Rotating pendulum hang from a wooden bar with a revolution speed of 0.15 rev/s.
The discussion revolves around solving a pendulum problem involving a wooden bar and its rotation speed. The user struggles to derive the correct angle θ that the pendulum makes with the vertical, initially obtaining an impossible value of 209 degrees instead of the expected 85.7 degrees. Participants suggest using numerical methods and iterative approaches to solve equations involving both sine and tangent functions. A specific method is proposed, where the equation is reformulated to facilitate iteration, ultimately leading to a valid solution of 67 degrees. The conversation highlights the utility of numerical methods in solving complex equations and the importance of validating provided answers.
JLABBER
Part c: A pendulum is attached to a 0.15m wooden bar sticked horizontally to a table by a string of 0.12m. If the system is revolved with a revolution speed of 1.5 rev per second, what is the angle θ the pendulum make with respect to the vertical axis?
Tsin θ =mrw^2
Tcos θ = mg
where r=0.15 +0.12 sin θ
To identify my mistake at how to solve this question as I can't get the answer provided which is 85.7 degree using my original equation. Instead, i get a value of 209 degree which sounded so impossible to occur.
Thanks for help.
You are right, the solution you got is not possible. Show your derivation. The question can not be answered exactly, you need some numerical method. Check the validity of the solution given. I think it is also wrong.
ehild
Okay, i will check. Thanks a lot. I think the question is taken directly from a book by my lecturer. And the answer too. What do you mean by numerical method? Do you mean that my solution is right but not possible? And this question can be solved with a valid possible answer through that numerical method?
For my way of solving,
First i divide the first equation by the second equation and i get
tan theta=rw^2/g
Then, i substitute r= 0.15 + 0.12 sin theta into the new equation,
tan theta = (0.15 + 0.12 sin theta) (1.5 X 2pi) ,
After that, i try to rearrange and solve for the theta, but i have no way to get the answer because there is sin and tan simultaneously, i have no point of solving it. But, using a calculator, I key in the equations, and get an ans of -871 degree of the equation. Is my equation correct anyway?
tan theta=rw^2/g
That is correct.
tan theta = (0.15 + 0.12 sin theta) (1.5 X 2pi)2/g
You missed a square and dividing by g.
-871 degrees? ... That is almost three rounds clockwise:smile:
Correct the last equation and substitute the given angle, than try 67 degrees. ehild
Wow, exactly 67 degree can solve for the equation. But, how should i solve equation involving sin and tan simultaneously? I do not have a single idea of solving it. Should we first changing tan into sin/cos?
You can do it by iteration. Write the equation in form of
tan(θ ) = A(1+Bsin(θ ))
It will be
tan(θ ) = 1.3596(1+0.8sin(θ ))
for the given data.
Start with θ=0, and evaluate the right-hand side. You get tan(θ), find inverse tangent. This will be your θ for the next step. find the sine, evaluate the RHS , get arctan, and repeat till the result does not change within 3 digits. Try, it is fun:wink:
ehild
Okay, i will try. Such a new knowledge for me, thanks a lot.
You are welcome. The method of iteration is very useful, although it does not work always.
ehild
I see. Ya,One more question, for this method, does it apply only to equation when tan theta= A(1+sin theta)?
It applies for other cases in form x=f(x), but the magnitude of the derivative of f has to be less than 1 (|f'|<1).
There are other methods to solve implicit equations numerically. It is always very useful to plot both sides and find the crosspoint graphically.
ehild
