ab}[/tex]
into:
[tex]R_{ab} = \frac{8 \pi G}{c^4} (T_{ab} - \frac{1}{2} g_{ab} T)[/tex]
I've tried experimenting with reverse-tracing the Ricci-scalar, but I just don't get the right equation. The trace from these equations would yield [tex]R=-T[/tex]. Is this really correct?
Multiply both sides by [tex]g^{ab}[/tex] to get
[tex]\frac{1}{2}R = \kappa T[/tex]
then substitute back.
Ok, I insert the expression and get:
[tex]R_{ab} - \frac{8 \pi G}{c^4} g_{ab} T = \frac{8 \pi G}{c^4} T_{ab}[/tex]
[tex]R_{ab} = \frac{8 \pi G}{c^4} \left(T_{ab} + g_{ab} T \right)[/tex]
Which as you can see is not entirely right. Have I missed something very obvious?
Take trace of both sides of Einstein eq. Trace of the metric is 4. Trace of Ricci tensor is R. You get
R = - k T
then substitute that back for R and take the metric term on the other side.
I made a mistake, [tex]g^{ab}g_{ab} = -1[/tex].
Check for an errant sign in this equation.
Okay, that fixes it.
smallphi said:
[tex]g^{ab}g_{ab} = \delta^a_a = 4[/tex]
Yes, you're correct. It's |g| = -1.
How can |g| = abs(g) = -1 ? An absolute value can't be negative. For example a radius cannot be negative.
|g| = 1 only in Special Relativity. In GR, the value of |g| changes with the coordinate system used but it's signature (the signs of the eigenvalues when you diagonalize it) doesn't change, depending on the sign convention it's either (-, +, +, +) or (+, -, -, -).
