Rewriting a function with y as the independent variable
To rearrange the equation y = x^2 - x to express x in terms of y, one can rewrite it as x^2 - x - y = 0, which is a quadratic equation. Solving this quadratic will yield multiple solutions for x due to the nature of the function not being one-to-one. It's important to note that not all equations can be rearranged to isolate x in terms of y, as seen in the example y = x + sin(x). The discussion emphasizes the need to treat y as a constant when solving for x. Understanding these principles is crucial for effectively manipulating equations with multiple variables.
Sidthewall
Ok. Sooo. Let's say u have y=x+5. Then u know y-5=x. Now if u have y=x^2 - x. How would u rearrange it to find out what x equals. I found out that in general I cannot rearrange ewquatioms with mitiplr x variables with different exponents. So help me please
Mathematics news on Phys.org
It's just a quadratic in x where you treat y as a constant.
y=x^2-x
x^2-x-y=0
I am not trying to find the x-intercept. I need the function to have x as the dependent variable and y as the independent variable for ex. If y=sqr(25-x) then y^2 - 25 = -x
Mentallic is pointing out that you have a quadratic equation of the form ax^2 + bx + c = 0. Solve the quadratic equation and you will get x in terms of y. (But there will be more than one solution as y = x^2 -x is not a 1 to 1 function).
Also, although you can do it in this case, note that you can't always explicitly solve for x in terms of y. For example, y = x + sin(x).
Yep Mute's got it :-p
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 21 ·
