Robertson-Walker metric and time expansion
54 replies · 12K views
grelf
The Robertson-Walker metric applies a time-dependent scale factor to model the expansion of the universe. The scale factor is only applied to the spatial coordinates (in the frame of the "comoving observer"). That is not covariant and it is hard to see how c could remain constant if the same factor is not applied to the time coordinate. So my question is: is there any evidence that time does not expand at the same rate as space?
Astronomy news on Phys.org
Hi, grelf,
Welcome to Physics Forums!
Covariance is a local property of the laws of physics, not a global property of the solutions to those laws.
Cosmological expansion is not just a change of coordinates. If it were, then it would be undetectable. One of the basic principles of GR is that you can make any arbitrary, smooth change of coordinates, and it doesn't change the physical interpretation.
I don't think expansion of time is a notion that's well defined. If it means a nonlinear (but smooth) distortion of the time coordinate, then it's not observable. If you have in mind something observable, what observations do you have in mind?
-Ben
To expand a little bit on bcrowell's point, if you also multiplied the time coordinate by the scale factor, then what you'd have is just a coordinate transformation of Minkowski space-time, so that there would be no expansion at all, just static, flat space-time.
Try this, transform the FRW metric with k=0 to its conformal form, in this particular case you can use conformal time as the time coordinate:you get a line element in terms of conformal time with a scale factor that also multiplies the time coordinate and it is actually a coordinate transformation of Minkowski spacetime with conformal time. (No expansion at all if conformal time is used instead of cosmological time)[itex]ds^2 = a(t)(dt^2 - dx^2 - dy^2 - dz^2)[/itex]
Also, in the conformal form of the FRW line element coordinate c is isotropic and has the constant value c everywhere.
http://arxiv.org/PS_cache/arxiv/pdf/1103/1103.4743v1.pdf
I show above that for the case of a spatially flat FRW universe actually it is just a change of coordinates. Just by switching back and forth between cosmic and conformal time coordinate you have spatial expansion or a static spacetime multiplied by a scala conformal factor (expanding space-time).
Expansion in itself is indeed directly undetectable. Certainly we detect redshift, but attributing it to expansion is purely model-dependent ( the prevailing model by the way).
bapowel, chalnoth? anyone disagrees with any of this?
That's exactly correct. But the change of coordinates to a flat spacetime is only possible with the FRW metric if you have an empty universe (because it was a flat spacetime to begin with).
I believe that the problem with your solution is that the time (t) that is the argument of the scale factor function is not the coordinate being used any longer, so that when you run through Einstein's equations, they come out non-zero.
In any event, it is a general result within General Relativity that no coordinate transformation can change the curvature scalar R, which is non-zero for any curved space-time. Since R is non-zero in the FRW universe (unless said universe is empty), this transformation cannot give a flat space-time.
Sounds good to me as well, with the caveat that this refers to a global change of coordinates (diffeomorphisms applied to the whole manifold). Locally, one can always transform away the gravitational field (the equivalence principle) leading to different (gravitational) physics.
I believe that the problem with your solution is that the time (t) that is the argument of the scale factor function is not the coordinate being used any longer, so that when you run through Einstein's equations, they come out non zero.
Sure, any flat spacetime corresponds to empty spacetime. But what I was highlighting in the conformal form of FRW metric with k=0 is not that, this is not a flat spacetime, but a Minkowski spacetme multiplied by a conformal scale factor -function of conformal time that may include a density parameter so it has non zero curvature scalar.
I was rather pointing out that this conformal form is compatible with a static spacetime or a expanding spacetime with space and time components exapnding by the same factor, which amounts to the same thing.
As I said the above mentioned transformation doesn't give a flat spacetime, but a static spacetime with curvature dependent on the density parameter encoded in the scale factor.
I'm not sure in what sense this is a caveat. It is a perfectly valid change of coordinates (conformal time is widely used in cosmology). The manifold is the same.
General covariance (diffeomorphism invariance) of GR ensures the form of all physical laws under arbitrary differentiable coordinate transformations.
It's a caveat in that the statement as made is only true for global coordinate changes. A local coordinate transformation very much changes the physics.
I don't see how a change to conformally flat spacetime coordinates is a local change of coordinates. It is not. The physics here doesn't change at all.
See http://arxiv.org/pdf/1103.4743 section 3
I'm not referring to any specific coordinate transformation, conformal or otherwise. There must be some confusion -- I was remarking only on the quote made by bcrowell --which was a general statement about coordinate transformations -- and nothing else.
That's interesting. Can you clarify what you mean by a local versus global coordinate transform? Suppose I have a smooth mapping that, outside of some 4-ball of spacetime is the identity. Are you saying this can change physics? How? (Every invariant quantity derivable from the metric will be unchanged). I must be mis-understanding what you mean.
