Will the Unsecured Shed Roof Withstand the Storm Winds?
  • Thread starter Thread starter vu10758
    Storm
The discussion centers on the stability of an unsecured shed roof under wind conditions of 20 m/s. The conclusion is that the roof will indeed fly off due to the pressure dynamics involved. The internal pressure of 1.01 x 10^5 Pa, combined with gravitational forces, must exceed the external pressure, which includes the wind pressure calculated using Bernoulli's principle. The correct interpretation of the equation P + 0.5 * density * v^2 + density * g * y reveals that increased wind velocity results in decreased pressure on the roof.
  • Understanding of Bernoulli's principle
  • Knowledge of pressure calculations in fluid dynamics
  • Familiarity with basic physics concepts such as mass, gravity, and area
  • Ability to manipulate equations involving pressure and velocity
  • Study Bernoulli's equation and its applications in fluid dynamics
  • Learn about pressure differentials and their effects on structures
  • Explore the relationship between wind speed and pressure using real-world examples
  • Investigate methods for securing roofs against high wind conditions
Engineers, architects, and homeowners interested in structural integrity and wind resistance of outdoor structures, particularly those dealing with shed or roof design.
vu10758
Someone is putting a small shed in their backyard. The roof is not nailed down so gravity alone is holding it down. The wind suddenly flows across the top of the roogf at 20 m/s. The air inside the shed is 1.01 x 10^15 Pa, the normal atmospheric pressure. The roof has an area of 16m^2 and a mass of 250 kg. Density of air is 1.29 kg/m^3. Will the roof fly off?
The answer is that the roof will fly off.
In order for this to be true, pressure inside plus gravity must be greater than pressure outside.
Pushing down I have Pressure_up = 1.01 x 10^5 Pa.
I know that Pressure_down = mg/A + P_wind
I know this must be less than 1.01 x 10^5
However, what is the formula for Pressure_wind? I know the faster the wind, the smaller the pressure. I know formulas such as p + .5*density*v^2 + density*g*y, but it seems like a higher velocity would yield a higher pressure with this formula. It shouldn't be that way. What am I doing wrong?
What is "p + .5*density*v^2 + density*g*y" equal to?
If you use the equation correctly, you will find higher velocity does give lower pressure.
  • · Replies 20 ·
15K
20K
