Root test for series 2^n/(4^n+1)
  • Thread starter Thread starter banshee43
    Root Series Test
12 replies · 3K views · last reply
banshee43
Can you if given a sigma notation for an infinite series
Ʃ 2^n/(4^n+1)
rewrite as,
Ʃ 2^n/(4^n+1^n)
then doing the root test can you
lim n→∞ n^√abs((2/(4+1))^n)
which equals 2/5, and
2/5<1, therefore can i conclude that the series above converges?
Sorry if this is in the wrong section, i guess its more of an algebra question.
Ʃ 2^n/(4^n+1)
rewrite as,
Ʃ 2^n/(4^n+1^n)
No this is 100% wrong to do.
Your series is :
##\sum \frac{2^n}{4^{n+1}}##
Which is definitely NOT equal to :
##\sum \frac{2^n}{4^{n} + 1^{n}}##
Why don't you try the ratio test, it will work perfectly for this.
sorry i didnt put enough parentheses my series is 2^n/((4^n)+1)
Zondrina said:
banshee43 said:
Ʃ 2^n/(4^n+1)
rewrite as,
Ʃ 2^n/(4^n+1^n)
Your series is :
OP was correct !
Actually, Ʃ 2^n/(4^n+1) is [itex]\displaystyle \ \sum\frac{2^n}{4^n+1}\ .[/itex]
SammyS said:
OP was correct !
Sorry, the lack of parenthesis confused me.
So can that 1 be represented by a 1^n? Because no matter what n is Given n>=0 that 1^n = 1.?
Yes. That's fine, but I don't see why that helps.
You do realize that [itex]\displaystyle \ 4^n+1^n\ne(4+1)^n\,,\[/itex] don't you ?
I thought that it looked funky when I did it. Thank you though
So, do you have a solution ?
Using the ratio test because there are constants raised to powers i get..
(2^(n+1)/(4^(n+1)+1))*((4^(n)+1)/2^n) then using some algerbra
(4^(n)+1)/(4*4^(n)+1) and some more algerbra...
gives me 1/4 which is <1 therefore the series converges?
(2^(n+1)/(4^(n+1)+1))*((4^(n)+1)/2^n) then using some algebra
(4^(n)+1)/(4*4^(n)+1) and some more algebra...
Are you using a limit without stating that you are?
[itex]\displaystyle \frac{4^n+1}{4^{n+1}+1}\ne \frac{1}{4}\ .[/itex]
Also, what happened to the 2 ?
yes i am using a limit and i forgot about the 2, i guess it converges to 1/2 then? i had forgotten that the ratio test needed a limit because i wasnt in class when we learned it.
banshee43 said:
yes i am using a limit and i forgot about the 2, i guess it converges to 1/2 then? i had forgotten that the ratio test needed a limit because i wasn't in class when we learned it.
Anyway, the series converges.
