Ring Homomorphism: unit in R implies unit in R'
  • Thread starter Thread starter AcidRainLiTE
    Ring Unit
The discussion centers on the properties of ring homomorphisms, specifically addressing the necessity of mapping the multiplicative identity (1) in ring R to the multiplicative identity (1') in ring S. It is established that while the general definition of a ring homomorphism does not require this mapping, the preservation of multiplicative inverses in the context of units necessitates it. An example is provided with the homomorphism from the integers to 2x2 matrices, illustrating that a failure to map 1 to 1' results in the absence of units in the image.
  • Understanding of ring theory and the definition of ring homomorphisms
  • Familiarity with the concepts of units and multiplicative inverses in rings
  • Basic knowledge of matrix representations in linear algebra
  • Awareness of unitary and non-unitary rings
  • Study the properties of ring homomorphisms in detail, focusing on unitary versus non-unitary definitions
  • Explore examples of ring homomorphisms that do not map 1 to 1' and their implications
  • Learn about the structure of the group of units in various rings
  • Investigate the relationship between ring homomorphisms and group homomorphisms in algebra
Mathematicians, algebraists, and students studying abstract algebra, particularly those interested in ring theory and homomorphisms.
AcidRainLiTE
I was just looking at wikipedia's article on ring homomorphisms (http://en.wikipedia.org/wiki/Ring_homomorphism) and I am a little confused.
If you look at the definition they give for ring homomorphism, they require only that addition and multiplication is preserved over the homomorphism (and not that it maps 1 to 1'). Then, under the 'Properties' section, the third bullet down claims:
If a has a multiplicative inverse in R, then f(a) has a multiplicative inverse in S and we have f(a−1) = (f(a))−1. Therefore, f induces a group homomorphism from the (multiplicative) group of units of R to the (multiplicative) group of units of S.
Don't you need to explicitly require that the homomorphism maps 1 to 1' in order for that statement to be true? Or is there someway to deduce this without specifying that requirement?
Not all rings are unitary, so the definition of ring homomorphism given on wikipedia is for a general ring. When a ring is unitary, most people require that a homomorphism map 1 to 1, but occasionally you will find authors who do not use this convention (in this case, 1 just maps to some unit in the ring).
It need not be true if the homomorphism does not map 1 to 1'.
For example, consider the map f : \mathbb{Z} \rightarrow M_{2 \times 2}(\mathbb{R}) defined by
f(n) = \left[\begin{matrix}<br /> n &amp; 0 \\<br /> 0 &amp; 0<br /> \end{matrix}\right]
This is a ring homomorphism that does not map 1 to 1', and clearly the image contains no units.
Thanks for the quick response!
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 0 ·
