Riding a train from Chicago to Detroit
  • Thread starter Thread starter tymartin
    Train
The problem involves a scenario where a person is riding a fast train from Chicago to Detroit and notices a discrepancy between their watch and the clocks in the Detroit station. The discussion revolves around the implications of time zones and the effects of relativistic physics on time perception.
  • Participants explore the possibility of a time zone difference between Chicago and Detroit, with some suggesting that Detroit is an hour ahead. Others question the assumptions about the type of watch and consider the effects of inertia and time dilation due to high speeds.
The discussion is active, with participants offering various theories regarding time zones and relativistic effects. There is no explicit consensus, but multiple interpretations are being explored, including the potential for time dilation to play a role in the observed discrepancy.
Participants are considering the implications of the problem as a thought experiment, particularly in relation to Einstein's theories. The nature of the watch (analog vs. digital) is also under consideration, which may affect the reasoning presented.
tymartin
You're riding in a very fast train from Chicago to Detroit. In Chicago you set your watch to the correct time, but as you ride through downtown Detroit, you notice that your watch differs from the time shown on the clocks in the station! Are all the clocks in Detroit wrong, or is your watch broken? Or is something else going on? Explain
I might be just be not thinking on this problem because it seems so easy. Wouldn't it because their is a time zone difference between Chicago and Detroit? Detroit is an hour ahead of Chicago so that is why your clock is different than Detroit's clock.
i think they are on the same time zone.
fisrt i am assuming the watch is a hand watch
not digital. with that said
if i had to explain this here is what i would say.
that everything that has mass has inerta. if you
are moving on the train very fast maybe the
intera "forces" (inerta really is not a force but oh well)
are preventing the arm from moving at the speed it should,
thus slowing your watch down.
that is my theory not sure if it helps
well, if you are moving REALLY fast, time can slow down for you a noticeable amount
Detroit is on Eastern time. Chicago is on Central time. There is no reason in physics why clocks in Detroit and Chicago or on the train would run at different rates, unless this is one of Einstein's thought-experiment trains!
AM
Hi tymartin! :smile:
tymartin said:
You're riding in a very fast train …
the question says "very fast", so i'd go with thepopasmurf :smile: and guess you're supposed to take time dilation into account :wink:
