RL circuits - finding resistance and inductance
Cocoleia
Circuit schematic with a 24 V voltage source, a switch marked t = 0, resistors R1 and R2, an inductor L, a 3 Ω resistor, and the output voltage v_o(t) across the 3 Ω resistor, with current i(t) marked.
I am practicing questions from the book in preparation for an exam, and I am having trouble with this one
According to my professor, the answers are: R1=12ohm, R2=9ohm, L=34.28 H
So far this is what I have done:
Voc = 6V
τ = 20/7
Vo = 3V
Rt=7L/20
Rt=6/(-24+Isc(R2+3)
This is just from analyzing the equation that was given in the question. I don't know if my logic is correct, and I am not sure what the next steps will be.
Start with your equation for v(t). What is its value when t equals 0?
Since the current through L can't change instantaneously, prior to closing the switch, what is the current flowing in the circuit? That is the same current that flows through the 3 ohm resistor, so the v(0) value should help.
See if this helps any.
Heed @magoo's clues. The important thing here is to note that the current through the inductor doesn't (or can not) change instantaneously, but voltage across it can.
Cocoleia said:
Voc = 6V
τ = 20/7
Vo = 3V
Rt=7L/20
Rt=6/(-24+Isc(R2+3)
What do these symbols (Rt, τ, Voc) stand for? Which method are you using?
Given the voltage equation, what will be the equation of current for t>0?
τ is the time constant
Voc is open circuit voltage
and Rt is thevenin equivalent resistance
(I think)
(I think)
You need not use Thevenin for this circuit.
What is the current through the circuit at t=0+?