Perhaps I'm unclear on what constitute a "change in physics." By local transformation, I have in mind the coordinate transformation at a single point on the manifold that brings you to the tangent space. I was referring to this as a transformation that "changes physics" because it removes the gravitational field (sends a general metric [itex]g_{\mu \nu}[/itex] to Minkowski). I'm merely referring to the equivalence principle here. This is of course different from a global diffeomorphism, under which spacetimes describing the same gravitational physics form equivalence classes. This is what everyone has in mind when they refer to the coordinate invariance of GR, and what bcrowell was referring to. I'm sure everyone's clear on this and so it was probably unnecessary for me to be so nit picky about this point.
Of course, if you really want to be pedantic, it is coordinate covariance, not coordinate invariance. Invariance would mean that if you change the coordinates, all the output numbers you get remain the same. Covariance means that you change the numbers, and many quantities you measure will be different (e.g. you'll have different energy, momentum, etc.), but the relationships between them remain the same.
One way of saying the same thing is that I can start in some coordinate system, perform a transformation into another, do a bunch of calculations, and then transform back, and the answer I get is guaranteed to be identical to the answer I get if I just leave everything in the original coordinate system (provided I'm careful not to divide by zero anywhere).
Actually, I was intentionally saying invariants derived from the metric because any actual measurement I can think of involves contraction or integration resulting in a quantity that is invariant. Even for seemingly coordinate dependent quantities, like KE, the way I look at is that if you specify a measuring device following a particular world line measuring KE of some object, the result is invariant. Thus, if the tensors are covariant, the observables are invariant.
I don't think that's right. Just to take a really simple example: consider the round-trip light travel time measured at the source by, oh, bouncing a laser off of the Moon from an observatory on the Earth. I can change this quantity trivially by just changing my time coordinate around. But, of course, the number I get will always differ by a simple coordinate transformation.
I don't agree. Consider an actual clock. If you build in some notion of time measurement that differs from proper time, then modeling the physics of the clock as specified will allow computation of its behavior as an invariant. I think I'm making a fairly trivial statement - the result of an actual measurement is coordinate independent. Changing coordinates used for analysis cannot change what reading a device will produce or what the result of a particle interaction is. Thus I claim all actual observables in GR are invariant; any quantity that is not invariant is not actually an observable.
I don't think this is right, the distinction between covariance and invariance Chalnoth made is well established.
Except that by defining a clock (including its motion), you've picked out a particular coordinate system. I could easily pick a different clock that it accelerated differently, and it will record a different time. But the times recorded on the two clocks will be simply-related by the coordinate transform between one clock and the other.
I think what I am saying is also well established. Tensor quantities don't represent observables in GR. Only contractions or integrations of them do, resulting in invariant observables.
You can choose to look at it that way. I think it makes more sense to say the observable - the reading of a particular clock - can be described in a coordinate independent invariant way; and that all real observables should be defined this way. For example:
1) device measures KE of a particle; this is dot product of device 4-velocity at interaction event with particle 4 momentum, minus norm of 4-momentum. Coordinate independent and invariant. No matter what coordinates I use, I conclude the same thing about what the device measures.
2) clock measures round trip time of radar signal to the moon. Proper time along clock world line from emission to reception event. Different clock will be different. Both measurements coordinate independent, invariant. Of course they depend on the clock (particularly, its state of motion), but they don't depend on labels I attach to points on a manifold.
I stand by the point of view that any real observable must be an invariant in GR.
Define "observable in GR" and give some examples of them. Is momentum a "GR observable"?
Hmmm, I suppose. However, this particular statement of invariance is just a statement of consistency: if this weren't true, then the theory in question would predict different experimental observations just depending upon how you did the calculation. Any theory that did that would clearly be wrong.
I suppose the more accurate statement, then, would be that tensors in General Relativity are covariant, while contractions of tensors to scalar quantities are invariant (this follows, if I remember correctly, from the covariance of tensors).
This seems a very trivial statement that has nothing at all to do with GR.
No, it isn't. Imagine that I have a sensor attached to a clock, that ouputs on a digital display the time that a photon hits this sensor based upon this clock. The observable is the output on the digital display.
No, momentum per se is not an observable. A measured momentum is an observable. Defining the measuring process (most importantly, the world line of the measuring device) gives an invariant definition of the measured momentum. This all gets back the fundamental principle that results of measurements and interactions are invariant. What shows up on a dial, a picture, a particle detector are all invariants.
Correct. And this is almost exactly the wording I have used a few times: observables are contractions or integrations of contractions. And yes, all such are invariants in the mathematical sense.
I don't actually see the connection between saying that a scalar measure obviously is an invariant (otherwise what 's the use of measuring anything?) with the previous discussion or with the OP.
