Calculating Angular Speed of Rotating Apparatus with Attached Mass and Rod
The discussion focuses on calculating the angular speed of a rotating apparatus consisting of a 3.0 kg rod and a 4.0 kg rectangle. The correct angular speed at the moment the rod is horizontal is determined to be 5.19 rad/s. Key equations utilized include the potential energy equation (mgh) and the rotational energy equation ((w^2 * i) * 0.5), with the moment of inertia for the rod calculated as (m * L^2) * 0.333. The user identified errors in their initial calculations and clarified the need to compute the rotational energy of both the mass and the rod.
  • Understanding of potential energy (mgh)
  • Knowledge of rotational energy equations ((w^2 * i) * 0.5)
  • Familiarity with moment of inertia calculations for rods
  • Basic principles of angular motion
  • Study the derivation of moment of inertia for various shapes
  • Learn about energy conservation in rotational systems
  • Explore angular acceleration and its relationship with angular speed
  • Investigate practical applications of angular speed calculations in engineering
Students in physics or engineering courses, educators teaching mechanics, and anyone involved in the analysis of rotational dynamics in mechanical systems.
JiggaMan
The 3.0 kg rod has a length of 80 cm. The 4.0 kg rectangle attached to the rod has negligible dimensions. The entire object rotates counterclockwise about the bottom of the rod. Determine the angular speed of the apparatus at the instant the rod is horizontal.
https://gyazo.com/9d0bb4ce2fed98b192f173a918549f60
^image
mgh = potential energy
( w^2 * i ) * .5 = rotational energy
i = moment of inertia
moment of intertia for rod rotated on end = (m * L^2) * .333
L = length
m = mass
w = angular speed
THE ANSWER SHOULD BE 5.19 rad/s
*For the height, I found the center of gravity which is .63 meters, i think the length stays .8 though
mgh = (w^2 * i ) * .5
mgh = (w^2) * (m * L^2) * .333 * .5
7 * 10 * .63 = ( w^2 ) * (7 * .8 * .8 ) * .333 * .5
44.1 = (w^2) * .746
59.115 = (w^2)
7.68 = w
7.68 rad/s ?[/B]
Being the genius I am, I have self-analyzed my own work and found my error. For the rotational energy. I must find the rotational energy of the mass first, then the rod:
( ( w^2 ) * .5 * 4 * .8 * .8 ) and ( ( w^2 ) (3* .8 * .8 ) / 3 ) then add them and take out the w ^ 2 since the angular acceleration should be equal for both:
( w^2 ) ( (.5 * 4 * .8 * .8 ) + ( ( 3 * .8 * .8 ) /3 ) )
I was however correct to have found the center of gravity for mgh.
  • · Replies 25 ·
