Rolling Resistance for Large Trucks
The discussion revolves around the calculations of rolling resistance and air drag for a large truck, specifically a 60,000 lb vehicle. Participants explore the implications of these forces on the truck's deceleration and coasting distance when in neutral, examining both theoretical and practical aspects of the problem.
  • One participant calculates rolling resistance and air drag forces, yielding a deceleration of -0.011 g and a coasting distance of 1186 meters, which they find surprising.
  • Another participant references a real-life example of coasting and suggests that the actual coasting distance would be longer due to the non-linear nature of air resistance.
  • It is noted that air resistance is not linear and decreases with speed, complicating the calculations of deceleration.
  • A later reply emphasizes that the problem involves a non-linear ordinary differential equation (ODE) due to the nature of drag forces, suggesting a longer stopping time when solved correctly.
  • One participant expresses a shift in perspective, acknowledging that real-world factors like engine braking and tire conditions may affect their initial assumptions about coasting distances.
Participants express differing views on the accuracy of the initial calculations and the implications of air resistance. There is no consensus on the exact stopping time or distance, and the discussion remains unresolved regarding the complexities introduced by non-linear dynamics.
Participants highlight limitations in the initial assumptions, particularly regarding the treatment of air resistance and the simplifications made in the calculations. The discussion also touches on the practical realities of truck operation that may influence theoretical outcomes.
This discussion may be of interest to those studying vehicle dynamics, engineering principles related to motion, or anyone involved in the practical aspects of truck operation and performance analysis.
jimgram
I'm calculating the rolling resistance and air drag for a 60,000 lb truck. I used a Cd=0.7 for drag coefficient; 6 m2 for frontal area; and a rolling coefficient of Cr=.008; density of air=1.3 kg/m3.
I get a force from rolling resistance of 2142 N (Cr*mass*g). I get a force from air drag at 35 mph of 676 N (1/2*ρ*Aveh*Cd*v2).
All is well - until I calculated the deceleration of this truck based on these two forces (I.E. the transmission is in neutral and no brakes) (a=f/m). I get a deceleration of -0.011 g (-0.103 m/s2).
This decel rate yields a distance to coast to a stop (v2/2*a) of 1186 meters - nearly 3/4 of a mile and taking 152 seconds (almost 2.5 minutes). This, to me, seems unbelievable for a 60,000 truck. If I change the velocity to 60 mph I get a 1 1/2 mile coast taking about 3 minutes. Can't be - where did I go wrong??
Looks about right to me:
https://www.youtube.com/watch?v=zYE2TN2zI8M​
And I don't think the car was in neutral, so there was probably some engine braking involved. There is also this other real-life example:
On a training day with negligible wind, sunswift IV entered the flat straight of the race track at 70 k.p.h. The driver then switched the motor off and coasted, using no brakes. After covering a marked kilometer, she was traveling at 50 k.p.h. What is her acceleration?
In your example, the real result would even be longer as drag will lower with speed, hence acceleration will lower as well.
Air resistance isn't linear in the sense we think it is.
As jack action observes, air resistance decreases in magnitude as the speed decreases, so it's incorrect to use a constant acceleration formula to solve this problem. The solution is a bit more complicated since it's a non-linear ODE as well: m\dot{v} = - b v^2 - Cmg. If you solve it (it's a little tricky to do, but possible), you'll see that you get a bit more than 2.5 minutes stopping time when you take into account the reduced force with time. If you're confused, you're probably thinking it's because the truck is so massive that it should have a large resistive force against it -- and that's true. But it also has a lot of momentum, and the drag forces take a long time to erode it all. Or another way to think about it is that the mass represents resistance to acceleration, and in particular more mass makes it take longer to decelerate the truck (and this effect competes with the larger rolling resistance).
Well, hardly a criticism, as the drag listed in the OP is indeed non-linear :)
Really? Show me where it's NOT in his calculation.
I'm convinced. I think I'm just accustomed to trucks with improperly inflated tires and drivers rarely, if ever, shift to neutral and totally decouple the engine. In fact, it's more common to use engine braking.
BTW - I know air drag is a function of velocity squared and while it only accounts for 24% of the total drag at 35 mph, it very rapidly diminishes, making the coast time and distance even greater. Thanks for all of the input.
13K
11K
32K
10K
